Posts posted by vaddoc
I just use 120. If something needs care I move towards the centre where it spins slowly. If I need to take a lot of material towards the edge. The aluminium oxide paper lasts ages and although with use the grit increases to maybe something like 150, it continues to sand well. 80 is so rough it leaves scratches and 180 and above is just not aggressive enough, these are more finishing grades. All finishing is done by hand, 400 is silky smooth
Dear all
Holidays are over and planking continues at a very slow pace. Planks are now 80 cm long!
When all the ribs are installed, I hope they will pull and align all the planks. I decided to use maple for the ribs instead of beech as it probably is a bit harder and generally a more pleasant wood to work with.
After filling all the gaps and sanding, the hull should be reasonably smooth.
Mark, Michael and Carl, thank you very much for your comments. Actually brute force is the answer. The wood-MDF joint is very weak so a good wack with a 1 inch chisel shaves off a thin layer of MDF and sends the wood pieces that hold the frames in place flying off. This can be done easily after all the planks are in place.
I have had very little time but I managed to install another plank and have ready the card templates for a couple more. I am now past the turn of the bilge and the curves are more apparent, it looks really nice but I cannot capture it well on photos due to the size and the limitations of my phone camera.
The next two planks will be again difficult. Progressively spilling got less and less and now the planks are almost straight. Up to now, one edge was concave and had to be cut with the knife, with extreme care and then sanded etc. The other convex edge though could be prepared in seconds with the disk sander. Now both edges need to be cut with the knife and this increases the chances of ruining the piece.
Another problem is that the planks are now very long, this is a 50 cm ruler. Maple is a lovely wood for planks, better than cherry pear or walnut, but the sheets I got have (or developed in storage) some warp which makes things even harder.
In a few days our holidays start, so there will be no progress for the next 4 weeks. I ll try to use this time to read some of the books I have been buying only to decorate my modelling shelves. The next boat is likely to be a scratch built fully framed one and this will need serious preparation.
This was a shock, very sad news.
Planking slowly continues but now much less spilling is needed and the twist is much less.
The planks are becoming though very long. These are two A4 mats, this plank (still unfinished) 2/3 of the way towards the sheer is around 70 cm long!
The hull is slowly starting to show its curves and although very rough yet, it already has the inherent elegance of all wooden boats. As I gain experience the gaps between the planks are getting smaller. The starboard plank is temporarily held in place with clips.
A problem which I need to figure out is how to get the boat off the MDF base so I can turn it around and install the ribs. The frames are 3 mm made of two sheets plywood 1.5 mm laminated together with epoxy. They are super strong. These are epoxied to wood strips which in turn are glued to the MDF with PVA glue. The whole thing is very solid. After I install the sheer plank, there will be very little space to put any tools in there.
Maybe I should soak the whole MDF plank in water overnight up to the level of the joint with the frames, this should dissolve the PVA glue. Or mess everything up!
Thanks Jon! Oh yes, it is coming along and for first attempt it is probably ok. There are significant issues but all part of the learning curve.
I guess that now with babies and all I am rushing things and often I am not happy with the outcome since I know I probably could have done it better. But I must compromise: It has taken me one and a half years to get this far! This is going to be a long journey.
But sometimes, as I see the hull emerge plank by plank, I feel like a child again!
Planking continues!
Thanks Druxey, indeed this boat was intended to be a learning tool as well as a model. I have certainly learned a lot so far! This scale I believe is the most difficult to work at. The planks now are 60 to 70 cm long and all imperfections appear huge! Also, wood needs to be chosen carefully to avoid twisted grain.
I have standardised a way of producing planks and I am learning from my mistakes. Still, it is a lengthy and difficult process to produce each plank although both the twist and the spilling are now getting easier.
Some photos of the progress so far. When the steamed ribs are in place the planks will hopefully align. Then the screws will go, the temp frames will be removed and the screw holes plugged with tree nails. Then filler will go in the gaps between the planks from both sides and the hull will be sanded. I hope this will produce a reasonably smooth hull.
