allanyed
Everything posted by allanyed
  1. The attached is Folio 1 from the Steel and SR tables. Note that the SR does not have the 80 gun ship. The anonymous author had some rather disparaging remarks about the sailing qualities of the 80 gun ships and purposely left the dimensions out. Why the 50 gun was not included, I have no idea. Allan Sample 1.pdf
  2. Ben, Yep, for the SR and Steel tables, I used Steel as the default because the scantlings follow the order of construction to great extent whereas SR, well, not so much. Added to the challenge and a lot of time to "coordinate" them. Thanks Joss, I hope you will find it to be useful. Allan
  3. Joss, Further to my last post, keep in mind that Steel has a lot of sizes/rates in his tables, but it does not include some sizes found in the other tables. For example he does not have any information on 100, 90, or 60 gun ships. It all comes down to the size and year of the ship you want to model. I use Steel a lot, but the next model I am contemplating building will be from much earlier in the 18th century, so Steel will be of very little help, if any. Allan
  4. Thank you Joss, your point is quite valid and well taken. Steel was published in 1805. The Shipbuilder's Repository was published in 1788. The Establishments are as noted, 1719 1745 and 1750. This covers nearly 100 years of shipbuilding versus a more narrow time frame with Steel alone. I will post the first folios of each later today so you can see the differences for at least some of the principal dimensions. The dimensional differences carry through the entire sets of tables. They are often close, sometimes, the same, but there are definitely differences throughout. Thanks again for bringing this up, I appreciate the comment. Allan
  5. Bob at Seawatch Publishing posted the news that the book of scantlings is now available to anyone interested. The Seawatch website gives a good bit of detail but I thought it would be a good idea to let anyone interested know a little bit about the book. This is not a novel. If you have trouble getting to sleep at night, it will work better than most drugs to fix that problem. BUT, if you are a model builder, especially scratch builders and kit bashers, there is information all in one place that required a rather extensive and expensive library up until now. Over 200 pages of the book are tables of British Naval ship scantlings and dimensions, including: A.) 1719 and 1745 Establishments and the 1750 modifications to the 1745 Establishment. B.) 1788 Shipbuilder's Repository and Steel's Elements and Practices of Naval Architecture scantlings for ships from 110 guns down to 10 gun brigantine. Merchant vessel scantlings were not included because there just was not enough room. C.) Boat scantlings from Steel D.) Anchor scantlings from Steel E.) Drawings showing many of the items listed in the scantlings. I hope this will turn out to be a helpful source to many of you. Allan
  6. Ian, The names were painted on the ships, some plain, some not so plain. Printing them as described above, on THIN paper stock that is the same color as the counter is a good idea, but you can also make a thin paper template, paint it the same color as the counter, then paint the name. After drying, glue onto the counter. David Antscherl goes into great detail on how to do this in TFFM. Allan
  7. Chuck, I have used thinned acrylics and I do like the results, but I prefer using several coats of India ink. There are no brush marks, it penetrates well and maintains a consistent matte finish. Allan
  8. Ed, Cudos. Ahh, the lowly single edge stiff back razor. A fresh one for scraping deck planks, snipping ends as you show, and then grind a profile in the dulled ones to use as a molding scraper. A rather useful, yet inexpensive little tool for sure. Allan
  9. Hello Newton, Please take a moment to introduce yourself in the new members forum. As the Santa Maria was a Carrack , a possible source for the information you are seeking is Magellan's Victoria replica which was a Spanish Carrack. The replica was built in 1992 in Japan. I have no idea how much similarity there would be nor how accurate the builders of the replica were, but I would guess they studied it intensely and were more accurate than many, kit manufacturers. Allan
  10. Atta Boy Ben! Druxey convinced me to try stiff card stock and illustration board a long time ago. It is cheap and easy to cut into pieces and make into a variety of jig fixtures. Ply works as well of course, but more costly and needs more than scissors to cut. Then again, plywood is likely to last longer for future use. Allan
  11. For the most part, don't make or rig sails if it is not necessary, imho. Even at 1/4 scale, any sewing, be it hand or machine, will more than likely not be to scale and not look good. I have made and rigged sails on several schooners because the client required them otherwise would never have considered it. I used 1200 count Turkish linen sheets. That thread count was as close as I could get to scale, but it does have a sheen to it. It ain't cheap. Two pillow cases gave enough material but was close to US$40, on sale. Our bed sheets are not even close to that quality. If you can find silk span it is thin enough to be to scale at least down to 1/4, maybe smaller. It used to be available in three thicknesses, but I have not seen it readily available since shrink plastic took over the model airplane field quite a few years ago. I did a quick search and it is apparently still out there, if not in the neighborhood model shop as in the past. Allan
