DB789
Posts posted by DB789
  1. Please could I have some advice.
    I have rigged the fore and main masts except for the yard braces, I’m now onto the mizzen mast and trying to understand how the jeers work for cross jack yard. It looks to me from Chris’s plan that the line just loops around the base of the mizzen topmast and doesn’t go through any blocks - is that correct? Where does the jeers line start - is it just tied to the mizzentop? Anything that could help me visualise this arrangement would be hugely appreciated. IMG_5326.thumb.jpeg.a8ab8e02796a5ba6ed56ce2cd3e93b3c.jpeg
    I’ve trawled through all the build logs on MSW without success and the Peterssen book does not cover a cross jack yard with lateen yard below.
    Thanks again.
    Dan
  2. Rigging is progressing and the spritsail and foremast yards are fitted. I keep crossing lines and my rigging is messier than I’d like it to be. Even with Chris’s superb plans I often find it difficult to work out the path of each line through the bird’s nest of other lines. It’s all a learning curve still for me, with the plan to eventually build a frigate (Sphinx and/or Surprise) - hopefully by then I’ll have a good idea of the run of most lines.
    IMG_5174.thumb.jpeg.0724a446abe88ddbf554b2353ff0a224.jpegIMG_5170.thumb.jpeg.ab2947f53e32ceaf4078e6a37e31e508.jpegIMG_5169.thumb.jpeg.2da1d5eaef7f6ce5c5a7c5e8377ded8c.jpeg
    The foremast and yards are mostly rigged but I haven’t added yard braces yet as they’ll get in the way when working on the main mast yards.
    Still to make the main and mizzen yards.
    Thanks for the likes and encouragement!
  3. Andrew and Ronald thanks so much for your encouragement, you’re very kind! Having followed logs from both of you, you’re both much more skilled at this than I am. Andrew, please do restart your Sparkler, I’m looking forward to seeing how you complete her.
    I felt my logs were more useful and read when they were one of the first or only logs on a kit such as Grecian, Adder and some of the later Vanguard fishing boats… I’ve tried to be much more comprehensive on those and not so detailed on a well established kit such as DoK with plenty of other much better builds.
    It certainly is a support network!
    Duchess now has all forestays and backstays in place as well as all three crowsfeet.
    IMG_5087.thumb.jpeg.b2b07f6ede599c7c6702d83a4fdeda47.jpegIMG_5085.thumb.jpeg.7c4371dfa308e4e49bfd18abff24770a.jpegIMG_5084.thumb.jpeg.bc9c89cdf33bb9c716795d72fbad6a60.jpegIMG_5083.thumb.jpeg.69a6c2d5db6dc78da48722c2c1bc6894.jpegIMG_5081.thumb.jpeg.a698413d658c2854883eec094a9bda0a.jpeg
    Most of the stays are just tied on with the knots not glued, so quite messy with lots of excess thread everywhere and some lines need a little more tension.
    I’m not sure whether to tie off, glue and trim all the lines now or leave them so they can be removed and adjusted when the yards and their rigging is added. It’s already quite a confusing forest of threads with the lines not trimmed, but access to areas such as below the tops is already quite restricted with all the stays, crows feet and shrouds in place. Any advice very welcome!
    Duchess looks near completion, but I still have not made any of the yards so there’s quite a bit of work still to come. I doubt that I will have time to start making the yards on the lathe for a couple of weeks due to other commitments, but I’m looking forward to getting on with this last stage.
  4. More slow but steady progress!
    Topmast and topgallant shrouds completed as are the topmast shroud ratlines. IMG_5050.thumb.jpeg.c9429f31303018dded265f1c884122ae.jpeg
    Also added the bowsprit shrouds and the forestays and mainstay. I’ve added the foremast crowsfeet too which was much easier than expected! IMG_5053.thumb.jpeg.43059fff581dafe9eb0fe4b116543bc5.jpegIMG_5051.thumb.jpeg.583b224f31f8807062e01aae769f5599.jpeg
    Lots of lines not fully tied off yet so I can adjust tension if need be. Makes the model look a bit messy.
    Thanks for the likes. Not sure I’m adding anything with this log that much more accomplished builders haven’t already achieved on the DoK! I’m enjoying the build so will keep going with the log.
  5. Fantastic looking Speedy, I’ve really enjoyed following your build, I’ll certainly be benefiting from your log when I build Speedy later in the year - thanks. Mine won’t look nearly as good and I’m still somewhat daunted by the rigging…. which looks a step up in terms of complexity from Adder, Grecian and Duchess of Kingston.
