Old Collingwood
Posts posted by Old Collingwood
  1. 6 minutes ago, mtaylor said:
    Jack,
    When you're done with the bird, unless it's in a case, hang a sigh with something like "Do not touch. The rotors do not turn. "  And maybe some threatening words like they will suffer extreme harm from you fearless watch dogs.
    Or "Mind the Rotors they dont turn - but the body does"😁
    OC.
  2. 4 hours ago, mfrazier said:
    When I  set up and tried to start the 4 butt shift pattern,  I spent three hours trying to figure it out. I laid a few planks and it would be wrong and I  had to remove them and start over. Finally, once I  got it started, it went okay. I  am sure most of my problem was the fact that I  have major problems with numbers since my stroke a couple years ago. I'm an engineer and I used to be able to do trigonometry problems in my head and now I  can't add 2 and two without a calculator and still get the answer wrong. It gets frustrating.  This planking method requires some counting, a lot of counting.
    Keep at it mate  you will do it.
    OC.
  3. 15 minutes ago, CapnMac82 said:
    This continues to be an impressive build.
    And the kit appears to be top notch, as well, too.
    Watched a vid on building the 1/18 (!) Merit SBD 3/4, and was somewhat amazed.  That kit goes for north of US$150, and has as many movable parts as the old Monogram 1/48 kit (other than folding wings--go figure).  The parts looked as if they had been pantographed "up" to the larger scale, rather than down.
    So, all the more applause on the build here.
    Sorry for butting in (again)   Captain   you should do a build log in the site.
    OC.
  4. 44 minutes ago, Jack12477 said:
    Not sure Lou. As I assembled it I made sure no glue got on the shaft pin that runs down thru the assembly,  but I cannot see how the thing will rotate if I glue that pin into the hole in that black rimmed insert. Also cannot see how I can insert it in hole either since I am inserting it blind, no way to see the hole. Have to play around with it to figure it out. I will try to post some close ups later
    I remember some kits  - old school Airfix I think,   thier  heli's  used to have a plastic  T piece bolt like thing  it  was supposed to be held inplace then the rotor head was supposed to glue to it  allowing the rotor head to rotate.
    OC.
  5. 11 minutes ago, Jack12477 said:
    Before I can finish the rest of the model I have to add 3-4 grams of weight/ballast to the nose so it will sit level. Right now it is tail heavy.  This incarceration is making it difficult to run and and pick up a packages of BBs since I have nothing in stock that will fit down into the well.  More later  !
    Have you got any small nuts and bolts?  you could try attaching them with blue tak.
    OC.
  6. 29 minutes ago, cog said:
    it will be Denis ... it just hasn't arrived yet. I want to build one with a detailup cockpit, engine, radio room (more like a box), and wheels. That should keep me busy a few days ... four seperate builds in one ... add a cloak of invisbility ... and the camo is complete too
    By the way, presently working on a Spitfire IXc 1/48 engine ... should fit snuggly in OC's build ;)
    Sounds interesting, is it the Brassin  one?   I have heard good things about that.
    OC.
