Everything posted by captainbob
Sorry about the pool and wind but it looks like it was a good time. Bob
- 553 replies
- sloop of war
- constellation
(and 3 more)
I like the cockpit. They keep getting better. Bob
- 153 replies
- musongus bay
- sloop
Thanks Lawrence. That’s the great challenge of this hobby, to make the present build better than the last build. Bob
- 420 replies
Just right. There should be extra thickness where the hawse pipe goes through. Bob
- 569 replies
- shenandoah
- corel
Very nice. That's why they refer to these lovely boats as "she". Bob
- 296 replies
- herreshoff
- buzzards bay
Draftsight Question
captainbob replied to alde's topic in CAD and 3D Modelling/Drafting Plans with Software
For many years, I used both AutoCad and SolidWorks when I was working. Now I run DraftSight on a cheap Toshiba laptop with Win7 and have no problems. If you want to continue with DraftSight you should contact their tech support. Bob -
She’s looking fine, John. Nice to see you posting again. Camera? I'd probably take the pictures and then leave the camera at the museum. Bob
- 745 replies
- francis pritt
- mission ship
Congratulations on a job well done. Don’t forget to let us know when you start on the Spanish Armada. I’m unfamiliar with the use on unicorn tears. Bob
- 25 replies
- anchor hoy
- miniature
dentist binocular loupe
captainbob replied to grsjax's topic in Modeling tools and Workshop Equipment
The main thing to watch for is the focal length. Those that I have seen do not focus close enough for me liking. Bob -
James Craig by blueyAU - FINISHED
captainbob replied to blueyAU's topic in - Build logs for subjects built 1851 - 1900
With such a nice start, it must be finished. Bob -
Ah yes, we're begining to see Herreshoff's beautiful lines come to life. Bob
- 296 replies
- herreshoff
- buzzards bay
Yes, I used 91% isopropyl alcohol. The vodka was being used elsewhere. Bob
- 80 replies
- Americas Cup
- Endeavour
Pete, Kieth, I'm with you. I can't wait to see it painted myself. Bob
- 420 replies
Wow, So many responses. Thanks to all of you and to the many “likes”. Right now it is just pushed together. I will be taking all apart and will paint the wood white except for the barrels. The brass parts will stay brass. But I still have a few other items to make before I paint, such as the main cabin and the steering box. Bob
- 420 replies
Floyd, as it says in Per’s entry, there are different types of resins. There are some that will always be sticky even after curing to give them that necessary bond to the next layer. There are others that set up smooth and shiny such as some resin covered tables you see in diners. It will be best to ask the sales person at the hobby shop. What I used looked like the two bottles at the Hobby Town sight but was labeled “Casting Resin”. It had a shiny surface when it set. The only sanding required was to correct application errors. Wet sanding was best after 4 or 5 days of curing. Bob
- 80 replies
- Americas Cup
- Endeavour
When you mix the "epoxy resin" it will be thick as the West Marine stuff. That is why I mix alcohol with it, to thin it out. That way it flows like paint. As for filling gaps it all depends on how large the gap is. Epoxies and resins are a glue, by definition, and like thin or thick CA the thicker the epoxy the larger gap it will fill. You might want to mix a small batch to see how it acts. Like paint it won't take much to cover a large area. Bob
- 80 replies
- Americas Cup
- Endeavour
Floyd, Epoxy and resin are both two part plastics that set-up and get hard. The names get confused all the time. This is what I used. Devon epoxy (Note the bottle says epoxy resin.) It is a 1:1 mixture and it does not smell as bad. Which is why I used it. I would mix a batch and then add an equal amount of alcohol to thin it to almost a water consistency. The alcohol does not change the set-up time. I would paint it on the bare wood with a brush but I heard of some who would spray it. Use a cheap brush and throw it away. Clean-up is best with acetone. The thinned mixture soaks into the wood and makes it harder. Paint it on and leave it until it dries. If you go back to touch up a spot and it is starting to set it will be gummy and mess up the finish. Bob
- 80 replies
- Americas Cup
- Endeavour