  6. Thanks Bob!
    Doesn’t look like much progress - but I have completed the ratlines for the lower shrouds and added futtock shrouds too. All very straightforward but a touch messy! I use CA for this as I don’t have the patience to use white glue….
    One of the foremast catharpins was cut by accident and needs to be replaced.
    IMG_4416.thumb.jpeg.d31a8d9c8e7b21e6c63731a4cae03073.jpegIMG_4419.thumb.jpeg.cbce5952b6ad1b792f48d95a19e8cd7a.jpeg
    Made a start on the foretopmast shrouds too.
  7. On 3/4/2025 at 6:59 PM, palmerit said:
    The photos in the Sherbourne instructions book at the end for the rigging are actually from a different (similar but not identical) model ship (maybe the Alert, I don't know) - the instructions do say that.
    That’s Trial, not Alert.
    I’m away for a few days but I’ll open up my Sherbourne when I get home and will try and work out where those blocks go too.
  8. 11 minutes ago, palmerit said:
    Did you experiment with mixing the dyes together vs. doing a dip in one dye and doing a dip in another dye. I'm sure I can read a bunch on how to dye things. Just wondering if you had experimented or had seen videos or posts recommending dye mixing vs. sequential dyeing.
    I did try mixing dyes together based on the colour mixes on the RIT website - I think that’s probably the recommended way of dyeing. My dye mixing is all in the Nisha log that I sent to you.
    I only tried the sequential dyeing for this set of sails as I was disappointed by the colour achieved from tan dye alone. Had no idea if it would work, but was very pleased with the outcome.
  9. On 2/19/2025 at 8:44 PM, palmerit said:
    Can you unpack that a bit?
    How strong is strong (for the tan) and how weak is weak (for the scarlet)? I maybe dyed something 40 years ago.
    How long did you keep the sails in the tan (you specified of the scarlet a minute or two)?
    Did you use the Rit powder or liquid?
    Maybe I can start by dying an old t-shirt or something. Any idea what material the sails are made from? The part list in the instructions just say "Cloth". Cotton? Linen? If I'm going to experiment I'd like to find the same material.
    Ranger was the sixth and last of my fishing boats, so the dying was more by feel rather than measuring out exact amounts of dye.
    I used the RIT liquid dyes. This is the tan one, scarlet from the same range.
    https://www.ritdye.com/products/tan/
    I think that the sails are made of linen. I experimented a lot on old T-shirts but the cotton fabric and weave made a big difference to the end colour, so they weren’t very useful. These experiments are all in my Nisha build log, link below.
    Broadly I followed the instructions and timings in this RIT Dye video for the tan but adjusted the strengths. It came out a bit drab and brown so I mixed up some scarlet and as an experiment put the sails in that for max two mins, maybe less.
    https://www.youtube.com/watch?v=wL6NFLL8NI0
    I can’t give you more accurate guidance than stronger than the instructions say on tan and weaker on scarlet. You’ll just have to judge it. Sorry I can’t give you better guidance!
    Your build is looking great so far.
  10. Have fun with this one. I really enjoyed building her, she’s very straightforward and an imposing model when complete due to her tall mast and huge sail area relative to the other Vanguard fishing boats. She’s currently sitting pride of place on my mantelpiece.
    Sail colour is entirely a matter of personal choice, I have almost the full range across the six fishing boats, I think I like the ‘rust’ colour achieved on Ranger the best, partly because it doesn’t contrast too much with the white seams / thread running across the sail that doesn’t absorb the dye so the overall effect is less striped. IMG_9751.thumb.jpeg.b646005dc8e3de7634afa08310288afb.jpegIMG_9748.thumb.jpeg.069f0727572fec0200bb8b5c165564cd.jpeg
  11. Thanks Andrew,
    Life has been busy and DoK is progressing, albeit at a near glacial rate.
    Fitted the anchor rope, had to enlarge the hawse holes to get the rope through.
    The woodwork on her masts and bowsprit is complete although they still need fittings and woldings added.
    In the meantime I was given Vanguard’s Sherbourne for Christmas which given her small size I’ll probably build between DoK and Speedy.
    Thanks for all the likes, apologies for the slow progress.
    IMG_4011.thumb.jpeg.cc5c3c43e9b2b084a89e859d40f163ac.jpegIMG_4017.thumb.jpeg.9db7720cb03115f57e1aa837e994dcba.jpegIMG_4016.thumb.jpeg.f92dda1752ebf0ecfc81d5da179c5588.jpegIMG_4015.thumb.jpeg.4049daac699a5f0b533fc36560916807.jpeg
  12. Thanks Bob.
    DoK’s hull is now mostly complete and fitted out. All that is remaining are a few eyebolts, chainplates and the outer edge of the channels, belaying pins, and the figurehead’s knight’s head which I’ll leave off until the bowsprit is fitted.
