MrBlueJacket
Everything posted by MrBlueJacket
  1. I have a model that sat for 10 years before finishing it. Not to worry. Nic
  2. Hi, Seguin research was done many many years ago. I just did an image search, and of the hundreds of photos, not one shows any evidence of sails. In the picture you show with sails, the booms are very evident, and Seguin lacks those. Of course, sails could be loose-footed. I'm at a loss. Nic
  3. They are not. They are 1/87 scale. However, the difference is very small (only 10%) and not noticeable on a large model.
  4. Having done what I could on the port side, flip over to the starboard side again. I'll be adding to mast #4; shrouds 1 & 4, jackstays, backstay, and ratlines every 5th batten. To #3 mast; shrouds 2&3 (for the battens) and start the jackstay. Then we'll flip yet again.
  5. So now I've flipped to the port side. Masts 6 & 5 are completely done, working on #4 and 3.
  6. Excellent job! PM me your full name & address so I can put you in our system and note 10% off the next kit you buy from us. Nic
  7. There is something seriously wrong with the shaped hull, that should never have gone out the door. I will send a replacement on Monday. Your mystery piece is an unfinished hull blank, again, should not be there. Although we suggest an assembly sequence, if it bothers you, you can always make your own decision. Nic
  8. Hi Rob, Check post #204 for leather simulation. https://modelshipworld.com/topic/19500-red-jacket-by-mrbluejacket-finished-bluejacket-shipcrafters-scale-18-1-196/page/7/ Nic
  9. So after almost a month to do 2 repairs, I am back to the Wyoming. Attaching battens to the starboard side of #4 mast. No, the battens aren't crooked, they are parallel to the waterlne, but because the masts are raked, it looks skewed.
  10. Referring to post #122 above, the tackle under the boom is called a boom preventer guy. Our buddy Jerry T sent me this: "Nic, I came across the Model Ship World blog you and Al are doing regarding the WYOMING prototype. An extraordinary model for sure. I read with interest the question about the purpose of the luff tackle rigged along the bottom of the booms. I came across this feature when researching my construction of the BOWDOIN model a number of years ago. See photos below. I found the answer to this question in Chapelle’s “The American Fishing Schooners”, page 357. This was a boom guy, a preventer whose forward end was rigged to a staple on the rail just aft of the shrouds when the boom was rigged out for running before the wind. Its purpose was to keep that boom steady as the vessel rolls and to prevent an accidental jibe. Maintaining control of those booms was critical on the big schooners." So while the boom sheet prevents it from extending too far, this guy prevents it from accidentally returning towards the boat thereby keeping it in a fixed position..
  11. From what I've seen of the speculations about what the Ark looked like, you could start with a shoe box or a length of 4x4. HiS models does make an Ark kit. Google Noah's Ark models and you will find examples. Nic.
  12. Creativity and ingenuity prevent everything being cookie-cutter. I couldn't be more delighted. Send me a couple of pix and a paragraph or two of your mods and I'll make it "model of the month" sometime. Nic
