Everything posted by glbarlow
Vanguard MDF
glbarlow replied to hornet's topic in Building, Framing, Planking and plating a ships hull and deck
Never had a problem. It’s much easier to work with than the old fashion easily splintered ply material. So I’m thinking you’re a klutz:-) There are many posts on this topicin years past, mostly it seemed to me people resisting change had a bigger problem than anything related to the material. Some cheaper models may use a lower grade quality of MDF, that’s certainly not the case with any Vanguard model. More significantly the is no way Chris could create his modern interlocking designs with ply, there would be shattering and splinters everywhere. -
Winchelsea is a tremendous model that took me 3 years of working almost daily the entire time. It took skills I learned over the 12 models I built before it and new skills I learned along the way. Personally I’d recommend doing any of the Vanguard naval ships first and if you’re ready to test yourself further I’d start with Chuck’s Cheerful, a model I fully enjoyed building and led me directly to Winchelsea. I doubt Trussben or others that have built it would say it was easy, the fun is in the challenge. That’s not to say anyone couldn’t start with Winchelsea, in my case it was more fun because I’d built the others first. Chuck’s designs are well thought out, the parts are detailed, and his instructions clear. His support along the way is unparalleled. Undoubtedly it’s my best model. All that said, I’d read through multiple logs, get some experience under your belt, and decide then.
Brings back memories. Seems like you have it well in hand, it is essential that all the framing is accurate. This is especially true of the stern and gallery framing, there are some tight tolerances ahead in future chapters, this framing is what makes it work. I noted you use cut outs of the plans on the bow, I encourage you to do so on the stern, both the transom and in particular the galleries. You’ll see this done in other build logs. So many times I was thankful I’d worked and reworked this infrastructure, the cutouts were infinitely helpful.
I should have mentioned the ones from Model Expo often seem like they come out of the discarded bin. Brass takes me back to my military days, the slightest tarnish wasn’t tolerated. I used Brasso and a soft cloth to quickly and easily bring back the bright color that’s always there somewhere. Nice work with the turning and filing, the model and stand integrate perfectly. I've used that wood base on all my models other than Winchelsea, I never had one arrived stained, glad it’s a color you like. Now I recommend adding a small engraved brass plate, I include model name, my name and the month/year I completed it (so when I’m old I’ll remember it was me that built it😂🤣 You’ve build a great version of Cheerful, really excellent work.
The included rigging are very simplistic and underdone. I found this book very useful, and specifics to fore and aft craft including cutters. It isn’t overly difficult and does help spice up the model. Plus good learning exercise. Rigging: Fore and Aft Craft. Lennarth Petersson. I found it on Amazon.
- 80 replies
- Lady Nelson
- Amati
You’re doing quite well with your first model. The breaching lines are enough for such a small model, the effect is there. I’d encourage you to make your own eyelets and ring bolts using the 24 gauge wire (what you have is correct). The result is such an improvement over commercial versions. I made hundreds for Cheerful and Winchelsea, in one way it’s tedious and another therapeutic and in all ways a skill worth learning. I attempt to describe the process in my logs. Give it a try, you’ll start by making 10 to keep 5, but production improves with practice.
- 80 replies
- Lady Nelson
- Amati
Question re "Line Off"
glbarlow replied to JohnWW's topic in Building, Framing, Planking and plating a ships hull and deck
Typically the first marking is with a wider plank, I’ve never had this as an issue. -
Absolutely, it is good practice. lining off is tedious but the results is worth it. It applies to any and all wood model ship hulls. Nothing detrimental or any impact at all on the rest of the model. Kit instructions would never cover anything of this detail and seldom offer any help at all on planking. -
Best Marine Salvage Airbags for Lifting Sunken Vessels?
glbarlow replied to wildtmpckjzg's topic in Nautical/Naval History
That’s a rally big model ship….which is what this forum is for I thought. -
The two sides at once is a good idea, after coppering one side of Vanguard I stopped modelling for three years in avoidance of doing the other side. Haven’t coppered anything since. I like the square tuck. Probably like you I’ve been fascinated by them ever since Cheerful.
- 332 replies
- Harpy
- Vanguard Models