  12. First thing that came to my mind is as Nigel and others have posted. Further, some adjacent planks end at the same spot. I don't believe there would ever be two adjacent strakes with butts on the same frame, so this reinforces the idea that this is the builders way of showing off his framing. Allan
  13. Cudos Danny. I do not recall seeing mention of it earlier in your build, but I may have missed it. What materials are you using for trennals, bamboo or something else? Thanks for continuing to share your build. Allan
  14. Ben Are you going to add all the ports as you make and install the frames? I know there are those that do this and do it well. Heck, I have a hard time making them lie in the correct and fair line when marking and cutting them in a finished framed hull. Cutting the notches in the frames for the ledges and lintels is far easier when doing so off the model, but alignment, for me at least, is not at all likely. Overall though, it is coming along very well. I wish the "net" had been around when I did my first few scratch builts and could get the mentoring available at MSW. Allan
  15. Ed The detail you always show is really quite something to behold. Your engineering background certainly shows through in the attention to detail. In your research, were the hanging knees called out as hanging knees or hanging standards as would often be called on the older English ships when the knees were directly under the beams versus fayed to the side of the beams? Are you marking the location of the knee on the side or underside of the beam once the knee is temporarily pinned in place so you can glue it off the model? There is so little room to work, I am curious as to how you are locating the knee to get such a neat fit against the side of the hull especially in that they all have a slight taper to follow the shape hull fore and aft. Your build continues to be a learning experience and fun to watch. As always, thanks for sharing. Allan .
  16. Remco The Fiebings dye was a new one for me. Thanks for sharing that information. Do you or does anyone else on the site have long term experience with it regarding fading or effects from long exposure to sun light, etc? If you posted more on this product earlier, I missed and thus apologize for the question. Thanks again for sharing, your model is terrific. Allan
  17. Ed, All the best complimentary words have been used. This model deserves a newly coined term for exemplary. Keep the pics coming, please. Allan
  18. Gary, The only suggestion I can make regarding the lumber is to get the set for Euryalus from Jeff Hayes at the Hobby Mill. When we did the book and plans and build, it was over several years but I did not keep track of the lumber quantities used. I started with rough cut wood and cut my own stock but if you do not have the tools, the Hobby Mill set is a great way to go. Allan
  19. Ciao Bruno There are a few that I found on the NMM website in the collections section using "24 gun" as the search term. I did not see any of the Pandora. Then again, maybe Pandora was not the same as the others regarding the rabbet. No matter, your model is looking extremely good! Allan
  20. Bruno, I am very sorry, but I am not sure I understand your comment/question. You mention a direct question so please feel free to ask or PM me if you prefer. (If you are in the area of Croatia that speaks Italian, feel free to PM in Italian. Half my coworkers are fluent in Italian.) Allan
  21. Bruno, Your workmanship is beautiful. I do have one question regarding the rabbet on the keel. Should it go all the way to the stern post? Of the few NMM drawings I have seen, it usually stops several stations forward of the stern post. See attached. Sorry these are not super clear. You can find them in the collections section at the National Maritime Museum site for a clearer version. Crescent is from 1779 and Mermaid from 1749. Thanks for sharing your build. Allan
  22. Jabe The three threads are the strands used to make the rope itself. Thread is,,,,, well, it's thread. It does not look like rope except maybe at the tiniest sizes. Allan
  23. Vossy, Whether you use one long strip or in shorter lengths, the width is an issue in that it is supposed to change, especially between the dead flat and the bow. Each plank should narrow as the space for the planks reduces the closer you get to the bow. Look at the cross section at the dead flat and another cross section toward the bow. If you do not do this there will be too many drop planks. The stern has the opposite issue in that the planks often need to get wider, or stealers need to be added. Check out http://modelshipworldforum.com/resources/Framing_and_Planking/plankingprojectbeginners.pdf This should help. Allan
