mtaylor
Moderators
Everything posted by mtaylor
  1. What would be a good glue to use for gluing printed plans on wood to be cut? I'm thinking rubber cement but not sure.
  2. Yves, Follow your heart and see where it leads. You may try #3 and realize you're way over your head. You many do #1 and then be mad later because it's too pristine. I'd say use #2 as your baseline. If you feel comfortable and up to doing more, go for it. I do like the rust by the way and other aging things you've done. Which raises a question... how often were the subs pulled out and put in drydock?
  3. You can add that eyebolt as in the picture you show but it was actually British and possibly American method. On the plans, there's two sets of eyebolts. The two rear most were for the training for in hauling the cannon. The two in front of the rear trucks are for running the gun out after serving. These plans are from ANCRE for Belle Poule, so I don't doubt their accuracy. Zu Monfeld shows similar for the period. I'll include it for comparison along with a top view of it in place and rigged. Note that in practice the crew would often only use one in haul and that the in hauls were normally not attached unless absolutely needed. They often just loosened one tackle and ran it back to the eyebolt in the deck. It saved time actually. There was much traffic with powder monkies, gunners, officers, etc and the in hauls just got in the way.
  4. Shortgrass, What are you looking for? There is a major supplier in Portland, OR but you'll have do some processing as I don't believe they "custom" as far as planking strips, etc. Here's their website.... https://www.gilmerwood.com/home
  5. The wood arrived and is currently laying flat on my bench with some heavy weights on it. I guess spending a week in the back of truck in this heat and humidity did it. I'm also going to have to rework my drawings a tad as, for example, the quarter inch thick wood isn't. It's about 1/32 shy of 1/4 inch so I'll need to close up the tolerance on the slots in the false keel.
  6. Looking good. Comparing the ship the plan on the wall, I think you nailed it.
  7. Don't feel bad. It is easy to mix up plans and cause yourself confusion. Hopefully you can save and use some of the parts you have cut.
  8. That seems to be typical. Best bet is to figure out how many ports, the size, and then adjust the spacing between them.
  9. From what I've read, the lists you see are the basics. The paint was diluted with turpentine (or other spirit) and mixed to provide the various colors.
  10. The French had the bolts and rings down the deck behind the guns. As for the guns themselves. there were two eye bolts (one on each side at the rear. They did often use only one tackle to pull the gun to the rear. I'm attaching a drawing from the La Belle Poule which is a tad earlier in the period than your ship. I hope this helps.
  11. Generally speaking, the gun ports will follow the run of the deck so there probably would be a gentle curve fore and aft with the low spot in the middle. When built, many times the ports are clear of the wale(s) in some places and cut into them in others do to the sheer (curve) of the planking. The idea is that each port is the same height above the deck.
  12. Depending on that programs, apps, etc. on your computer, you might be able to import the plans and reduce them down to print out at the right size.
  13. John, Welcome to MSW. I'd suggest that your next project to open a build log.
  14. Bill, Feel free to start a build log even at this point in the build. If you have some pics from earlier you can put them in or just go from where you are now.
  15. Looks good, Tom. And be careful what you wish for.
  16. Pat, The backbone (false keel) is 1/8" (3.175 mm) thick 3-ply plywood. My bulkheads are 1/4" 3-ply plywood and are 1-1/2" (41 mm) on center. I intend to put some wood braces between the bulkheads and along the false keel to make it rigid. On the local news front... my plywood is being delivered tomorrow. Yippee....
  17. I think the lines look very acceptable. Ok.. scratch that... very good. Do the plans show an eyebolt with a ring on the deck for each gun behind and in a line along the hatches? The line would be followed (gentle curve like bulwarks) fore and aft with one "set" for each gun used to pull the gun out of battery if the recoil didn't get back far enough or if it needed to have the shot and ball removed. They do add a bit more "eye-candy".
  18. Nah... she won't do that if she's been watching court shows. Find a hit man maybe.....
  19. Nice work on the eyebolts, Nenad. Those things are tiny but look great.
  20. Thanks Piet. Mike, It's too big for the Death Star. The main backbone (false keel) is about 29" long. I've ordered "Lite" plywood which I'll let settle in before using it. I'm also planning on putting in spacers between the bulkheads to help.
  21. Shall I delete the two extras or leave them in for emphasis?
