Posts posted by Richard Griffith
Wow, I toon have a grand daughter named
Isabella~! She also likes to work with me in my shop.
Keep building, and above all, have fun. Duff
Griphos' method also works for me.
I do NOT put CA on fingers because I have glued them together several times which required me to use my scalpel. I guess it works for you, Jim, but it's too dangerous for me...Duff
- BETAQDAVE, mtaylor and thibaultron
- 3
Very nice work, Jorge!
And the cat and daughter are gorgeous...….Duff
- Jorge Diaz O and mtaylor
- 2
Yaymay, it depends on how much detail you want to include.
Suggest you skip the sails as those will double your work effort but not the amount of line.
I don't think 120' will be enough, though. If I recall correctly, the Connie had 10 to 12 different sizes of line, and lots of it. You could rig her with the 3 sizes. As a general rule, use lighter line as you go higher up the masts. The darker lines would be for the standing rigging, lighter for the running lines.
Dave, and Mike, I prefer the torch. It looks like you already have a ceramic block and T pins. Anchor your ring to the block, add solder paste to it, then put tiny pieces of solder in the paste, then put your brass pipe on top. Brace the pipe so it won't move.
Be sure the parts are clean, and you may have to hammer the solder into tiny flat pieces. As soon as the solder melts, remove the heat. Duff
- BETAQDAVE, thibaultron, mtaylor and 2 others
- 5
Azzoun, I am very interested.
We have to watch our finances because our house burned down last May plus I am working on a couple of repair commissions that will give me 'book' money. I expect to finish them early March.
What price would you consider? thx. Duff
very nice work!
I may have missed it-what specie of wood are the wales and how did you make that tight turn under the counter?
I agree with Bob. Never mind that the air brush will be ruined, but your lungs and nervous system will be too.
Controlling the humidity is the best strategy, then replacing the cracked planks should 'solve' the problem.
BTW, Longridge's HMS Victory develop cracks in its hull planking…….. Duff
- Bob Cleek, vossiewulf, druxey and 2 others
- 5
Hey Pieter, brass, bronze and mixed metal were in use at that time, mostly for bolts, bottom protection ('coppering' which was mixed metal), cannon, binnacles and the like. Iron was cheaper and although it would rust, got painted.
Unless you have documentation, paint them dull black. Duff
Chris is 'on the money' with his comments. Potential buyers don't give a hoot about great grandad but you do, and that cannot be priced.
The model is nicely made and shows well. If you MUST sell her, I suggest you seek a professional such as Fiddlers Green in NJ (I have no connection).
As for a box, furniture and appliance stores have large boxes for the asking, Best regards, Duff
welcome aboard, Iliya~!
Good advice above. Yes buy tools only as you REALLY need them. Of course all of my wants are all of my needs............Duff
- mtaylor and pontiachedmark
- 2
Welcome back Tom! And your Portland is beautiful....
love the pun Zack....
Your question covers the waterfront, but here's my 2 centazos.
Start small and cheap. If you were to get everything listed in your post, you would need a second mortgage.
Carbide burrs are adequate for our work, even used ones from your dentist. Dentists must always use new in order have adequate defenses in law suits. So he/she may donate a few to you if you ask.
If you have Harbor Freight or similar in your area, get their $10 packages of diamond and carbide burrs, which have various shapes and start making some dust. You will start to get a feel. Don't rush, you are in learning mode. Buy your next set or type of burrs based on your feel=your new found knowledge.
Comments on the types: When you need to remove A LOT wood, use a round head tungsten carbide, they have real teeth but will set you back $20 each. Buy only when in need. Diamond burrs are good for smoothing as they remove only small amounts of wood. Your new feel will tell you which shapes you like the best. Same for the carbide burrs.
Your homework is to search this forum for other comments, especially Chuck's intro on relief carving.
Best wishes on you quest and please keep us postsed
- Ryland Craze, mtaylor and thibaultron
- 3
Hey Marcus, interesting project! Suggest you dye the cloth and avoid the tea, as the tea has mild acids. Keep up the great work.
- Elijah, Canute, thibaultron and 1 other
- 4
Hey Jim, you're off to a great start~! Duff
- thibaultron and mtaylor
- 2
Licorne 1755 by mtaylor - 3/16" scale - French Frigate - from Hahn plans - Version 2.0 - TERMINATED
Mark, the sentiments expressed above are all valid and cogent. We are rooting for you~!! Duff