    The deck furniture is pretty straightforward and well designed - as usual for Vanguard and produce a stunning boat. The use of PE to decorate the hull on this kit is hugely impressive.
    My only variance from the instructions has been adding breech ropes to the cannons.
    The biggest challenge for me was the rails on either side of the poop deck. The stanchions are very fragile and part of the same piece of wood as the centre section of the railing. This means that the wood grain runs across the stanchion and they snap really easily. Luckily Chris has already thought of this and provided a spare set of stanchions (kudos to Chris for foreseeing this potential weakness for clumsy builders like me!). Nonetheless, I found it quite fiddly to get all the stanchions fitted and aligned. Not sure that they are, but they’ll have to do.
    IMG_3672.thumb.jpeg.3fafea118617dab7c19440c410036e91.jpegIMG_3676.thumb.jpeg.78a7cd6f8f1b228f2e10160f3805d7eb.jpegIMG_3682.thumb.jpeg.86a5412d4df27711ec7e077dd7ec82ed.jpeg
    Overall, building DoK’s hull has been rewarding and tested my ability a bit further than on previous builds, which is great and what I was looking for. Vanguard classify this as an “experienced” kit compared to Adder and Grecian which are “amateur”. This feels about right even before rigging, she’s certainly a step up in terms of complexity but still exceptionally well designed and very manageable.
    The big challenge ahead for me will be the rigging of my first ship-rigged vessel.
  13. More progress. The main change since last time has been the fitting of the PE decoration which simulates intricate engravings on the model and looks great. I had planned and tried to use the Klear polish method to attach these but it didn’t seem to work, I thought the problem was that my polish had been open over a year since I built Alert and needed it last - but I now understand that the problem was the method I used. For instructions on how to do this properly I refer you to Glenn’s excellent Alert build log. Wish I’d not rushed and realised this before - using CA as I have is inevitably less tidy.
    The copper canopy isn’t permanently fixed to the hull yet. Nor are the cannons.
    DoK’s cannons are Vanguard’s old style of cannon carriage with separate PE capsquares. I didn’t fancy my chances bending these to fit so instead I ordered six new cannon carriages with integrated wooden (similar to those on Grecian, Adder and the newer versions of Alert and Speedy) from Chris. I’ll add breachropes later.
    The acetate in the stern windows does look a touch grubby so I’ve decided to go for the no glass option in the remaining windows. For the two highly decorative windows on the port and starboard quarter I’ve painted the frames inside black so it’s not just a view of MDF frames. IMG_3505.thumb.jpeg.ddc2bd001b6292b25a96ff6e514b97dc.jpeg
    I’ve no idea what it’s called but the “basket” at the bow has been the hardest part of this build so far. IMG_3502.thumb.jpeg.5652e8772eaec23fa806957b2e813656.jpeg
    As for other logs, I’ve had to file the excess on the base and rear of the figurehead to fit. I’ve left the knight’s head off the figurehead for now as there are several reports of the plume being broken off during the build. I’ll add it back just before fitting the bowsprit.IMG_3508.thumb.jpeg.1b74fe7f553e6ca25cc99fac5b08a6d8.jpeg
    The three gratings/ hatches on the main deck are glued in place, as is the spiral staircase aft - this is a superb piece of design by Chris and exceptionally easy to assemble and install.
    Next a few more bits of PE, finish the rudder, add side steps and channels, then more deck fittings.
  14. Progress update.
    IMG_3448.thumb.jpeg.380b406aacfc72c6ea835da48c6897b8.jpegIMG_3445.thumb.jpeg.a07aa9c26a82fcbe5f62148406e3c275.jpeg
    Next the gunwales and side railings. The wood of the side rails, like the outer bulwark was very dark compared to the rest of the kit. IMG_3406.thumb.jpeg.56a812e88d5c07df7156b00a4936ee29.jpeg
    I checked with Chris who explained that with kits with so many different pear sheets such as this it is almost impossible for him to ensure colour consistency across all the sheets - this makes complete sense. He very kindly agreed to let me buy a lighter version of these sheets which I used for the railings and should give more colour continuity between the outside of the hull and inboard.
    The gunwales were fitted first, then the railings soaked and clamped to dry. On the aft of the hull I used elastic bands not clamps. After 48 hours to dry the railings were glued on. IMG_3451.thumb.jpeg.4b231c6a87a3a5f620338a6c9d9edf63.jpegIMG_3453.thumb.jpeg.1db04fa3d955f8a4e64794a2d0624d36.jpeg
    The stern was shaped and the stern board fitted.