I was catching up with your log Patrick and I started thinking "where is the galley" and voila! last post answered this one
I loved the picture with all 5 decks in a row. I think the 4th one up is for me, having cocktails as the sun sets.
Lovely work, very nice!
Actually there are 3 progressively more difficult planks left each side before things get easier. The boat is so large that each 100 cm maple sheet gives about 3 planks only! The ruler in the next photo is 50 cm long.
As the twist gets worse, it is more difficult to define the shape as even the cardboard resists going into place. It took a few tries to get the template right. It had to be done in 4 segments which are glued together, now waiting for the glue to set.
I have a suspicion though that my planking is actually wrong. This is due to the garboard plank that i feel does not have the right shape. It should go a bit further up in the stern and bow and be thinner in the middle. This way, the rest of the planks would need less spilling. Also, I now realise that the rebate line needs to be cut with extreme care and also that the planks at this scale need to be prepared very carefully as well. I was very sloppy and now all defects appear huge! Lessons learned (the hard way).
Anyway, despite all these, it is starting to look like a boat!
View from the bow
View from the stern
On 7/2/2017 at 10:44 PM, Jim Lad said:
It sounds like you're starting to get into the swing of the planking now, Vaddoc. As the twist on the planks gets progressively more severe, you may need a bit more aggressive steaming to make the wood compliant.
John
Thanks John, indeed I think I ve cracked this. The twist is causing lots of problems when dry fitting the plank during the actual making. 2 more to go each side though and then it will get much easier as I ll be at the transom.
Indeed, Allan, Druxey is right. The boat I am building turned out to be really complex!
I ve cracked the planking, still a handful though with each plank 60+ cm long and 2 mm thick...
- CaptainSteve and mtaylor
2
I think I should post my recent experience as it might help some first timers in planking like myself.
I realised that I probably got my GB plank wrong. I have gone as far as installing the first 5 planks (GB plank upwards). You can see the shape of the GB in the photo above.
The problem is, that as planking progresses, the spilling gets more aggressive up until the 7th plank (in my hull at least) and then it eases off. Now, my GB is already spilled so things get pretty bad with spilling as I progress. If I had taken the gb a bit higher in the stem (not much) and thinned the plank in the middle, given it a bit of a butterfly appearance, I would probably need much less spilling for the rest of the planks. This is why there is the advice of keeping the upper edge as straight as possible.
I suspect my spilling will get a bit unrealistic and my wood wastage is huge. Lesson learned though!
Thank you all for the likes and encouragement
Patrick, I think this moto should be added to the forum logo at the upper left corner of the page!
Druxey, that's a good word indeed! To be used when there is far more wood dust than elegance.
I looked into buying a height gauge but they are too expensive. I needed it to transfer the height of the lower edge of the planks on the frames (corresponding to the width of the plank) from the marked side to the other. I made a Franken-gauge that worked pretty well.
I then made the pattern for the third plank on the starboard side and cut the plank. I used the compass to outline the shape of the upper edge. Then transferred the shape onto the maple sheet, having marked the position of the frames. I then measured and transferred the width of the plank at the frames to the sheet. Then, I used a batten to draw the lower edge of the plank so that it would be a fair curve. I installed the plank and sanded the high spots so that the plank would sit as close to the previous plank as possible. Success with the first try again!
The spilling is quite significant but entirely possible in real life. It would mean huge wastage though!
3 more planks each side to go, with progressively worse twist at the stern and then I ll be at the transom. Looking at the garboard plank, I think that if the shape was different, going a bit higher at the bow and stern and left narrow at the middle, the rest of the planks would need much less spilling. I guess those practicums were right!
Thank you all, I really need the support in my fight against these stubborn planks.
I finally got the second plank right. It took countless tries and a forest of wasted wood.
