Old Collingwood
  1. Thank you so much for that my friend - just hoping the lack of level with them is not too bad. OC.
  2. Good day all, sincerely thank you for all the likes and replies, So more work on the shrouds - this is not the most straight forward part of the build - keeping the deadeyes all level when under tension is not easy, also the tops of the shrouds where they rap around the mast heads - they tend to throw out the shrouds stopping them from laying flat with each other, I guess I will need to lash some some thread around the top of the shrouds to pull them all level. So four done on each side with two each painted as they should be - two more to be done, then onto the mainmast Heres the pics - OC.
  3. Another excellent build - I have my chair all set up mate. OC.
  4. You should be proud of that - what a fine job. OC.
  5. She is looking Superb mate - the extra effort with the weathering sure makes all the difference. OC.
  6. Can only agree with hamilton as we both had/have connections with this build. OC.
  7. I diluted in the jar - if you have an empty jar I just put half the original paint in and top up with distiled water, then just thoroughly mixed it, that way I have a half jar of un diluted for small areas than need a thicker bit of paint, and a full jar - diluted. OC.
  8. Evening all, not much to say realy - just shroud number two done both sides. OC.
  9. Another welcome from the UK. OC.
  10. So plan for tomorrow - carry on working on the foremast shrouds. OC.
  11. Carl, EJ what I did was to bend the one block over till it was facing the other one (carefully not to break it off) that gave a controled way to fit the ropes - I just dabed abit of ca on each end of thread then squeezed it between my fingers, this gave a finer point to the thread - I then passed it through both blocks then back through the same hole and glued both sides - then cut off the ends and pushed the small offcuts into the holes and added an extra dab of ca - it worked ok I think. OC.
  12. Evening all, a bit more progress on the pearl today - my next move was to create the mizzen - main stay block, this was again done using the kit plastic blocks that where laced with black thread while still attached to the fret, after attaching and adding a few dabs of ca, I then painted the block assembly. After doing this I fitted the mizzen stay and looped and tied it off with a dab of ca - then I did the same to the mainmast with the block, after I tentioned it and connected at the block. Just the three pics including firstly the block assembly. OC.
  13. I used Lifecolor Acrylics for my Warspite build and brush painted all the top and hull with them, my tips for this was diluting the paint 50/50% with distiled water - then apply thin layers that at first look patchy, a dried inbetween layers and soon the thin layers smoothed out with a good flat layer. My rules to myself was - to work in controled areas, not to load too much paint onto the brush, keep the area to be painted clear from dust (drying with a hairdryer helped this), and not to go back over an area when it was becoming tacky during its drying. OC.
  14. Evening all - more progress on the pearl, I decided before I could continue with the foremast shrouds - that it would make sense to build and fit the mizzen mast including the two sets of lifting blocks, after painting and weathering I glued it in place. Next I turned my attention to the foremast - the idea is to brace both sides and forward so its tentioned correctly for the rest of the shrouds, I did this with a length of thread wraped around the head and ran down each side tentioned and tied, this is just a temporary line and will be cut away when all the fore-shrouds are inplace. Heres the pics - OC.
  15. Crikey - Thats an Armada - what a Superb collection not to mention all those thousands of hours building them - amazing. OC.
  16. Such a strong plane and so versatile no wonder they carried on for so many years. OC.
  17. She is looking Superb craig great painting also. OC.
