Posts posted by Old Collingwood
5 minutes ago, mtaylor said:
Not liking that OC. Other than somehow removing the paint and starting over and finding decals I have no idea how to fix this disaster.
Dont understand why it happened reaction between tamiya rattle can and acrylic?
Still keep looking at it with diss-belief.
OC.
- Canute and popeye the sailor
- 2
Think I have Wrecked it, I decided to apply the Tamiya Acrylic Semi Gloss top coat from a Bottle by brush, I brushed it on as well as I could, when covered I used the hairdryer and the result A Cloudy Mess just Horendous.
So I thought as its Acrylic it should wipe off using soapy water and a sponge - "Wrong Wrong Idea"
Dont know what I am gonna do now, even if I could re paint the whole things (so dont want to have to do all that again) I dont have any replacement decals.
Disspaointed dont cut it to be honest.
OC.
4 minutes ago, Egilman said:
I think it's coming out beautiful brother, but then I'm kinda partial to camo on great planes...
Thank you EG.
OC.
- Egilman, Edwardkenway, mtaylor and 2 others
- 5
More progress today - my building has a pattern - you can tell waht the weather is like by what time I spend at the table, anyway more progress on mossie, I carried on attaching the various decals on the fuselage including the bomb drop count and grin reaper, I then put a first coat of micro sol, and put it aside, then it was time to have a llok at the wing and stabs that had been sprayed - I gently removed the paper/blue tak masks and gave them a wipe down with soapy water, then I gave then a gentle rub over with fine wet and dry (as I have been trying to age the paintwork slightly to show fadded/rubbed areas from use. I also used my pencil and worked along some of the panel lines/around obstructions, the wing still needs the roundel and other decs.
Here is a few pics showing a dry run with wings attached not glued o yet.
OC.
- marktiedens, Egilman, Canute and 8 others
- 11
36 minutes ago, popeye the sailor said:
good to see your pressing on OC.....the plane is really coming along nicely I've run into a lot with decals..........making my own at times shows me more. yup......some are done in flat and some are glossy.....obvious to most that if a company makes kits......wartime models, that they should be done in a flat format. excess film is another problem that some decal makers have remedied.....printing their decals as stand alone and not in a long strip......numbering and lettering. the excess flashing around decals is yet another......trimming close to the image cleans them up fairly well, but make sure your using a very sharp pair of scissors. I don't do it all the time, but trimming and applying the numbering one piece at a time will save some of the grief. .....and in the event that they do appear glossier than the surface your applying them to, flat top coats will take care of them.
gonna look great when Mosi gets her wings
Thank you for the kind words Denis, I should have looked into trimming the decals with a rule and blade, but it occured to me after fitting them, but its something I will look into if I come across decs like these again.
OC.
15 minutes ago, Javlin said:
Mike in away,I use Semi-Gloss enamel by Model Master to seal the paint and it will tone down a gloss paint also then I apply the semi again after the decals are laid then hit it flat unless it's NM finish.
Thats what I have in jar/pot form Tamiya Semi Gloss top coat, I will be brushing it on once all the decs are on, then I will blast over with a couple of coats of Tamiya rattle can Flat top coat (after leaving the semi gloss a good few days to harden)
OC.
36 minutes ago, Canute said:
Take care of yourself, OC No rush for completion dates. Your Mossie is looking good, mate.
Thank you kindly Ken.
OC.
- Canute, popeye the sailor, Egilman and 2 others
- 5
Another thought - "Did they put covers over stairway openings during action" to save sailors falling down them at the heat of action?
OC.
26 minutes ago, cog said:
Getting black as good as you did is quite hard, well done
Thank you carl, I think a combination of perseverance and stubbornness not to let it beat me, also driven by wanting to make my late farther proud, also not trying to do to much or achieve too much when dog tired - but save for better days like yesterday was.
OC.
- lmagna, Canute, Edwardkenway and 3 others
- 6
As Ryland said - it depends how you want the wood finish to be (still show the wood grain - or aim for a smoother finish) if you look at pics of say HMS Victories inner bulwarks they look like a fairly thick layer/layers of paint has been applied, but it really depends how you feel about the finish also how thick the paint is inside the tins/jars, if it very thick you could dilute it say 3/4 paint to 1/4 acrylic thinner or distilled water.
Hope this helps mate.
OC.
Hi Mark, with the planking it doesn't hurt doing a couple of rows coming from the keel garboard plank thats how I did mine and others do it the same way, I have been over Vic possibly about Three times years ago, If memory serves me the upper gun deck under the boats has Two facing stairs following the line of the deck both looking into the middle.
OC.
Superb work EJ, she has turned out marvelous a real credit to all the hard work you put into her, stay well and safe, look froward to following you next project.
OC.
