Everything posted by catopower
When I first began ship modeling, more than 30 years ago (!), I had the Davis books in paperback and tried building the Lexington. Having never built a wooden ship model before, I wasn't up to the task, lacking skills and knowledge, so it was a failed attempt. In fact, I don't think I got very far at all before I realized this was way too much for me at that time. I think it could be done if you have the plan set, but there may be easier or more well documented methods of building up a framed model from scratch. Also, it's been argued for decades how that ship is very unlikely to actually represent the Lexington. So, you should just be aware of that.
Glen, I'm really happy to see someone taking an interest in Japanese watercraft, and your Kentoshi-sen is looking great! I've been focussing my own study of Japanese boats to mostly coastal and river craft, so I don't know much about the oceangoing vessels of the earlier periods. There seems to be much less info on those. I recognized the term Kentoshi-sen, but don't know much about them. However, I do recall seeing a model at the Sea Folk museum in Toba, Japan, and I have a couple photos I took of it, if you're interested. A bit different from this one, though, and I don't know what information it was based on.
- 106 replies
- Kentoshi-Sen
- bottle
Congratulations Tim on a beautiful build! Very inspirational. I haven't built a solid hull model in at least 10 years. You're making me think it's time to take one on again, and I've always had an interest in this particular ship and kit... 🤔
- 142 replies
- alfred
- solid hull
The next issue on the Mary is to fix the positioning of these fittings that work like cleats or kevels. Does anybody know the proper term for these Dutch belaying points? These fittings were mounted so low on the bulwarks that there was no room to wrap lines around them. I had to debond the glue that was used on them, which was some kind of rubbery adhesive. It made them easy to remove, but left a lot of rubbery glue spots and some hard to remove residue on the model. I did what I could and re-attached the fittings with thick CA glue. This allowed me to finally rig the lines for hauling up the lee boards. Rope coils to come later. Looking ahead at rigging the vangs, I noted that an image of the Utrecht reconstruction showed small pin rails at the bulwarks, aft. So, I added those to the Mary. I didn't have a whole lot of room to do this, as the forward wall of the stern cabin is about an 1/8" further forward than the plans show. This was an adjustment made by the original modeler. Made the spacing a little tighter, but I think the new pin rails should be okay.
- 82 replies
- Yacht Mary
- Mamoli
- 82 replies
- Yacht Mary
- Mamoli
Gregory, I just used them right out of the bag. There is some color variation between batches of blocks. But, not enough to worry about. I'm very happy with the deadeyes. Also, the 3D printed stuff seems pretty sturdy. I've had wooden blocks split when trying to wire strop them. But, not the 3D printed blocks.
- 82 replies
- Yacht Mary
- Mamoli
Trevor, thank you for the kind words. It is good to know that I'm not crazy for missing Sierra so much. Sebastian is a good, new companion, though he eats everything in sight, and then is ready for more! 😊
- 82 replies
- Yacht Mary
- Mamoli
Thank you, Patrick. Her death has been really hard to take, we were very close. Two weeks ago, I was going crazy and decided that while I could never replace her, I needed to do find someone to take over her job at least. So, I adopted this little boy kitty from the animal shelter to serve as my new ship modeling supervisor and kitty overlord. I named him Sebastian, and he's been helping out a lot. It's taken him this long to get used to me, but we're managing pretty well now.
- 82 replies
- Yacht Mary
- Mamoli
I've been having a really hard time working on my ship modeling projects. I started this topic a few days after my dearest kitty cat, Sierra, passed away. She'd been seriously sick for a couple weeks and couldn't hang on. I ended up having to work a lot extra to pay for her vet bills, plus had a hard time concentrating at home. So, things progressed very slowly, even though at times I thought things were getting better. Now, maybe they are getting better. I don't know. But, I did compile some of the work I've managed to accomplish over the last two-and-a-half weeks... I set the sails aside and started working on the main hold-up on this model, which is the making of chainplates. Once these are made, the shrouds can then be dealt with. It’s been a long time since I’ve made decent chainplates. On the Charles yacht model, they are simple wires that wrap around the deadeye and the bottom ends are inserted straight into the hull. I wanted something a little more sophisticated. So, I created chainplates from brass wire that are soldered to form flat plates with a loop at the bottom end for a nail. Took me a while to consistently form brass wire into the right shape. For this, I had to make a little fixture with a piece of brass rod for the big loop (for stropping the deadeye) and a hard, stainless steel pin for forming the small loop for the nail. It’s also been a long time since I’ve done much silver solder work, and I couldn’t find my silver solder and flux, so I had to buy more. I was sure I had some somewhere, but I guess it was hidden away somewhere some time ago. The soldering process turned out pretty well as you can see below. After soldering and cleaning up the new chainplates, I blacked them, starting by soaking them in vinegar (acetic acid) solution, rinsing them off, and them soaking them in a dilute solution of BlueJacket’s Brass Black solution. I find that BlueJacket’s metal toners work the best of any metal toners I’ve used over the past 30 years. Deadeyes are 5mm, 3D printed resin deadeyes sold by Syren Ship Model Company.
