Vought F4U-1D by Papa - Tamiya - PLASTIC
Old Collingwood replied to Papa's topic in Completed non-ship models
Heres one of the FAA ones over here at the FAAM museum Yeovilton - well worth a visit with near on 100 aircraft on display. Internet photo - not mine. OC. -
Probably the Brits clipped wing versions would have helped thier handling and stowage on RN carriers. OC. -
My late farther told me they also had one of the best power to weight ratios, no doubt due to that stinking huge lump up front, owe also wasn't they made of Alum? OC. -
The UK had them also used in the FAA some were based at HMS Daedalus. OC. -
This will be gorgeous. OC. -
Nice work on the tops - that stuff from Syren looks tasty, I never thought to order different thread/ropes - I just use watery pva to de fuzz the thread that came with some of my kits. OC.
- 961 replies
Good day pirates - more work over the last two days - anyway I have fitted the mizzen mast lower shrouds (minus the ratlines) they are loose and not lashed to deadeyes yet, I have also fitted/lased and tied the main- lower mast side backstays to the channel deadeyes, I have also attached the two upper mast side backstays and lashed them to the deadeyes - these will be tied to the back channel deadeyes then tentioned at the same time tentioning the main to foremast stay. Pictures later. OC.
A bit more progress this evening - I constructed and fitted both sets of lift blocks and also fitted the upper shrouds around the mast heads, and also fitted the main to foremaststay. OC.
Kevin from here would be a mine field of knowledge being an ex submariner - supprised he hasn't visited yet. OC.
Count me in closest thing I built was Airfix 1/600 Ark Royal. looking forward to following this. OC.
- 345 replies
- graf zeppelin
- trumpeter
Right then folks inlight of my nasher woes - I got some more work done on the pearl, I made the upper gallant mast by making a wood dowel mid section between both tops sections, this was then painted and weathered - this was put to one side while I measured up then worked by shaping the topgallant yard, this was also painted and set aside to dry. I decided that it would be easier to fit the yard to the upper mast while loose - so I semi glued it inplace with a dab of ca, then lashed it inplace. Here are a few pics showing it dry fitted inplace - its starting to gain some hight now. OC.
Thank you piet, yep its a crazy cazy situation guess they dont want us to either eat or smile - or both. OC.
