Posts posted by Old Collingwood
Just now, CDW said:
It will be a surprise. Thanks for the kind words OC
No worries, will look forward to what ever you build mate.
OC.
- popeye the sailor, CDW, Canute and 3 others
6
Just backing up what Ken said.
OC.
Looking really nice Craig.
OC.
- lmagna, mtaylor, popeye the sailor and 4 others
7
2 minutes ago, Canute said:
Coming along nicely there, OC.
Thanks Ken, toying with the idea of putting some wiring in there from fuse wire and a support strut.
OC.
Hi all, so today I was "multi tasking - shhhh cant let the admiral hear I struggle looking at the hoover as it is" I first put the first grey coat down on the Spit, then put it away in my box to dry, then the second bit - I decided to work on the Seafire, in the kit you have the choice to display the wing guns open through an open panel, I decided this would be good on the one wing, first I struggled to understand the instructions as it wasn't clear how the machine guns and feed units go, they come into two different types of assemblies, after going to Mr Google to check out some pics - I found out how they fit together.
I first put a few coats of cockpit green down, and while at it did the same to the wheel wall and well bottoms, next job was to put some nato black on the machine guns, then when dry (with hairdryer again) I dry brushed some white over them.
I finished off by gluing the wings together.
OC.
- marktiedens, Canute, Jack12477 and 6 others
9
9 minutes ago, Egilman said:
That's a beautiful update set and in injected styrene to boot! it will make any 1/48th scale builder very very happy accurizing their 1/4 scale manned missile... That being said, unfortunately my 3/8th scale manned missle will have to suffer along with resin unfortunately......
Thanks for the link brother I"m sure it will give another Zipper "G" modeler exactly what they need to build a real beauty...
No problem at all.
OC.
Thats a great size will be a beauty.
Found this link to update goody heaven -
http://www.dacoproducts.com/KDCC4802.php
OC.
- Egilman, mtaylor, popeye the sailor and 2 others
5
Excellent work Tom, really busy in that plane.
OC.
- Fright, Canute, Edwardkenway and 2 others
5
I dont want to deflect EG's post but my 10pence worth - Ken I have built two versions of the AardVark an E version but also the SparkVark, both 1/72 scale Hasegawa kits I think.
Sorry for the interuption EG.
OC.
- Canute, mtaylor, popeye the sailor and 1 other
4
52 minutes ago, cog said:
Thanks all for the likes, and comments
I did paint on stripes Denis. As it would be rather silly not to. In all honesty, Initially I forgot and had them painted the base "belly colour", but realised I should have painted them with stripes. Checked the paint scheme, and added them by hand. By the way, I changed the prop from fixed to a turning one. That's why it's still not mounted. I did a wee bit of weathering, painted the exhaust (nearly forgot as well) ... final layer of varnish/lacquer ... would satin be the propper choice or gloss?
Carl I have seen both Slightly shinny satin with modern versions or those in museums, but those in service I'm not sure about (I assume they would be mat with just heavy use areas slightly shinny)
OC.
- popeye the sailor, mtaylor, Canute and 1 other
4
1 hour ago, popeye the sailor said:
sorry I missed all the action............sad to see that happen OC. I've had decals do that.......that's why I hardly ever coat them afterwards. something about the decal film........perhaps not enough adhesive properties. when the decals are movable on the paper, I like to move them around a bit, to insure they have sufficient adhesion. the use of micro sol and micro set can take some away, if too much is used. one might never know the cause, but it's a learning curve nonetheless. hard to say if the use of paint pens might have helped you, but I've done that in the past with reasonable results. you did the right course of action. glad to see you can move on from here.....and get this bird finished........hopefully Murphy free
Thank you kindly Denis, It has been a Huge learning curve for me as its the first (proper) attempt at building a half decent plane kit, the construction stage never was a real issue as the parts can be wiggled about and glued/filed/sanded where needed, it was the large area painting that has been the trouble, that and mixing paint/top coat layers, and also not having as much control with rattle cans.
Will I learn for the next build or one after that - "probably not" as I have to use what I have and am limited by my enviroment.
Still its all fun.
OC.
- Canute, Egilman, Edwardkenway and 1 other
4
34 minutes ago, popeye the sailor said:
that's where scratch building comes in.........lots of time, the supplied parts aren't quite up to snuff, especially ship fittings. the use of paint is more of a requirement with plastic than wood.........with wood you see more lacquers and stains.
Seafire is com'in along nicely OC
Thank you Denis, not bad considering this was the original Spit I had binned in the "naughty cupboard"
OC.
- popeye the sailor, lmagna, Egilman and 3 others
6
Thats a good recovery mate (glad im not the only one with model gremlins)
OC.
1 minute ago, Egilman said:
I think it's looking VERY VERY nice, probably more than you really wanted to do, but she is worth it....
Thank you kindly.
OC.
Good day all, I reached a milestone today after doing a bit more touch up and weathering around the region of the damaged decals -
Mossie has her wings attached.
Just a few more decals to be put on the one stab, then in a couple of days time I will do a mist coat over the troubled decal area, then followed up by a couple more layers.
OC.
- Javlin, Edwardkenway, CDW and 12 others
15
15 minutes ago, mtaylor said:
Sounds like a good plan, OC. The recovery so far is looking great. Nothing like a few worn spots and some scars on a war bird.
Thanks mate, just my logic - cover up the blemishes with blemishes - just intentional ones.
OC.
- Egilman, Edwardkenway, mtaylor and 3 others
6
So after doing some internet bashing on the subject (not fly flishing🙃) later I will do a bit of shading using my pencil along some of the detail lines, then I will go over picking up the high spots with either a dull alum or white dry brush, as around the region where the dameged decals, there is a fuselage locker and the strenthening rib, the same needs to be done to the other stab where had to give it a re - paint.
OC.
3 minutes ago, Dan Vadas said:
With the amount of Spitfires built/being built on this Site we may have to change our name to Model Ship and Spitfire World
Not far wrong there Dan, tell you what this section has really taken off.
OC.
Very nice work Kevin, the lights add a 3D affect to her.
OC.
- popeye the sailor, mtaylor, Kevin and 1 other
4
M4A3 Sherman w/ 105 mm Howitzer & 75 mm Long Gun tanks by Jack12477 - FINISHED - Tamiya - 1:35 scale - PLASTIC
in Non-ship/categorised builds
I have that sorted when I go out - Flame thrower does the job fine.🤭
OC.
