Everything posted by wefalck
How to seize a block to an iron band
wefalck replied to Laggard's topic in Masting, rigging and sails
Perhaps getting some proper 'model rope' will help. These are somewhat stiffer and keep in shape - apart from looking like the real thing. There are European sources (e.g. Morope) or from 'Chuck' here on the forum, if you are in Northamerica. -
The point is to be cautious with 'sources' and to understand that for certain questions there are not definitive answers, but only probabilities ... it is a good idea to understand this as early as possible in order not to run into unresolvable issues. -
Almost certainly no specific ones, as this was an artisanal job for the shipyard and to be maintained on board a ship. -
Gregory, have a look at how the hooks are put into the eye-bolts. They are the wrong way around. This gives the impression that the rigg has been restored at some point. Ooops ... posted this at the same time as you, Allen. -
Historical insight determines what needs to be done - not convenience ... -
I would recommend to ignore instructions in kits - sometimes they are good, sometimes they are bad, but in most cases they provide simple solutions that are often far from what the real thing would have looked like. The guys of old knew what they were doing and their methods have been tested and refined over the centuries. So, within the limits of materials availability and your own capabilities, it is always a good idea to follow prototype practice as closely as possible. Perhaps also a word of clarification: 'seizing' means to attach something with a thin rope, similar to sewing. This is not normally done with blocks at all ! What you are interested in is 'stropping', which consists of making a loop of rope and putting it closely around items such as blocks or also spars. These strops are usually tightened with the help of 'seizing', but the seizings go around the rope, not around blocks or spars. I am not an expert on 18th century rigging, but have the strong feeling that the kit instructions are not quite correct. The masts on such 'long-boats' are rigged only temporarily and were easy to strike. In the 18th century wrought-iron bands with eye-bolts were not very commong and I would not expect such fitting on a relatively thin mast as that of the long-boat. It would have been more likely that the mast was provided with shoulders at the locations, where the standing rigging would attach and where any blocks would attach. A spliced strop would fit tighly around the mast and block forming a figure of eight, being tied down in the middle with a seizing. It is quite easy to form such strops from rigging thread (or better real 'rope') using a fake splice, i.e. pushing the ends through each other with the help of a sewing needle. The fake splice then is secured with a drop of varnish. With a much thinner thread you tie the strop to a figure of eight going around the block and the mast. The whole thing then is secured again with a drop of varnish. Such an arrangement would also prevent the eye sticking too far out as in the kit instructions. -
Normally, if you have an iron band around a spar it would have one or more eyebolt attached to it (the method depends on the period). Blocks stropped with a rope would have an eye formed with that rope. This eye would be formed around a metal cringle which goes through the eye of a hook. This hook would be hooked into the eyebolt on the mast and the hook is secured with a 'musing', which is twine wound around the neck of the hook and its tip (which slightly bent up to prevent the twine from slipping). In the second half of the 19th century the hook would be replaced by a shackle (this only became an option once threads had been standardised). At the same time (internal) iron stropped appeared, which also would be attached with shackles. -
I am fixing things such as the hanks and knots with a dab of solvent-based varnish. A drop of solvent allows you soften this, if you need to move the part. As to the serving machine: - you could add wooden stay at the top to keep the sides spread and/or - use a kind of serving mallet, i.e. a short piece of brass tube to fit over the rope to which a 'handle' is hard-soldered; cut/grind away about half of the tube opposite the handle; the serving yarn is wound a couple of time around the handle for friction - this device allows you to keep the tension on the serving yarn, while not pulling on the rope to be served - there are other somewhat more sophisticated version her on the forum, check out e.g. 'archjofo's' log.
What are 'turbo' carvers ? Any picture or link ?
