Everything posted by druxey
And looking good as well, Michael!
This is the wonderful part of a community like MSW; folk helping each other out. Kudos to Henry!
- 740 replies
- Tudor
- restoration
(and 4 more)
When you fair the frames (sand gently!) it should take care of things.
- 61 replies
- Lowell Grand Banks Dory
- Model Shipways
I've used limewood in the past. It is very nice to work and carves well. (Grinling Gibbons' work was mainly in lime.) I found it a little soft, so one has to work carefully in order not to accidentally mark or dent it. It's certainly a little harder than basswood, a close cousin. Try it: I think you'll like it.
Welcome to another Ontarian. Check out the Marine Modelers of Niagara club site for monthly Zoom meetings.
To correct, only dampen the concave side; in this case it's the bottom surface and clamp across. The wood fibers that side will expand.
- 61 replies
- Model Shipways
It seems that the suggestion of making the angles of the outer aft edges the same will at least simplify the problem considerably. Do I understand the right side drawing to be plan view from above, or are the deck levels different on each side?
- 2,699 replies
- heller
- soleil royal
(and 9 more)
A fascinating exercise in developing the optimal solution, Michael! Thanks for sharing this series of experiments.
Lovely progress. The edges of forecastle and quarter deck had the plan ends butted into the recess along a beam of larger scantling as you surmised. Shipwrights tried never to have exposed end-grain that would absorb moisture and then rot. In addition a very slight lip along the upper edge of the beam would act as a spurnwater to direct water to the outboard edges of the deck.
- 2,699 replies
- heller
- soleil royal
(and 9 more)
That is correct for British ships at that time period, HH.
- 889 replies
Yes, HH. The area where the gun carriage trucks traversed were done in 'top and butt' and of oak, not deal.
- 889 replies
That's one nice way to show the underlying structures.
- 889 replies
Mooselookmeguntic? More like 'Moose look gigantic'! Either way, this subject looks interesting.
Is the material the deadeyes are made from really suitable at that size and scale? How frustrating for you.
- 740 replies
- Tudor
- restoration
(and 4 more)
Superb as usual, Valeriy. I've found model-making a good way of reducing stress. Heartfelt best wishes in these uncertain days.
Very nice and methodical!
- 61 replies
- Model Shipways
Whew! A lengthy procedure rather, I suspect. like walking a high wire. Glad you didn't fall off! Terrific result.
Those furled sails look as good as any I've seen. Nice work.
- 3,560 replies
- clipper
- hull model
Echo by tlevine - FINISHED - Cross-Section
druxey replied to tlevine's topic in - Build logs for subjects built 1751 - 1800
Looking good, Toni!- 52 replies
