Everything posted by Mike Y
Started turning rough "resawed" willow planks into thin straight planks suitable for the display case floor. That worked fairly well with a straight thick pine plank as a planing sled, and a double sided sticky tape to hold them. Some planks had some holes, look like insect holes: Then this piece cracked around those holes, exposing some disgusting internals: I do not want this organic stuff anywhere close the model, so cut this off quickly Overall it was a lot of sawdust and chips The target plank thickness is 2mm, so I guess more than a half of the log was turned into sawdust and cutoffs. Still not very bad
- 968 replies
- hahn
- oliver cromwell
I was thinking about this idea, scribing the joints to make them a bit visible. On this model, this approach is taken to extreme: Will try something like this on my wales, but very subtle. Though it will require some practice - glue and wood grain will make it hard to make a clear line. Maybe just scraping the wale part with a blade or chisel before the glue-up will work better.
Please please please share your finish technique! Each photo is an eye candy for perfectionists! Everything is aligned, no gaps, clear joints, brilliant!
Was worried about painting such a nice wheel over, but your "painting" ended up very nice!
Very nice, and it is built so quick! Do you have a photos showing the entire model?
- 28 replies
- bellerophon
- 74 gun
Thanks everybody for the support! That really helped It is proportional to the hull, but the biggest element on the entire wall, look out of scale comparing to shelves, TV, etc. So the conclusion is simple - I need to upgrade to a bigger wall (in a bigger apartment), this one is getting too small for the model. Bigger TV is also an option, but we are watching it so rarely (like 10 hours per year) that spending lots of money on a big screen does not sound exciting.. Also, I booked a part of the case into the "kid" account - Daria's model will be in the same case, thus saving space by avoiding a second case. Carl, all the bright parts of the case will disappear - instead of staining, it would be planked with our self-milled willow and I will add a pear "skirt" around it below the glass. That is coming relatively soon, but with all upcoming business trips - probably will take a month.
- 968 replies
- hahn
- oliver cromwell
Good news: no problem with the base weight, it holds well. Even with 2 bolts instead of 4 (one - the nylon plug is too loose for this kind of concrete, second bolt - the hole is probably not deep/wide enough, can't drive it through in the last 2-3mm). I have a lot to learn when it comes to anchoring / bolting things to concrete wall. To make it funnier, apparently the left two bolts are in some really hard concrete, while the right are in a porous concrete that falls out of the hole. The base is bolted like so: Bad news: it does look too bulky, I should have made it thinner, so it does not stick so far from the wall Maybe I will get used to it, maybe it will look better once planked, but it is out or proportions in this place. My wife laughs and says "ha ha, ok, I am ok with it", but I am not happy myself. It looks like a clunky aquarium. Will finish it and see how it looks. Next time - such things definitely need some fullsize cardboard mockup, it is really hard to visualise and imagine it even after laying out all dimensions on the wall.
- 968 replies
- hahn
- oliver cromwell
Hmm, that is an interesting idea, haven't thought about it. Will definitely use it next time, thanks!
- 968 replies
- hahn
- oliver cromwell
Hooray, the glue-up is completed, and it ended up ok. Even thought it was a stressful time race against silicone and epoxy, trying to make sure nothing falls apart, avoiding smearing adhesives all over the place, while trying to hold it together with swears and load bearing masking tape Overall the design is really super light, the case weight without the base is just 6kg (2.4kg for the front glass and the rest is 3.6kg). Most of that weight is plexiglass, I would be surprised if all that pear sticks combined weigh more then a 0.7-0.8kg. The corners have some slight gaps, that should be far less visible once sanded. The pre-finishing was done mostly for the areas that are hard to reach, but all exposed flat surfaces would be sanded/scraped to be perfectly flush, and then re-oiled. Will do it once the case is mounted - without anything in the back, it wiggles without the front glass. When mounted, top corners would be attached to the wall with recessed brackets that were prepared in advance: With the glass attached, a bit of scraping is required to ensure gapless fit: Here is how the glass connects to the case, basically lots of magnets and a boxwood strip that locks the top side with the glass, preventing sagging: LED strips as seen from the inside. Sorry for the photo quality, but the strips are in recesses, should not be visible for the observer. Now the case is in the corner, hiding from the Admiral Just a few things left: 1) Mount the base on the wall, if it is too heavy - remake it from a thinner plywood. 2) A bit of planing to ensure good fit to the wall 3) Plank the case "floor" 4) Glue the case to the base 5) Add a decorative pear skirt to hide the base 6) Sand everything flush, re-oiling 7) Connect the wiring, install the light switch and the dimmer.