Lancia Assunta by maurino
wefalck replied to maurino's topic in - Build logs for subjects built 1901 - Present Day
Looking at the sail, I am wondering, why you have both ends of the reefing points at the same side of the sail ? Was this indicated so in the kit instructions ? Normally, they would go from one side to another, secured in the middle by a kind of not and or sewn onto the sail on one side. Below is an image of a slightly larger boat type (also with painted sails) from the lagoon in Venice in the Naval Museum there: -
Thinning Paint
wefalck replied to Ed Gibbons's topic in Painting, finishing and weathering products and techniques
Enamel as on pots is something different from 'enamels' as in paints ... Enamel as on pots is a layer of glass. It is applied as a layer of a glass-powder mixed with some flux on the bare metal, which is then heated in a furnace to the melting temperature of the glass. A technique thousands of years old. I believe 'enamels' as in paints are named so because they form a hard and smooth layer resembling real enamel. -
Re. the bottom of the archipelago ... I am a geologist, after all, who studied in Kiel I tried small paint rollers on paper sails, but it does not work very well, as it leaves a slightly rough surface - foam is better than fleece. However, spray-painting is the best solution. At the beginning I used the frame-method or suspended the paper from its corners. Today, I cover a piece of cardboard with clingfilm and lighly tape the paper onto this - make sure to not wet the paper too much, as then the back will not look nice, with paint accumulating at certain points due to capillary effects. In this way I also make 'built' sails, i.e. sails composed of individual paper strips to simulate the cloths and doublings.
I gather the bottom of the archipelago would be glacial till with a lot of pebbles of various sizes on the surface, so a grapnel would be a good choice.
Help from German speaking readers needed…
wefalck replied to Waldemar's topic in Nautical/Naval History
Although a native German speaker, I did not chip in before, as I had some difficulties deciphering the script. I think the final 'free' translation is pretty good. Was there a ship in the fleet of question by the the ARCA NOË ? I have difficulty reading the last three(?) words in the first sentence: ullb (or ulls?) auff der Lersnusa(?). One would need to compare the letters with others in the document that can be clearly identified by the context. It was (and I used this for a time myself as well) to distinguish in handwriting 'n' from 'u' by putting a hook over it: Ŭ. What you interpreted, at least at the beginning as 'tb', the symbol that looks a bit like a 'w' with a curl through it is the old abreviation for 'libra' = lb = pound. I am not so terribly well educated in the details of German language history, but there has been a transition sometime between the 17th and 18th century from 'scheißen' (or scheiszen or scheissen) to 'schießen', i.e. the meaning of to shoot separated from to ****. The verb 'zerspringen' (or only springen) was used to describe to burst or to explode, depending on the context up to the end of the 19th century in the context of artillery, a grenade 'zerspringt' (past tense 'zersprang') while today we would say it 'explodiert'. The same for a gun barrel. Today we would rather say 'bersten'. Neither of German, Dutch, Swedish or Danish, was very standardised (perhaps German the least) as to the spelling and also the vocalisation (which still does vary in modern spoken German depending on where in the country the speaker originated from) in the 17th century. So one can observe variations even within the same text. Somehow the text reads as if there was some Swedish or Danish influence. It is correct that gun-metal is more ductile than cast iron, but I would still use the term to burst, rather than to split, because the failure was usually due to casting failures (foreign substance in the metal, untempered stresses from the casting process, micro-fissures due uneven cooling, etc.) that could go undetected (there was no ultrasonic or radiographic testing at that time ) by inspecting the barrels by hammering at it. Such failures would result in fragmentation as for cast iron barrels. -
Kevin, at that time either oil-based paints or (shellac) lacquer based paints and varnishes would have been available. Oil-paints, when new can be quite glossy, but it also depends on the pigments and other accessories used in the paint formulation. When exposed to the wheather, it would dull. Oil-paints remain a bit elastic, so would be well suited to paint structures such as coaches. Shellac-based paints, being harder, could be polished to a very high gloss, but would be more prone to cracking. Colourless shellac varnishes of wood can be polished to your wishes, between satin and high gloss, and would be quite tough. On the other hand they are not really weather resistant. I think the wood-work would have been either painted with an lineseed oil-based paint, or be treated just with lineseed oil.
Talking about paint-schemes: over here in continental Europe I think by the early 19th century most stage-coach services were state-run in one way or another, with inns being sort of franchises. The coaches were mostly painted yellow with black iron-work and lining. Also leather-work including roofs, boot covers, etc. was black.
I gather, such questions are difficult to answer, which is why no-one chipped in so far. Internally strapped blocks require the manufacture of rolled iron-bars and the possibility to drill accurate and matched holes for the axle. This kind of manufacturing technology only became available around the second quarter of the 19th century. That should give you a time frame. This kind of marine technology diffused quickly around the world and was adopted, where the respective manufacturing technology was available together with the necessary raw materials.