- popeye the sailor and EJ_L
- 2
Truly Amazing, any thoughts of what you will do with here when finished? She is Museum Standard and I am sure many many people would love to see her (when we are back to some degree of normal)
OC.
I agree completely - this is superb work of small subjects at a small scale - not much room for error, they look loverly mate.
OC.
36 minutes ago, Egilman said:
I usually paint a section that will be under the decals with future to create the glossy surface for the decals to adhere, then overcoat them with Testors flat rattle can lacquer for the final finish......
Most important is the smooth surface under the decal to prevent silvering, doesn't have to be glossy, but it does have to be smooth. (flat paint doesn't create a smooth surface) The reason most use a gloss coat for decaling is the perfectly smooth surface gloss lacquer produces and it's easy application.... I prefer Future floor wax because it dries thinner than most lacquer overcoats.....
It coming out beautiful my friend......
Thank you sincerley EG, I think as was mentioned earlier if the decals had been of a higher standard and with a glossy sheen to them, the backing would have settled down over the shiny paint surface that was also very smooth from buffing for that purpose, when you look at them on the backing strip they are deffinatly more flat in finnish than shiny like others tend to be.
What I will do is put a fourth layer of micro sol ontop of the large decals leave over night, put the other smaller ones on (more micro sol on them) then when the whole fuselage is decalled, I will hand paint a layer of semi gloss top coat all over and put it aside to harden for several days.
Then I will work on the wings and stabs that have been sprayed up today.
OC.
- Egilman, lmagna, popeye the sailor and 3 others
- 6
Thank you Diver, as I explained somewhere further back my farther was an Engineer in the RAF during the war his service knick name as an ERK, he specialized in airframes and engines, and on base he would do anything from bench strip downs to engines and right through to light to medium/heavy airframe work either on the pan or in the hangar, all dependent on what was needed or the condition of aircraft returning from duties.
The mosquito was one of his fave planes to work on but he also serviced Spits, Hurricanes, Lancs, Wellies, Shorties, and prior to this he cut his teeth in the FAA on Seafires and Corsairs.
OC.
23 minutes ago, Canute said:
A flat surface will cause the decals to silver. You can spend hours removing it. I think the gloss as a base is OK, but you'll need a top coat to blend them in.
That was my thinking Ken - top coat to blend it all in.
OC.
- mtaylor, Canute, Landlubber Mike and 1 other
- 4
13 minutes ago, Landlubber Mike said:
And OC, I should have mentioned that your build is looking really sweet. That paint scheme is really sharp.
Thanks mike, I am wondering the same thing with the decals, I am hoping that by first painting on a layer of semi gless top coat (as I have a jar of this for hand painting) then after a few days spraying the tamiya rattle can flat top coat will bring it all to the same finish.
OC.
Just now, Javlin said:
It's all part of the curve OC 8 out of 10 times they are a Glossy backing just thinking of the Spits out there.
I dont rate these revell ones that highly dont think they are cartograpgh ones, have a lot of edging to them - in hindsight I should have trimmed them.
OC.
- Egilman, Edwardkenway, lmagna and 6 others
- 9
6 minutes ago, Javlin said:
All looks good OC but something for future builds.The surface of the plane was over glossed to sheen of your decals hence the flat look to the decal backing shows.The idea is to make the two surfaces match before the decals are applied to hide the backing film just food for thought all looks Very Good though. kevin
Thanks for the advice Kevin, my first work using decals with setting producs, I polished the fuselage as I thought the advice is to put them down on a gloss / shiny surface? guess it doesn't help with the decs being a flat finish not shiny.
OC.
- Edwardkenway, lmagna, Canute and 1 other
- 4
More progress with the decals - I put a few layers of micro sol over the tail, then today I brushed over a coat of semi gloss top coat just to seal them down, next was the serial this went down ok, then the large one piece fuselage decal, this was a little more trouble-some even with a coat of micro sol you can clearly see the decal paper between the letters - this might settle down with a coat of semi gloss top coat.
The decal is still wet from the micro sol.
OC.
- Edwardkenway, Canute, Jack12477 and 9 others
- 12
Mosquito B Mk IV - FINISHED - Revell - My next non-ship project
in Non-ship/categorised builds
Shouln't have been any - was indoors no heating on and about 18deg I keep telling myself "should have just sprayed the Tamiya rattle can flat over it and not tried to even up the gloss coat first, perhaps you can not apply acrylic over the top of Tamiya rattle cans as they are laquar and not acrylic.
To try to rescue it would mean trying to get a smooth surface then re masking the entire rear section from the fuselage joining section, meaning fresh black and on the tail/rudder, fresh camo on the top, I have found in the box and alternative large code with side roundel and registration code, but no spare tail decals (that would have to be left blanc.
Just the thought of having to re do it again - a third time - this kit is becoming a real knitmare.
OC.
OC.