- 82 replies
- Yacht Mary
- Mamoli
Yes, The Pilot Boat 'Phantom' Menace
It's interesting to note another deviation from the Mamoli plans – there are no sheet blocks attached to that large topsail spreader yard. The sheet blocks are attached directly to the sail, and they "ride up" the braces. Means no need to have belaying points for the topsail sheets, and no sheet block slung under the spreader yard either. I've also noted there is no place to belay the vangs. The Utrecht reconstruction looks to have small pin rails on the bulwarks, near the tackles. Saw that on a photo somewhere, but don't see it now.
- 82 replies
- Yacht Mary
- Mamoli
Patrick, thanks for pointing out the bonnet and reefing on the Utrecht. Also, about the seizing or lack thereof. No seizing certainly makes my work easier!
- 82 replies
- Yacht Mary
- Mamoli
Gregory, I wouldn't kick yourself about the reef points on your model. Certainly not due to presence of brails, which served a different purpose than reef points. In fact, there's a passage in Brian Lavery's book Royal Yachts Under Sail, that mentions the later yacht Fubbs, stating "Fubbs was old-fashioned in 1719 in using a "bonnet", an extra strips of canvas fitted under a sail to increase the area, in this case of the jib. But, she also carried the means to reef the mainsail." So, if we are to believe Lavery's work, there would be evidence of both bonnets and reefs on small ships of the era, as pointed out by Patrick in the photos of the Utrecht reconstruction. (Thanks Patrick!)
- 82 replies
- Yacht Mary
- Mamoli
Hi Gregory, those are the brails, and they should be correct. In fact, its been my plan to show the mainsail "brailed up" like in this image. The painting, however, does show the line of what appears to the lacing of a bonnet. I'm reposting your image with a blue arrow pointing to the feature. The following painting by De Man shows something similar, again, I point to with a blue arrow. So, if that's not a bonnet lacing, I don't know what it is. Just a reinforcement seam of some kind?
- 82 replies
- Yacht Mary
- Mamoli
Thank you Druxey. I would gladly make the sails without reef points or bonnets! Any thoughts about the serving of the shrouds or stays?
- 82 replies
- Yacht Mary
- Mamoli
I'm jumping ahead now and working on the sails. At this scale, I'm going to stick with my practice of making cloth sails. I've made many sails from cloth, but still experimenting a little here and there to get the technique to work just the way I'd like. However, the issue here is the make up of the main sail. If you look at the sail pattern, the mainsail shows a row of reefing points. My last Charles Yacht model had a bonnet. Not sure what is correct, but thought I'd put this question out here. The Royal Museums Greenwich website shows a model of the Mary with reefing points in the main and stay sails, no reef bands, and a row of holes in the sails. One for each reef point? Of course, I could just stick with the Mamoli instructions and add these reef points to the main sail, which I might just do, since It's simpler than lacing a bonnet anyway. Just wondering what might be correct? Also, since I'm more accustomed to later period ships, and mostly larger ones, if the forward most shroud and mainstay should be served? Also the eyes of the shrouds around the masthead? Of course, kit instructions never tell you to do this, even if it was actual practice. Here, I'm not so sure about. Seems to me that since there isn't much to chafe against, the foremost shroud would not be served. But, at the mast head? And the main stay? Again, since this is mostly a continuation of the original builder's model, I'm sure he would not have done any serving, so just going by the kit instructions is a safe route. But, I'd like to better understand this.
