Everything posted by druxey
Welcome aboard, Alex.
At this point you realize how amazingly complex wood engineering was back then. Looking good, Kevin!
- 1,134 replies
Off to a good start, Alex!
- 23 replies
- Lowell Grand Banks Dory
- Model Shipways
Cheers from Port Hope, Ontario, Canada
druxey replied to Peter Rumgay's topic in New member Introductions
Welcome, Peter. Check out the Marine Modellers of Niagara on the 'clubs' section of MSW. -
Oh, I'm sure you'll do a nice job on the kit 'as is'. But you may feel you want to kit bash a different kit later on.... Just sayin'!
- 109 replies
- Finished
- Artesania Latina
Life happens! We understand, You'll get back to it when you can.
- 8 replies
- Model Shipways
Your comments on the kit scale fitting out make me think you are on your way to either kit-bashing (modifying the model as you build it) or even scratch building!
- 109 replies
- Finished
- Artesania Latina
If you must use wire wool, use bronze not steel for the reasons given above. However, it's hard to find these days.
That is one of the critical points in forming the quarter gallery; everything is parallel to each other. You should be fine from here on.
- 399 replies
- winchelsea
- Syren Ship Model Company
Ships name 1700s
druxey replied to DaveBaxt's topic in Discussion for a Ship's Deck Furniture, Guns, boats and other Fittings
B. E.: I know that the French usually showed the ship's name in a compartment on the counter, but was not aware of this being done by the British in the early 19th century. Victory's name was certainly seen this way in early 1900's photographs (below), and persisted until changed to something more appropriate recently. -
Wet and dry paper is used for metal, not wood. This, and the fact you are using extremely fine grades is why you are getting clogging. Garnet, emery, aluminum oxide and silicon carbide are used on wood. See: https://www.empireabrasives.com/blog/sandpaper-grit/ Usually, for wood, 400-grit is as fine as you need to go.
Best wishes as you manage an elderly parent. It's never easy.
- 2,699 replies
- heller
- soleil royal
(and 9 more)
Ships name 1700s
British ships' names appeared across their counters officially in 1772, although this may have formally been done for a few years earlier. The practice seems to have been discontinued during the Napoleonic wars. -
Soft, medium or stiff brushes?
druxey replied to CPDDET's topic in Painting, finishing and weathering products and techniques
Look after a good quality sable and it will last you years. I have some over 30 years old and they are still in good shape. Cheap brushes are a snare and delusion. You have to keep buying them over and over and they will shed hairs in your beautiful fresh coat of paint!
