Posts posted by Jasseji
- mtaylor, JeffT and Jorge Diaz O
- 3
Main Wale, 3 strakes out of 4 done, ran out of glue
1.5x5mm Lime - I think it doesnt look that bad, will be Sanded to shape and covered with Walnut Veneer (or maybe Mahagoni even)
Waiting for thinner Lime for rest of hull and internal planking (although i'm tempted to do all internals with Tanganika which is 25% cheaper...)
- knightyo, James H, GrandpaPhil and 1 other
- 4
34 minutes ago, James H said:
Those you marked are actually not a problem, it's the 3 bow frames which would require sanding/filing down to an angle but i tested on scrap Wood and each Time i try to file it, the plywood layers come apart even with a fine nail-file - i dont think it Will matter on the finished ship, it's Just a bad technique
- mtaylor and GrandpaPhil
- 2
so, 1st strake of the main wale is in as a test, i am bending the planks with the wirecutters technique, although i found that the plywood i have for the frames is so brittle, i cant really fair them correctly so i'm left with gaps at the bow between the plank and frame 😕
Also it slighly affects the shape of the bow.
I am waiting now for new wood to be delivered, will have to think about it if i can live with this or try to fix this somehow
6 minutes ago, James H said:
Subscribed to this 🍿
Nooo, not you
Anyway, couldnt resist, frames are removed from the sheets and pre-positioned, the shorter ones are not damaged of course - that's where some of the Gunports go.
Only one frame was damaged but managed to repair
I also ordered AotS Pandora which is a very similar ship, only a bit shorter.
BTW @James H, i can send you guys the DXF files i created for these from the plans - might save someone the trouble if they want to laser-cut and dont know CAD (to include them in the downloads section)
- Jorge Diaz O, mtaylor and Jolley Roger
- 3
- Jorge Diaz O, James H and JpR62
- 3
6 hours ago, puckotred said:
Good, there is a biiig difference between 2 and 3 mm blocks. only 1 mm but it's one third of the size difference!!!
If it's rounded blocks they appear even smaller than the square ones... (But you know all of this.... I'm just pretending being wise 😁)
yes, i believe so, i got the 2mm blocks today, will see what i can come up with (hopefully i'll be able to use same thread)
On 2/9/2018 at 2:24 PM, knightyo said:
I've been trying to order the maple planking from Woodprojectsource for two days now, but keep getting the message that the site is down for maintenance. It's a little like torture! lol. I think I'll draw out a sample planking pattern on the templates, and run it by you guys for your thoughts.
Alan
Alan, what wood did you use for the inside planking (wood type, thickness, width) ?
7 minutes ago, puckotred said:
They are 3 or 4mm dont remember now but Daniel is sending me 2mm to try
16 minutes ago, J Harreld said:
Well, I have yet to build my first in wood, so I'll definitely be starting with a kit! I'd like to find a late 19th Century west-coast steam schooner, but I understand that kits of these either don't exist or would be very difficult to find. I'll keep looking, and working in Lego in the mean time. 🙂
Cheers,
John
hm, did you browse through the MSW ship kit Database ?
Measure her and calculate
There is a rope diameter sheet somewhere on the forums (in the rigging section i think)
usually when you rig a ship, you start with the Bowsprit, then the mast shrouds, next the Stays - the bowsprit needs to be rigged properly first, because the stays are attached to it and it holds the fore-and-aft position of the masts
in your case, you have like 90% of the standing rigging done (shrouds and ratlines) so propably only minor adjustments are needed on the stays and maybe lanyards
If you dont like the color of the ratlines, you can always dye them a bit
Ambitious projects are best
- Pete38, Jorge Diaz O, knightyo and 1 other
- 4
HMB Endeavour by Blacky - OcCre - 1:54 - First wooden ship build
Nice one, keep up the job
