pete48
Everything posted by pete48
  1. Thank you Mark , I Like the lines of this one as well , as far as Racing boats goes, I think the Farr designs are some of the best ( in the modern era ) Hey Patrick, There is no trick to the Balsa, I sand with the grain starting with 320 grit sand paper ( very lightly ) I guess the trick is going slow Thanks Jay, Glad to see you here, I am building her as a static model, so no need to use the West System on this one . I was thinking about it this morning and I will probably just seal up the Hull by Brush coating Titebond 3 ( wich is water proof ) that should do the trick Best Regards, Pete
  2. Nice work Mark, she's really coming along nicely Best Regards, Pete
  3. Today, I started by finishing fairing the Frames. While I was fairing the Frames, I soaked the Balsa sheets in rubbing alcohol ( 3 hours )This will make the Balsa more pliable , and easier to bend ( Alcohol also dries quicker than water , making the material ready to use faster ) . After that I started by planking the sides of the Hull, faired the sides to match the frames, then planked the bottom of the Hull. I then cut out the Keel slot and started to fair the bottom to the sides of the Hull. It is just a rough fairing at this point. Next will be to finish the Fairing , and seal up the Hull ( I will use Epifanes Varnish for this Process ) Here are the results
  4. Hi Patrick, look like She's starting to take shape , Nice work Best Regards, Pete
  5. Thanks Dave B. I appreciate the vote of confidence, Thanks Patrick, I am pleased with the results Best Regards, Pete
  6. Today, I started by adding the Deck Clamps to the Frames, Then I faired the Frames, at that point I realized that I needed to add the Keel slot and box ( to house the Keel ) Then finished Fairing the Frames, Next will be to plank the Hull. So far so good , she is coming out right on the money. Here are the results
  7. Thank you Patrick, I hope so she will be a challenge to build Thank you Cap'n'Bob, someone has to keep you on your toes Best Regards, Pete
  8. Ok Here we go, I have cut out the frames and made the building jig , I then set up the frames and added the keelson , Next will be to add the Deck clamps ( port and starboard ) and fair the frames , to get her ready for planking . Here are the results
  9. After a lot of contemplation, I decided that I would start work on the Most current Volvo Ocean Race 2014-2015 Farr Yacht Designed Volvo 65. I am building her in a 1/4" = 1' - 0" Scale . I started researching this build while building the Volvo open 70 ( completed in the Gallery ) I started Cutting out frames and building jig while I waited for the Varnish to dry on The Herreshoff Buzzards Bay 14 ftr. I was hoping to have started this build sooner , However here we are , I have not decided at this point whether to build her static or let her free sail. I do have plans to build a larger boat that will be RC. Here are the drawings for the boat, wich I will be using for the graphics and colors
  10. Congrats Piet, on job well done , one of the Best Builds that I have followed , I learned alot about making metal parts ( wich I did not know before, your build was very informative ) Absolutely superb workmanship . Hat's off Best Regards, Pete
  11. Thank you Mark, I was pleased with how the planking turned out ( Planking is my favorite part of the build ) Thank you Patrick, 6 coats of varnish did the trick Thank 's David B. , I will let the varnish set up a few days before I start handling it . Best Regards, Pete
  12. Looks Sweet Patrick, Beautiful work Best Regards, Pete
  13. I finally finished the Varnishing of the Hull, it took 6 coat's of Epifanes varnish to get the result that I was looking for . now that the outside of the Hull is complete I can turn my attention to the inside ( Cockpit and rear deck ) Here are the results
  14. Thank you Mark, Herreshoff designs have the most beautiful lines I have ever seen Thank you Yves, I like the color combo of natural wood and the stained red ( it's pleasing to my eye ) Best Regards, Pete
  15. Thank you Patrick, I am pleased with how she is coming along Best Regards, Pete
  16. Thank you Dr. Per I greatly appreciate it Best Regards, Pete
  17. Today, before I sand and Varnish the Hull, I decided to add some birch ply to the forward Cockpit bulkhead and the rear deck Cockpit station and stained them a cherry red. I started by laying out the ply using the plans, I then cut them out and glued them in, and then stained them Next I cut out the floor and cut out birch ply for the rear deck. And lastly I cut out the seat benches. Next will be to sand and varnish the Hull. Here are the results
  18. Thank you Bob, It's nice to see her finished Best Regards, Pete
  19. Hi Nils, I agree with Patrick and all the others who posted , Stunningly Beautiful Best Regards, Pete
  20. Thank you David B. you gotta love the Herreshoff designs Thank you Michael, She is starting to come together Best Regards, Pete
  21. Thank you Patrick, I am pleased with how she turned out Thank you Cap'n'Bob, Originally I was going to free sail her, I am planning on a larger boat for RC, so I decided to just complete her as static Best Regards, Pete
  22. Thank you Nils, She is starting to take shape Hey Patrick, True that Best Regards, Pete
  23. Ok, here we are at the finish line, First of all, I would like to thank everyone for the comments and likes .( she has been a pleasure to build ) I started by building the cradle, and adding some logos to it. Next I installed the Keel . and Lastly I made the 2 rudder blades , installed them and painted them. the Boat is now complete and no new post's will be added to this log. ( I will answer questions and reply to comments ) Here are the results, the rest of the photo's can be seen in the gallery
  24. Thanks Patrick, Kate is always right Thank you Cap'n'Bob Best Regards, Pete
