HIPEXEC
Everything posted by HIPEXEC
  1. Another pre-bent plank just slips on. This pic shows that plank 1 minute after gluing. It's going to get harder now since clamping planks will confined to rubber bands.
  2. You work as fast as Sjors! Looking forward to seeing you in Amsterdam.
  3. The bottom pre-bent veneer strip has just been glued. I'm amazed that it needs very little clamping. The clamps you see in the background are the port side veneer strip being pre-bent
  4. I'm pre-bending the first exterior veneer plank. Most of the exterior planks were pre-bent, so I'll have to do the same to the veneer.
  5. I very carefully planed the excess planks at the cap rail. Now I have to clean up the gunports and sweep ports. I'll continue to improve their finish as time goes by. I now have to start veneer planking the outside.
  6. Both inner gunwals rough finished all the way up. Now I have to carefully trim the whole thing to prepare for the cap rail and outside planks.
  7. Looking good, Sjors. Maybe I'll come and see your beautiful work in person when I'm in Amsterdam on June 2nd and June 17th. We're taking a cruise on Holland America.
  8. First inside course, both sides. Wow...all that patchwork sub-structure ( as per the plans), sure is ugly. I can't wait to cover it all up. Cutting out the tiny sweep ports was tricky since they and the gunports get partially covered during planking.
  9. This is the best "First Build" I've ever seen. You have a great talent for model ship building.
  10. After a tremendous amount of making filler strips and blocks.... and sanding and sanding and sanding to get the gunwals narrowed and smooth....I finally glued on the first piece of inside planking. Now I have a very long road ahead of inside planking, outside veneer planking and deck planking. But this is the stuff of making the model look great when finished.
  11. Inner transom cleaned up a bit. Now I'm cleaning up the inside gunwals so I can plank them. They are composed of dozens of small pieces and parts, so getting them smooth is a chore.
  12. There's nothing like wrestling with pintels and gudgeons to drive you crazy. Rich geons
  13. Welcome. I'll be visiting Brussels and Antwerp this July.
  14. Finished rough planking the inside of the stern. Now I have to clean it up with trimming, etc
  15. Another inside stern plank. This one partially covers gunports which I will trim when glue dries. Rudder hole has been stained
  16. Inside stern planks progressing. The white slash is the rudder port hole and will be stained
  17. I'm pre-bending the stern trim to be installed later. I'm still preparing the inner gunwales to be planked.