Actually the same techniques can be applied to wood, metal, and plastics. I prefer metal or acrylic glass for small parts over wood, as I then don't have to worry about the wood-grain. If you need to have the parts look like wood, it is quite easy to simulate this with paint. I have, for instance, milled the cleat-shape from a suitable rectangular brass profile and then sliced off individual cleats. If you let a spigot protruding from the foot of the cleat, you have something to hold it in a pin-vice for further shaping operations and, of course, for mounting it later on. The same technique works for acrylic-glass, which is easier to shape, but more brittle than brass.
Idea : Printing fabric sails using heat transfer paper
wefalck replied to modeller_masa's topic in Masting, rigging and sails
Allen et al., this is the heat-activated paper repair I talked about: https://www.neschen.de/en/product/filmoplast-r-2/#pdetails. Not sure about the availability outside Europe, but I am sure there are equivalent products, as all around the globe paper- and book-restorers face the same challenges. The prices are not Chinese supermarket prices, but a roll 50 m long and 20 mm wide will probably get me through all the models I am likely to build in the next three decades, before I am getting too old and tatty for this. -
I have been tossing around the idea of using ink-jet or (colour) laser printed for a couple of decades or so. The biggest issue is the light-fastness of the pigments they use. There are various studies on the Internet, where people used (accelerated) test on different combinations of inks/toners and papers. Very few really hold on over more than a few years. Reds are notorious for their fading. So my conclusion was to stay away from home-printed parts. OK, there may have come new inks/toners onto the market since I did my survey, so I may be wrong .... I have used, however, b/w printing to give me the layout, which I then painted in acrylics, say for flags. We had the discussion on sail materials several times in recent years here. I fully agree with Allen, that cloth in most instances is not a suitable base for scale sails except at very large scales. Paper can be at least an order of magnitude thinner than the thinnest woven fabric. The problem with many papers is that their wet tear-resistance can be rather low. A friend of mine started experimenting with a special paper as used by book- and paper-restorers. This is a long-fibred rice-paper coated on one side with a heat-activated acrylic glue. When applied onto a sheet of paper, it is almost invisible. My friend made three-ply sails with this special paper on the outside and a core of thin silk-paper in the middle. In this way, he achieved three things: the sail has a reasonably good wet tear-resistance to be shaped, painted and handled, it is translucent, if only thin washes of acrylics or inks are used, and by cutting the outer layers into strips of the scale-width of the sail-cloths, the seams are reproduced to near scale thickness. I have not tried this myself yet, but it seems to produce quite impressive results for set sails. I have to make some trials, to see how it works for gathered or brailed-up sails. -
Iteresting trials, indeed. The importance of the colour of the primer reduces as one increases the thickness of the paint layers, but this will also depend on the pigments in the paints. For 'gilding' another option might be 'gold' leaf (e.g. https://www.amazon.co.uk/Imitation-Metallic-Handicrafts-Decoration-Furniture/dp/B0924GTH3P/ref=sr_1_7?crid=1CR56NNXM68RG&dchild=1&keywords=krylon+foil+metallic+gold&qid=1628411413&sprefix=Krylon+Foil%2Caps%2C654&sr=8-7). At this price it is not real gold, but brass hammered out very thinly. Most of it comes from China these days. Got a booklet like this, but did not yet around to try it out. Being brass, it probably needs a protective varnish, such as used to protect brass- and silver-ware. The gold-leafe is applied on a slightly tacky lacquer and then burnished with a steel or agate burnisher (the latter one can get from craft shops that cater for porcelain painters). I am not sure that I would have used primer at all on the white-metal parts. I would probably burnish them and then apply the paint directly. Primers contain pigment/fillers and these always roughen the surfaces compared to burnished metal. That is ok for coloured surfaces, where you want the the paint to key into the primer, but for 'metal' surfaces, the surface roughness of burnished metal would be the best you can get.
These cooking stoves were in reality quite complex pieces of engineering, that were also designed to minimise the risks from handling open fire in an environment tremendously susceptible to fire-hazards. Well done !
