druxey
Everything posted by druxey
  1. You can dissolve white glue and acrylic medium with rubbing alcohol.
  2. A little spot of dilute white glue or acrylic matt medium will secure the hanks for you.
  3. I've never seen upper stern framing constructed off the model before; an interesting approach! Lovely work, as usual.
  4. Welcome, Jared. Check out Model Shipwrights of Niagara if you are near this end of the province. Check it out anyway!
  5. If you haven't carved one before, it's a very respectable result for such a complex figure. Well done, Alan.
  6. Oh, Chris! You didn't cut around the thwarts? What would the late, great Danny have to say? Here's to Dan!
  7. Is there evidence for the layout of the planking butts as you've drawn them? I'm just curious. The new shape of the hull with higher rise fore and aft looks very convincing now.
  8. Congratulations on opening, Ben. I note that you are Toronto based, so this should be of interest to Canadian builders in particular!
  9. I'm glad that you've come to that conclusion, Pat. I don't think you'll regret it. After all, if the original material for the hull were oak, would you really be impelled to use oak for a scale model? Obviously not.
  10. Look at the photo in Step 49, and you'll see that the line hitches around itself on the top of the spar before moving over to the next hole. (The instruction describes this as well).
  11. With that style of stem I temporarily glue a block of wood amidships on the bulwark top so that, when inverted, the stemhead is clear of the work surface.
  12. Coywles: Collectors of both fresh air and fresh rainwater! Congratulations, Chris; you have invented a dual-purpose vent.
  13. Also, don't forget that powder barrels were made differently without metal hoops!
  14. Nice start but, might I suggest, 'horse backwards'? Imagine finishing this carving, which will have delicate detail in places. Now, how are you going to clamp it to cut the slot for the knee of the head? The only reasonable solution is to have the knee of the head made first. Then cut the slot with its double taper into the blank block first, making sure that it fits in place nicely. Mount the carving on a temporary stick that you can hold in a vise to carve it.