- 968 replies
- hahn
- oliver cromwell
Thanks for the nice comments! Kurt, Carl, wife and kid are on vacation, so no problems with that They are coming back tomorrow, I made it before the deadline! Pat, thanks for the warning! Though I do not have any "painter masking tape" touching the glass, it is a protective film that the glass was shipped with. So I guess it should be ok to keep it on the glass a bit longer. No problems with sticking or breaking when I peeled it from the edges. Kurt, youtube and MSW are the only sources. Without a possibility to have a real workshop, the only thing I left with is to subscribe for a dozen of good woodworkers on youtube and watch it before going to sleep. And, actually, quite a lot of good advices are here on MSW, even though it is not officially a "woodworking forum"
- 968 replies
- hahn
- oliver cromwell
HMS Naiad 1797 by albert - FINISHED - 1/48
Mike Y replied to albert's topic in - Build logs for subjects built 1751 - 1800
Ooooh! Is it CNC cut or hand carved? Never saw such a smooth carving in this scale! Any chance to see this model in person in Rochefort, October 2018? -
Back from the holidays, finishing the case. The riskiest part - final assembly and glueup. This design is really not good when it comes to assembly and overall stability - each individual part is thin and bends easily, but once all parts are glued together - it should be strong enough for the purpose. I hope Though three-way miters of this size are not super strong either. I am using a good epoxy (West Systems), pre-soaking endgrain with freshly mixed epoxy, and then using a gel-consistency epoxy 10min later for the final glue joint. It works well on test pieces. Since there is no straight point of reference - straightedge is necessary every time. Using A3 drawing paper as a square (checked it for distortion first): Holding parts together is tricky, need to avoid bumping into those chairs Last minute adjustments - forgot to add a hole for the top strip wiring: Phew, now epoxy & silicone gel cures, and I hope there is a beauty under this masked mess: Looking through the eyes of a sailor, who would get locked in here Aaaaand a moment of truth is scheduled for tomorrow evening - all masking tape would be removed (except glass protecting film, I will keep it until the very end), hope it is not a failure. Fingers crossed!
- 968 replies
- hahn
- oliver cromwell
Nice build! Hope you will have more luck with thin planking strips included in the kit, it is actually easier to build with a boxwood package - thicker strips that bend more evenly with more margin for fairing.
- 90 replies
- english pinnace
- Finished
question for sketchup users
Mike Y replied to hamilton's topic in CAD and 3D Modelling/Drafting Plans with Software
Fantastic guide, thank you! -
Hi Kurt, Yes, magnets are small enough - I ordered a number of them in different sizes, they are quite capable. In this case, they do not even need a lot of force - just enough to prevent the model from tipping on a side. I apologise for this super ugly touchpad-drawn sketch, but it shows a cross-section of a model, somewhere in the aft section of it. The false keel rests on a slippers, and magnets (red circles) connect together the launching cradle and the hull. Magnets are glued under the planking, so they will have 1.0-1.5mm of wood between them, but this should be good enough. The model rests in equilibrium position, there is very little force to tip it over. And multiple magnets could be installed, there is enough point of contact between the hull and the launching cradle. It should be also very simple to remove the hull from that cradle, at the same time the cradle is barely visible. I am not a fan of screwing a model to pedestals (semi-permanently). I haven't seen it anywhere, but probably some modeller somewhere might have done it. Sound pretty straightforward, and if the idea is a failure - I can always switch to a traditional symmetrical cradle, that supports the hull from both sides. The magnet would be still in the hull, hidden inside it, should not cause any problems later on. Thanks all for the nice feedback! Merry Christmas! Sailor, "poppets" are the vertical timbers, or it is another name for the launching cradle?
- 968 replies
- hahn
- oliver cromwell
Greg, thanks! I am travelling now, and it is really hard to remember all that without peeking into the TFFM book every time There is a great shipyard diorama in the same Hamburg museum, which includes various supporting structures used when building the ship. Really worth a visit, if you will ever end up in Hamburg. There are 9 floors in the museum, where few of them are filled with models!
- 968 replies
- hahn
- oliver cromwell
Yes, Master Korabel kits are basically unknown outside of ex-USSR countries. They are not really trying to market it internationally, there is even no english website, nobody knows about these kits. At the same time, I think they are perfect for beginners. For that price, you can only buy some Artesania Latina kits, and the quality difference is dramatic. This one is a pleasure to build, while AL was a constant struggle (I had AL San Francisco 2). Like trying to bend thick walnut planks vs just gluing in thin pre-cut and pre-shaped veneers. Day and night! With AL, I am not sure that creators of the kit were even trying to build it according to the instructions. Here it is clear that the designer spent enough time to make sure that parts really fit together. And don't even get me started on quality of wood (pear and ebony in $100 kit!) and fittings. They are really good, brass and photo etch instead of cheap castings. Also, it seems to be really authentic design, not a copycat of some other kit in the market.
Kurt, for the next few years it would be still in the building jig, at least until I plank it and install some deck framing. Too risky to remove until then, the hull will get skewed and frames will go out of alignment. When in the jig, the keel is hanging in the air, and the hull is fixed in place by gluing frame tops to the jig. For example, you can see it on this photo: https://modelshipworld.com/index.php?/topic/7297-oliver-cromwell-by-mike-y-148-1777-pof-hahn-style/&do=findComment&comment=436953 But if we just speculate and throw ideas around - I was thinking about a small building slip, like it was in real shipyards (wooden blocks and slippers under the keel). And a tiny supporting structure (not sure what is the name of it) on the planked side of the hull, that follows the shape of the hull underside. No supports on the bare-frames side. To make it work and avoid tipping over, planned to use magnets - one glued in between the frames, hidden under the planking, another is embedded into the supporting structure. Here is an example from the maritime museum in Hamburg. With magnets, there should be enough support even without these tall vertical timbers that "hug" the entire hull. This is just a plan so far, but since magnets will be totally invisible - I will glue them in strategic places just in case, maybe they will become useful later. Magnet mount will also make it very easy to get the model out of the case, which necessary to show the model where two sides are very different (I will leave one side fully bare, and one side fully planked).
- 968 replies
- hahn
- oliver cromwell
