Posts posted by Old Collingwood
- Canute, lmagna, popeye the sailor and 6 others
- 9
Hi all, so when I spoke last I was waiting on good weather so i could get out and do some spraying - its that frustrating time as I had some chores to do first then our twice weekly shopping deliveries to the house, then I got the time to step out the back to try some spraying - "Rain" not heavy just that drizzly stuff, but I had nothing else on mossie to do till this painting was done, I kept my eye on the weather till later in the afternoon I spotted a dryer spell but with a little bit of wind - so I went for it, I have one of those 12 inch long plastic storage boxes with a hinged lid, I took the parts with me in it - got out the wing first and sprayed the Green - It went down very well until I noticed a flying thing nat or something had landed on the wet paint, I put this in the box and did the same to the main fuselage - that went down the same but with no thing's stuck to it, I put them both in the box closed the lid and was able to take them in the house without a worry over paint fumes.
Later after a couple of hours I was able to inspect the damage off the insect - I was able to scrape it gently off - but it will need a small section of primer then another coat all over the Green areas - the fuselage will get a second coat of green also as I did the same with the Grey.
No pics though.
OC.
- lmagna, Canute, Edwardkenway and 4 others
- 7
Looking smart now she is attached to terra firma.
OC.
- lmagna, mtaylor, popeye the sailor and 3 others
- 6
Your doing some amazing work Kevin, so much attention to detail is going into her.
OC.
- mtaylor, Kevin and popeye the sailor
- 3
If the weather is good tomorrow I will prime the tail planes/right wing/spinners and do a couple of coats of Green on the masked areas, then I will pop them in a box with a lid to let the smell go off a bit before taking them indoors.
OC.
- mtaylor, popeye the sailor, Canute and 1 other
- 4
This is a walk down memory lane for me as I built this kit when I was about 10, I t will be interesting to see what you do with it.
OC.
- Canute, mtaylor, popeye the sailor and 1 other
- 4
- cog, CDW, GrandpaPhil and 5 others
- 8
23 minutes ago, CDW said:
Is it just a matter of the shape of the cone or are the spinners too short? If it's just the shape of the cone, you should be able to reshape them somewhat more like the originals. you'll just have to take care not to file away too much material. If they are too short, it is a different problem/solution, and they will need to be built out with putty or something similar perhaps.
They are the right circumference just not quite pointed enough they are kind of like a ball shape.
OC.
- popeye the sailor, Canute, mtaylor and 2 others
- 5
Question - any ideas how I can make my prop spinners more pointy and less rounded, as the kit ones do not form enough of a point.
OC.
- popeye the sailor, lmagna and mtaylor
- 3
10 minutes ago, mtaylor said:
It may be a pig, but from here, it's coming out looking great.
Thank you kindly Mark, forgot to say I have also been working on some of the panel lines.
OC.
- popeye the sailor, mtaylor, Canute and 1 other
- 4
That's because you are a modeler, OC. Assemblers don't want to take the time to make things fit, modelers do.
Thanks mate.
OC.
- mtaylor, Canute and popeye the sailor
- 3
19 minutes ago, CDW said:
Your sanding and filing nailed it. Beautiful fit.
Thank you craig, I understand the Revell Mossie kit is renowned for being a bit of a pig to fit in some areas namely the Engine/undercarriage nacelles, and at the same time the joins with a little care are bang on.
OC
- Canute, popeye the sailor, lmagna and 2 others
- 5
All your hard work and attention to detail is paying off phil.
OC.
- Bill Morrison, Sundt and GrandpaPhil
- 3
HI all,
I had a battle on today - trying to manipulate the engine/undercarriage nacelle to fit the wing (its a notorious bad fit) I had to dry fit - dry fit - dry fit etc etc etc and file/sand away till I managed to get it to fit requiring just the smallest amount of filling.
Firstly I glued the front end and aided by the hairdryer and some gentle pressure it glued down, then I pushed down the back end and secured with a seam of fine glue.
The idea with the hairdryer is to make the glue mimick a heat gun by where the glue sets quicker by being hot, and cools quickly as set.
OC.
- Edwardkenway, mtaylor, Jack12477 and 7 others
- 10
Count me in - I too have done some Armour in the past from 1/72 diorama's to Tamiya 1/35 scale tanks etc.
OC.
- mtaylor, CDW, popeye the sailor and 2 others
- 5
1 minute ago, CDW said:
I have no experience with it whatsoever.
I know as much knowledge about Airbrushes as I do Knitting - never ever picked one up or used one, it took me fifty odd years to even use a Rattle can, everything else till now has been painted using brushes including 1/144 scale airliner kits like B747s.
OC.
I have been looking at Airbrush starter kits but how convenient are they to use in a living room - noise etc?
OC.
Good day all, more work on mossie, - I assembled the other wing starting by fitting the flaps together, at the same time I painted and placed the wing radiator in place, then after cleaning the seams up - the wing was joined together with the flaps trapped inside.
I also cleaned up and painted both engine nacelles.
OC.
4 minutes ago, mtaylor said:
Thanks OC. I'm still going to stand in the corner... Amazing how things get twisted from mouth to ear to mouth ad innfinitum ad nauseam.
Not your fault bro, no need to stand in the corner - take a seat on the hammock instead,
OC.
Clotilda by popeye the sailor - Steingraeber - 1:60 scale - slave ship - modified Agilis kit
That planking looks sweat denis.
OC.