Still, I finally might have standardised a process. Instead of making a cardboard template for the whole of the plank, it works better if divided in sections which then are glued together while on the boat so the plank is formed. I got the third plank right on the first attempt.
Just using hot tab water is enough to make the wood very pliable.
As the planking is progressing, it gets more difficult as the twist at the stern becomes more pronounced. Only when I reach the transom will it get easier. I realise I do one plank a week, so at this pace I need another 30 weeks to finish the planking!
So far I could not get the planks to fit snug to each other along all their length, this really would need skills I do not have. I pretend the gaps are left on purpose for the caulking...
Best wishes to all
Vaddoc
- Mark Pearse, russ, Omega1234 and 3 others
6
Dear all
In the last 10 days I made more progress than I could hope for. Still, planking at this scale is a difficult job and each plank is as painful as having a tooth out!
I fitted both garboard planks, I think they came out fine. The micro screws are easy to use and have huge holding strength. The tree nails are easy to insert. The gaps are left so that the steam bend frames can slide in the slots at the keel. Tree nails will be inserted later.
I then started fitting the next plank on the port side. Lots of wasted timber, many strips of cardboard in funny shapes lying everywhere. I am quite happy with the outcome though!
Next I started work on the other side. Close enough but not quite. Another wasted maple strip!
I do have a problem though.
When I designed the hull in 3D the lines seemed to show that the bow became hollow near the keel. I have cut the frames like this but the planks now seem to want to follow their natural curve there. I am thinking I will just put some sims in these areas at frame 2 and possibly frame 1 for the first 3 planks or so.
- mtaylor and CaptainSteve
2
This is brilliant Moxis, thanks for the tip. I struggled with this in my last boat
Vaddoc
- thibaultron and Moxis
2
Dear all
Slowly the boat is progressing. Both GB planks seem to fit reasonably well. Steam bending in the kitchen worked just fine, both planks very easily took and maintained their bend with minimal effort and no mess in the kitchen at al
I glued the port GB plank with PVA glue, I wonted to avoid the messy epoxy. I will also put tree nails where the plank rests against the keel, sternpost and stem and 1 mm screws at the temporary frames.
I will need a lot of tree nails, as later they will be used to secure the steam bend frames to the planks. My method for mass producing tree nails works fine. I have a selection of needles but I think i ll use 0.8 mm tree nails at the keel and 0.9 mm for the frames.
Tomorrow I will glue the other GB plank and tree nail and screw everything together, The hull will be much stronger then.
Regards
Vaddoc
- dj.bobo, Omega1234 and Mark Pearse
3
I use the big bottles of epoxy and insulin syringes as you can get very accurately just 1 m of each. If I need more epoxy I use 3 ml syringes (without the needle). I wear single use gloves and of course use the syringes only once. Very consistent results and not messy at all. Better value for money also I think
It is important to avoid skin contact with epoxy as an immune response builds up over tine.
A new lesson learned today. The garboard planks need to fit perfectly buy also need to be symmetrical!
This is not so easy when the wooden keel and rabet are not truly completely symmetrical. I took me 5 tries to get the gb planks shaped to be just acceptable. That was a lot of expensive wasted wood! At least maple is much easier to sand than pear or cherry wood.
Next, the planks will need to be secured in place. I am thinking of using a tiny amount of epoxy (as the slots for the ribs should not be filled) and tree nails with PVA glue. Since the frames are temporary and will be removed, I will use also 1 mm micro screws at the frames. The planks will need to be steam bend somehow, not sure how this will be done. I suspect the solution lies in the admiral's kitchen utensils.
SHADOW by Omega1234 - FINISHED - Scale 1/300 - Luxury 60m Mega Yacht
Dear Patrick, I have not been able to check on your log for some time and now I am lost in detail! Just too many things happening!
It is a beautiful boat and a very nice journey
Vaddoc