    I found fitting the wales quite tricky. I don’t have spreader clamps and resorted to elastic bands to hold the soaked wales in place whilst they dried. The upper wale was fitted first then painted black then glued. To position the lower wale I followed the excellent advice in the instructions and cut a lime plank to 3mm width and used it as a spacer. Elastic bands were needed to hold these in place. IMG_3462.thumb.jpeg.5cc31b4fdef51323e9b6e25d4484a150.jpeg
    Stern decoration was added. The rudder is temporarily fitted but needs to come off to be painted. This kit’s decoration looks amazing and is so clever with the upper area a piece of 3D printed resin that can be soaked in just boiled water and then bent to match the shape of the slightly curved sternboard. I used the AK gold paint that Chris supplies in his Vanguard paint set which looks super. IMG_3467.thumb.jpeg.015e2c95f97afc587296ab05106d4aff.jpeg
    I struggled to find a good solution for glazing the windows. This kit needs something for the stern windows and the aft most windows on each side as there’s no stern cabin in there just structural MDF pieces which I have painted black.
    I tried Krystal Klear to create a film, but it was too lumpy and uneven making the glass look much too thick. In the end I used cut outs of clear acetate sheet which get grubby whilst being fitted and doesn’t look ideal. Any suggestions welcome, I’d like a better glazing solution when I come to build Sphinx 2 or 3 kits in the future (definitely Speedy and likely Harpy first)
    I noticed that at some point I’d damaged the bow area. The spike on the bow (I’m sure it has a name but I don’t know what it is) had lost the outer veneer on both sides. I’d painted over where the damage was as I hadn’t realised that it was damaged. I’ll need to do some simple surgery based on the plans to replace the missing wood on each side. IMG_3472.thumb.jpeg.0466ff2790ffd1406197da1b21a70924.jpeg
  15. I’ve been a bit neglectful of this log of late. My apologies. Not sure I’m adding much on DoK as so many more experienced and better builders have already written excellent logs.
    Started some filler on the lower hull and painted the bulwarks blue and red. These are the colours from the Vanguard paints set. The imperial blue works well, but the red which is intended and ideal for the red inside the bulwarks on warships is too chalky and not rich enough for this decorative colouring.
    IMG_3394.thumb.jpeg.208e47164603dbac40a5098304bd1ad9.jpegIMG_3395.thumb.jpeg.7f3c92128134f0b5883fb14aa4421a34.jpegIMG_3397.thumb.jpeg.4b951aea1353c38a1db8c9f3effc366f.jpeg
    Then started the fill, paint, sand and repeat cycle for the lower hull. Going from this…IMG_3399.thumb.jpeg.ff3cbb7a717212ebbdcf41580fb5e26a.jpeg
    …and this…
    … to many layers later. This.
  16. Inner bulwarks are soaked and clamped to dry. IMG_3281.thumb.jpeg.bf11caa7d3783707f7ec87027af8ef47.jpeg
    I had a bit of a mishap with the engraved deck, entirely my fault. There’s significant tumblehome towards the top of the bulkheads so the deck needs bending to fit. It also needs a little sanding to fit properly, after multiple trial fits the deck split. I tried to fit it with glue and tape over the gap, but the gap reopened and in trying to remove the deck it splintered and broke.
    I emailed Chris to order a replacement - which arrived in the post the following morning - now that’s amazing customer service…. Thanks Chris, hugely appreciated.
    New deck went on carefully and cleanly. IMG_3293.thumb.jpeg.b1e074bd0b3bae67c31e2451d8a4d423.jpegIMG_3294.thumb.jpeg.0077ded9d45664f63d5283f87355e605.jpeg
    The next small challenge was fitting the inner bulwarks. I soaked these as per the instructions and allowed to dry for three days. I wish that I hadn’t soaked them as they now don’t fit the inside of the bulwarks precisely. There’s extra length on the bow end of these that can be removed, but they’re also too tall at bow and their aft end. I couldn’t use pins to align them either as only some holes lined up. Careful sanding of the bottom of the bulwarks and they fit much better. IMG_3295.thumb.jpeg.d8a07bd8b4b42f1b36a3004eac968166.jpegIMG_3297.thumb.jpeg.372c0bfc058e13f1c6c92d463acccfec.jpegIMG_3299.thumb.jpeg.bc816a0c2e9d370434dcbc087d8e1451.jpegIMG_3301.thumb.jpeg.3d31c2fe265746b514cca4c3ab08ee9c.jpeg
    I’ve started filling below the waterline, but still need paint, filling and sanding alternately to get the hull smooth.
