marktiedens
Posts posted by marktiedens
Welcome back! Very nice,as usual.
Marvelous job! I see you have discovered the infamous OcCre rigging plans! I had some of the same issues with the last OcCre kit I did - 2 lines going to 1 pin plus difficulty trying to determine the run of some of the lines. Some were shown actually running from a stay in front of a sail & belaying to a pin behind the sail! I ended up deviating from the plans in places just to make it look halfway believable. Luckily,you only have 1 mast to deal with. Love the lights!
Thanks. This is the fifth hull I`ve coppered,so I`ve had a little practice.
Thanks Mike - The glue actually does ooze out from under the plates. After positioning the plate I blot it with a paper towel to pull off the excess. I do get some smears on the plates,but I use a cloth with some acetate to remove the smears. It smells a bit,but the acetate does soften & remove the smears. Just have to be careful not to use so much that it would get under the plates & loosen them. It also needs to be done in a well ventilated area - besides the smell it is very flammable!
I`ve never seen the longest version for sale in a store. Don`t know if it`s even available on DVD,although I have not actually searched for it. Might do a search on some of the video outlets like Best Buy.
- Edwardkenway, Canute, lmagna and 4 others
- 7
8 minutes ago, mtaylor said:
There's a version of Das Boot that is entirely subtitles. I do remember seeing a lot of war movies prior to my military days. Most.. had errors but usually the story made up for it.
I have the three and a half hour directors cut & it has options for different languages with English captions. Excellent movie! One of the movie channels I used to have showed the full 5 hour version once in a while. Kind of hard to sit through a 5 hour movie,though.
I`ve always liked "The Longest Day". Even though some of the actual events were somewhat stylized or even wrong,I liked how the German characters actually spoke in German - very seldom seen even to this day. I don`t know German language though,so the English captions were nice.
Thanks O.C. & Ernie - much appreciated!
I forgot to mention that the copper plates were glued directly to the bare wood with an odorless medium viscosity CA & are stuck so well that a chisel would be needed to remove them. I have done it this way on other hulls & have never had a copper plate fall off. The only prep I did was to clean the plates with acetone to remove any oily residue.
Thank you very much,Edward.
Thanks Richard. Looks slightly shiny with my bright light on it,but should dull down somewhat in time. The copper on my Victory has dulled down pretty good over time & it has the same copper plates I am using on this.
Hi all - coppering done (except the rudder) Have to do a little shaping of the rudder before coppering it.
- chris watton, md1400cs, Henke and 21 others
- 24
Amati is supposed to be coming out with a Bismarck - pics looked really nice.
All nice looking aircraft - to me,the most menacing looking one I can think of is the F4 Phantom. It just looks so mean & nasty. Built one long ago & it was in a display cabinet at my local hobby shop,but it`s gone now - don`t know where it went.
What I do when I drop a small part is turn the lights out,lay on the floor,& shine a flashlight across the floor. I usually find my part (along with reminding my I need to sweep a little more often). Doesn`t work well,though,if you have carpet.
- Canute, mtaylor, popeye the sailor and 4 others
- 7
Very nicely done - sit back & admire it for a while!
All I can say is WOW - super job! All you guys doing plastic is giving me the itch to do one.
9 hours ago, Old Collingwood said:
Sounds like my earlier kits....
OC.
That`s the only kit I never completed - the fit was so poor that it was more putty than plastic.
- 7
You are doing such a fine job with this kit - the last JoHan kit I tried to build in my youth was so bad I just threw it in the trash! Never bought another one.
- popeye the sailor, lmagna, Egilman and 3 others
- 6
Thanks O.C. - I`m not real good at metal work,so looking forward to making sawdust again.
Greetings - hope everyone is staying safe! Hull coppering is about half done - not much else to do with most stores closed. Still no T.P. or paper products in the stores that are open. &^*%$#*! hoarders. I would have preferred to use Amati plates,but the wind in HMS Visa`s sails is a little too weak for what that would cost. Besides,I had to do something with the 3000 Caldercraft plates I already had. I tried flattening the "nails" in them,but it distorted them too much so I just used them as is. They are not as shiny as the photos indicate - I had a very bright light on them. They have actually started to get a light brown patina on them just from my handling them.
- JeffT, Edwardkenway, egkb and 17 others
- 20
Iron Band at the Heel of Masts
in Masting, rigging and sails
Looks more like a muffler belt to me.
