Old Collingwood
  1. Can only agree with hamilton as we both had/have connections with this build. OC.
  2. I diluted in the jar - if you have an empty jar I just put half the original paint in and top up with distiled water, then just thoroughly mixed it, that way I have a half jar of un diluted for small areas than need a thicker bit of paint, and a full jar - diluted. OC.
  3. Evening all, not much to say realy - just shroud number two done both sides. OC.
  4. Another welcome from the UK. OC.
  5. So plan for tomorrow - carry on working on the foremast shrouds. OC.
  6. Carl, EJ what I did was to bend the one block over till it was facing the other one (carefully not to break it off) that gave a controled way to fit the ropes - I just dabed abit of ca on each end of thread then squeezed it between my fingers, this gave a finer point to the thread - I then passed it through both blocks then back through the same hole and glued both sides - then cut off the ends and pushed the small offcuts into the holes and added an extra dab of ca - it worked ok I think. OC.
  7. Evening all, a bit more progress on the pearl today - my next move was to create the mizzen - main stay block, this was again done using the kit plastic blocks that where laced with black thread while still attached to the fret, after attaching and adding a few dabs of ca, I then painted the block assembly. After doing this I fitted the mizzen stay and looped and tied it off with a dab of ca - then I did the same to the mainmast with the block, after I tentioned it and connected at the block. Just the three pics including firstly the block assembly. OC.
  8. I used Lifecolor Acrylics for my Warspite build and brush painted all the top and hull with them, my tips for this was diluting the paint 50/50% with distiled water - then apply thin layers that at first look patchy, a dried inbetween layers and soon the thin layers smoothed out with a good flat layer. My rules to myself was - to work in controled areas, not to load too much paint onto the brush, keep the area to be painted clear from dust (drying with a hairdryer helped this), and not to go back over an area when it was becoming tacky during its drying. OC.
  9. Evening all - more progress on the pearl, I decided before I could continue with the foremast shrouds - that it would make sense to build and fit the mizzen mast including the two sets of lifting blocks, after painting and weathering I glued it in place. Next I turned my attention to the foremast - the idea is to brace both sides and forward so its tentioned correctly for the rest of the shrouds, I did this with a length of thread wraped around the head and ran down each side tentioned and tied, this is just a temporary line and will be cut away when all the fore-shrouds are inplace. Heres the pics - OC.
  10. Crikey - Thats an Armada - what a Superb collection not to mention all those thousands of hours building them - amazing. OC.
  11. Such a strong plane and so versatile no wonder they carried on for so many years. OC.
  12. She is looking Superb craig great painting also. OC.
  13. Cutty Sark would be good with her being local for reference photos, I went over her when I was very young and was equaly impressed just like Vic. OC.
  14. The only pearl wood kits I have seen are pirated and not welcome on here I understand and I am not skilled enough to scratch build one, I will use what I am learning with rigging the this pearl - and put it into my two other builds - the one thing I have learned from my model of the pearl - I think my Greyhound is too scale width (short) her scale beam should be wider I think as she looks far too narrow. OC.
  15. Thank you so much Kevin, I still have my Corel Greyhound and Peregrine - both wood kits - both roughly 1/90-1/100scale builds. This other one Kevin - OC.
  16. Thank you wallace - we managed to get something sorted. OC.
  17. Thank you sincerely mark, yep im quite enjoying the rigging as its not just a visual thing but starts to be more hands on with the different ropes and what they do. OC.
  18. So - with my build - I will have to continue the shrouds for the foremast - before I get around to doing that would it make sense to tension the mast by running a temporary thread down to the last deadeye (that does not have a shroud attached) my thinking is it will keep a even tension for all the shrouds sharing the same channel. OC.
  19. We wont freeze - the temp has warmed up slightly, we also have a wheel around calor gas heater that we keep for emergencies. OC.