  17. Second planking is complete. DoK’s hull is quite forgiving, but not enough that my planking didn’t get a bit messy at the bottom. IMG_3268.thumb.jpeg.26e53c96fbd5a5a5d4dafb1d9c18302d.jpeg
    I’ve added the waterline in the photo below. Everything below that will be painted white and I don’t mind what it looks like so long as I can fill and sand it smooth. IMG_3269.thumb.jpeg.b8d60f361afea6faf72aaf801e4ee500.jpeg
    The stern area was the hardest part, in particular how to terminate the planks against the counter. IMG_3267.thumb.jpeg.d05f2340c4ffc796e72f50f82c9bdccd.jpeg
    Looks neat in the photo but I’ve sanded it too much on the starboard side.
    I’ve put Danish oil on the planks as I usually do and also on the bulwarks. It seems to have stained the wood much darker than usual (Adder’s bulwarks behind in the photo are much lighter after Danish oil). Will need to think if I should have Danish oil on the inner bulwarks. The outer bulwarks are mostly painted so the dark colour doesn’t matter.
  18. Thanks Andrew!
    Next the stern post was assembled and the lower counter soaked and bent around a varnish bottle to achieve the correct shape.
    The counter and stern post were glued in place.
    The outer side patterns were soaked for 90 mins in hot water and then clamped in place. I also put pins through the holes in both side patterns to ensure that they were properly aligned. After being soaked the alignment wasn’t perfect as the peat wood swells in water. I had to leave them clamped and pinned for almost two days to dry out and shrink back to shape. Once done, they were glued too.
    IMG_3180.thumb.jpeg.859a912316a3486b74d71e66fcacc030.jpegIMG_3183.thumb.jpeg.ee96725ef98d20208e7acabd4207ccdb.jpegIMG_3185.thumb.jpeg.d8db140d12ffad49e1f31386c1d4102c.jpegIMG_3187.thumb.jpeg.7b7b5b1300be425c5f4aa7f0165d5b16.jpegIMG_3189.thumb.jpeg.80d35cf1992d5f1065b63aa64adb2ddf.jpeg
    Lastly the outer patterns for the keel and stem were glued in place. First breakage for this kit happened here (must be a record for me, usually I’ve broken loads by now). One of the clamps pinged off and took off a small section of the port outer bow pattern off. I’ve grafted a new piece in place and glued it. Still needs to be sanded to blend in. IMG_3190.thumb.jpeg.e5cf784502439c2af92281c096ae5f94.jpeg
    Onto the second planking.
  19. First planking. Complete on the port side. I know best practice is to do each side evenly for most hulls, but Chris’s bracing of the bulkheads makes the structure so robust that I don’t think that any planking could possibly warp the keel.
    IMG_3068.thumb.jpeg.206135005038a76188a3639dbd310ec0.jpegIMG_3066.thumb.jpeg.e11e556eefc51a013ff3424cfb1cb942.jpeg
    I follow the planking methodology that Chris and James put in their instructions of tapering from the point the plank starts to not run easily along the hull - in this case usually around the second bulkhead.
    i know that the “Chuck” method of planking, measuring at each bulkhead, is far superior, but I have neither the patience to do it, nor the confidence that I can cut an exact taper into each plank. What I do use that Chuck’s superb tutorials taught me is the plank bending method using a jig and iron. IMG_3079.thumb.jpeg.216efce7ffc01eeda83d099870973a72.jpeg
    Starboard side underway. I found easiest on this ship to fit the garboard plank but otherwise plank from the top downwards.
    Hull fully planked before any tidying up. IMG_3084.thumb.jpeg.a5ed4b04d31b5b9a0a5a4d4dcdaab705.jpegIMG_3087.thumb.jpeg.074e48a8cc392ac01e1f9c2f7aa4204b.jpeg
    Whilst it’s warm enough and a rare dry day in Gloucestershire, I gave her an initial sanding down in the garden. IMG_3092.thumb.jpeg.43909690d7e1d0b97885a66727f43e3e.jpegIMG_3096.thumb.jpeg.e916aae22887191b76e1a2e0db3521e9.jpegIMG_3097.thumb.jpeg.c4dbf16e5c89fcbec7eee62158041ea7.jpeg
    Despite appearing quite curvy in the pictures, she hasn’t been a particularly difficult hull to plank which bodes well for the second planking.
    I need to work out how far to trim the planks at the stern back.
