Evening all, I started on the pond today - first thing was to cut a sheet of paper then glue it underneath the base covering the area of the pond, I used PVA and applied a few coats inside also, this was the fully dried using the hair dryer, after I applied a few coats of mid Green the some washes. Then the fun stage - I emptied some of the Acrylic Resin into a smaller jar and emptied it into the pond - first mistake (I had put to much in and it was over the height of the edging stones) so before it had set I removed the majority of it - and re applied but a smaller amount that just covered the bottom. I used the hairdryer to speed up the setting process - I could gradually see the resin clearing from a white liquid to a clear water - this took about an hour of dryer work. Not too bad for my first attempt. OC.
I am keeping a lot of interest in this build (as I have the same kit - with the wood deck in my stash) I won't be starting mine for a good while yet - probably not till next year. OC.
Evening all, more work on the frontal area around the pond - the wall from the Barn to the front wall needed shortening, to make it fit the new floor plan, I then trimmed the edges of the floor base where the outside walls meet. I then dry fitted all the buildings to check they all fit and meet as they should. OC.
So, if you are wondering about the pond? it will have a sheet of paper underneath, then I will paint inside a light/mid green then poor over an acrylic resin clear water I brought, its supposed to be "self leveling" and takes a couple of days to set, then I will add a bit of a wash and my normal rock/stone colours around it and on the base. OC.
Evening all, onward and upward - the doors were painted and weathered and glued in place - one fully open and the other nearly fully open to show the detail framework on the back. Next I had to dry fit everything to get an idea where I needed to cut the floor down to (this will then influence how much the side wall needs shortening) the floor was marked and cut through using my blade and ruler - the a tab was cut into. Next off was the duck pond - this comes with a pre-cut cardboard outer that simulates the edging stones, first thing I did was to pencil the inner lines - then using my sharp blade I carefully cut around the mark - then when the rough cantre was cut out I carried on cutting away and dry fitting the out piece. When I was pleased with the fit - it was glued in place. This shows the dry fitted wall against the ground piece/pond. OC.