- 82 replies
- Yacht Mary
- Mamoli
Thanks Patrick, I appreciate the nice comments. I had a bit of a slowdown over the past week, but I think I should be on a more regular ship modeling schedule again. Here's the most recent progress I made on the Yacht Mary. The lee boards were already made, but there was no pivot for it, so I drilled them out, as well as the hull, to fit a small length of dowel. Also assembled the anchors and cleaned up the anchor stocks. I used black thread to wrap the stocks. I think I need better lighting, because I had a hard time seeing that the wrapping wasn't particularly straight. But, I did manage to wrap the rings on the anchors without too much problem, and then added the anchor cables. When I first received the model, it had the hull ladders still intact. But, in the process of going to another ship modeler and then back to me, the ladders got broken. So, I had to remove them completely and rebuild them. I'm not really happy with the new ladders, because of the way they had to curve slightly under the hull. I'm not sure if that's because of the way the hull was built, or if perhaps they're not supposed to actually be flush with the hull as these will be. I suppose they should be straighter, but on this model, they would end up flaring out from the hull at the ladder bottoms, which would seem stranger to me. I didn't do much to the guns and carriages, except to paint them. They carriages were initially natural wood color, and the barrels were painted black, but were chipped. So, I painted the carriages and barrels, and then took a length of line, and threaded them through the carriages for breechings. Note that this is the style of Dutch gun carriages, but the Mary was Dutch built, so this should be correct. Not sure at this point if I'm going to add gun tackle and train tackle. Finally, I added the remainder of the decorative piece at the stern. It was a bit of a challenge to fit these parts, and the work left some notable gaps. But, I think it looks okay. I'm starting to work on cleaning up the already made spars, and fashioning flag staffs. I've also decided to use Chuck's ULTRA rigging line and 3D printed blocks and deadeyes on this one.
- 82 replies
- Yacht Mary
- Mamoli
Gregory, I don't think you're cluttering up this log at all. I'm mostly just sharing about the model I received and how it's getting finished over time. I'm not demonstrating any special techniques or trying to illustrate anything special, other than to show that I'm actually doing something! 😀 Thanks for sharing the link to Lloyd McCaffery's model. Such beautiful work!
- 82 replies
- Yacht Mary
- Mamoli
Here's some of the first work I did on the model. I decided to add a little more color to the model, so I painted the bulwarks the same shade of red I used on my Charles royal yacht. I'm doing the same with the gun carriages. Part of the reason is that the bulwarks wood was a bit splintery, and there were issues apparently when the builder was cutting the round gun ports. Also, I didn't like the way that Mamoli had the caprails built up from layers of strip wood. It must have made construction easier, but the visible layers of wood seemed distracting, so I went ahead and painted those as well as the moldings around the decorative section of the bulwarks and the channels. I considered using a strip of light colored wood over the moldings and maybe the edge of the caprail, but decided not to, at least not at this time. I rebuilt the chimney that's just behind the windlass, added the decorative hawse pieces at the bow and drilled the hawse holes. The gun ports were a bit of a challenge, as some of them didn't line up correctly. Another reason I chose to paint the bulwarks, so I could hide any corrections. The round ports on one side had only been started, so they were too small. But, a bit of filing opened them up and adjusted their heights and alignment. Decided that the model was far enough along to safely mount it. I didn't want to use the included stand. Those things are usually too flimsy and don't provide a means to really secure the model to the base. I just used the classic brass pedestals. That little deck structure hasn't been permanently attached yet. I want to add the guns before I permanently fix it to the deck. Oh, and on that and on the stern cabin, I added acetate for the windows, which were left open by the original builder. I think I just used canopy glue to secure them into place. Yes, before you comment on it, that gap between the rudder and stern post is... well, it's too large. After repairing the rudder and the rudder irons, I left it the way it was originally built. If it bothers me too much, I may just clip off the stuff in between, fake the hinges, and pin the rudder to the hull. Just haven't felt the need yet. Lastly, I saw some photos of other Yacht Mary builds and really like the splash of color painted on some of their transoms. So, I went ahead and added some color to this one. I'm not sure if I can handle painting any better detail, but I may try. Just not really ready for it yet. I considered doing more, but I really just wanted it to have a little bit of color. Any more, and I might feel the need to paint too many other details as well. Again, this is not intended to be an "accurized", and I'm trying not to undo too much of what the original builder did. But, as far as kit-built models go. It is started to look rather nice, and I'm happy about that.
- 82 replies
- Yacht Mary
- Mamoli
Gregory, thanks for that link, some beautiful photos of that model there. I wish I knew more about the small details of Dutch ships. I know there are various resources to draw from, but it seems you really have to dig around and research. A little more involved than I want for finishing this model. I'll hang onto my unstated Yacht Mary kit for now (though I'm trying to thin out my model kit stash), and maybe someday I'll work on my own model from the start and incorporate those details.
- 82 replies
- Yacht Mary
- Mamoli
Hey everyone. My apologies for the extended break. I ended up with plans to finish up a model that was started by a ship modeler who passed away a couple years. It's the Yacht Mary, and with the completion of my Charles Royal Yacht, I figured I could wrap this one up pretty quickly. It's come along pretty well, and I'm hoping to finish it in the next month or two. It's my intention to begin resuming my HMS Wolf build immediately after that, or even a bit before the Mary is done. It won't be that long, as I'm just starting work on the Mary's sails now: Back soon!
