Everything posted by RossR
The quality of your rigging work is incredible. I will be building US Brig Syren soon and I will use your build as the standard I try to achieve. I suspect I won’t quite match your quality, but thank for giving me something to shoot for. great job
- 419 replies
- Victory Models
- Pegasus
Nice job on the planking. Looks great. Definitely worth the time you put into it.
- 332 replies
- Harpy
- Vanguard Models
Thank for sharing all the detailed steps. This is really helpful to us that are still trying to figure out proper planking.
- 241 replies
- Vanguarrd Models
- Harpy
I am considering trying the cotton rope from ropes of scale for the ratlines on one of my current builds. The website says they apply watered down PVA to the rope. Does anyone know if this rope works well with all of the clove hitches needed for the ratlines. I had a hard time getting the clove hitches to hold with polyester rope on a previous build.
I assume what you have are the 2mm x 5mm lime wood strips, If so that seems like a pretty thick addition to the bulwark. Be sure any cap will still cover it. A lot of Occre kits also use some 5mm x 0.6mm sycamore. Not sure if Polaris does, but that might be a better option for the inner bulwarks if you have any.
I used to think I liked adding sails because of the extra rigging details that came with the addition of sails. Seeing the level of detail you are adding with out sails is really eye opening to see what can be done without sails. I have the US Brig Syren on the Shelf, and your rigging has me really excited about that build without sails. Great work and thanks for sharing. Sorry If I missed it in an earlier post, are you using rope supplied with the kit or purchased from Ropes of Scale or Syren or from somewhere else?
- 419 replies
- Victory Models
- Pegasus
I like adding as much rigging detail, but worry my sails cover up much of it or detract from it. Love what you are doing? How are you adding the leech lines, what is the sail end attached to? similarly do you have the bunt lines just drop below the yard the back up through the block to the belay pin?
- 419 replies
- Victory Models
- Pegasus
I don’t have experience with it, but I think Renaissance Wax might be worth looking into.
- 20 replies
- Indefatigable
- copper plates
I mentioned in a previous post that I expected my progress to slow due to busy work life for the next couple months, so no new pictures or progress. I did want to share a follow up to a post I made in a topic related to why we started building models. After the post I thought a little about how I look at the models differently now than I did when I started. I only wanted to build the kit on my first model. It didn't occur to me to consider accuracy of the kit or the level of detail the manufacturer chose to include. I discovered MSW as I was completing that model. Since then I have slowly started thinking more about those details. Particularly scale. I also had an opportunity to acquire a copy of Lees Masting and Rigging of English Ships of War and two of the Anatomy of the ship books, Victory and Constitution. To be honest I am struggling to get much out of Lees book. I feel like I need Masting and Rigging for Dummies first. Lees book is full of great information, but not written for a beginner. Anyway, after the post the other day, I decided to use Lees to figure out what diameter the shrouds should be on my current build. I know Lees book deals with English ships and mine is model is Spanish, but it was more of an exercise in using the book to calculate the should diameter. I did make the assumption that the Mast on the model was an accurate scale representation of the actual diameter of the mast on the real ship. In Lees the diameter of the various lines are calculate as ratios of other lines or ultimately the associated mast. My lower mast was 0.478 inches in diameter. According to Lees the main stay would have a circumference of 1/2 the diameter of the mast. That works out to a diameter of the main stay of 6.85 inches. .478 x 90 (scale of my model) equals 43 inches. Divide that by 2 and you get a circumference of 21.5 inches which equates to a diameter of 6.85. The lower shrouds are then calculated as 6.85 x 0.60 equals 4.11. That divided by my scale of 90 equals a shroud diameter of .0457. As a check on reasonableness I pulled out the Victory Anatomy of the Ship book and checked the lower main shroud diameter of HMS Victory and that is listed as 11 inches in diameter which works out to 3.5 inches. Divided by 90 and I get 0.038. The Santisima Trinidad was slightly larger that the Victory so I would expect a slightly larger line. I may also be basing this on a mast that is not an accurate representation. Either way, I was excited to use Lees and not just have it take up space in my shipyard. I was also excited that I had some 0.045 rope from Syren left over from my Diana, and I am going to use it on this current build. Any way I want to thank everyone on the site that has helped me appreciate the details that can make a model even better that the kit. If you are only interest in building the kit, please know that that is just fine. I think that approach got me started on a hobby I really enjoy . Thanks for reading and being patient with my lack of progress,
- 21 replies
- Santisima Trinidad
- OcCre
Great work. Your rigging is so neat and clean. I hope to come close to what you are producing someday. I like the detail of the wood bands above and below the woldings. This is a detail you don't see added too often, Sorry if you mentioned this in an earlier post, but did you use card stock for that?
- 419 replies
- Victory Models
- Pegasus
I have been making some slow progress on the ship, and I thought I would give a quick update. I have added the fore sail as a furled sail, and all the sails on the main mast with the main sail furled like the fore sail. I still need to add the braces and the sheets and tacks on the fore and main sail. After the stay sails are added I will complete those rigging elements. Next up are the main and mizzen stay sails. Sorry I don’t have more pictures right now.
If you really want to start out with a three masted ship consider Occres HMS Beagle. There have been a few first build build logs that turned out really well of this kit. I didn’t do a build log, but it was my first kit and I was happy with the results. if you want to learn skills to prepare you for something like the USS Constitution, some of the advice from others above might be the way to go.
Thanks. I like the red a lot. I didn’t need to bend anything. When installing the 4x4 pieces on exterior, you need to be sure the gap between each band is wide enough to accommodate the frame for the gun port.
- 21 replies
- OcCre
On my last post I said I would be getting back to my Frigate Diana, but I found myself continuing to work on the Santisima Trinadad. I completed the planking on the exterior of the hull, painted the gun port hatches, added the cap rail and secured the cannons on the top deck. Painting the gun ports was a challenge given their size. They are about 10mm in width. The hinges are slightly wider than 1mm and the rabbet is less than a mm. With my eyesight it was all done under a 3x magnifying glass. In an earlier post I discussed my concern with not pinning the cannons on the lower decks, I ultimately chose not to as I didn't want the cannon barrels protruding before I sanded the exterior of the hull and now I do not have access to pin them. I will do my best to secure them to the deck with some clear PVA glue. The four cannons that are mounted on the upper deck are pinned to help secure them to the deck. Next up is the adding the ladders to each side of the hull. These will be made up of 76 pieces that range in size from 6 to 18 mm in length. My Ultimation tools were a huge help in cutting those small parts to right lengths. I used the chopper on the longer pieces, but on the really small ones I used the Repeater with the sander to get the lengths precise and consistent. Life continues to be busy away from the shipyard, but I will get in to work when I can. I will say again that my intention is to get back to my Frigate Diana, but who knows which model I will feel like working on when I find a little time to work.
- 21 replies
- OcCre
How thick are the blades on those knives? The single bevel ones are interesting.
Occre sent out an email today that said there are only 50 of the limited edition HMS Victory models left. That means that 949 have been sold. Unless I missed it, I don't think we have seen a single build log for this model or the new Artesania Latina version of the Santisima Trinidad. With 949 of the HMS Victory sold, it is hard to believe at least a few weren't purchased by a Model Ship World member. If anyone is building either of these models, please consider starting a build log. I would love to see one of these being built and I suspect there are others that feel the same. If I missed a build log that already exists, I apologize.
