Anchors, so today I assembled the two kit anchors each comes in four sections, first thing I had to do was round off the shank as it had a square section, I then did abit of smoothing to hard edges then I glued the arm to the shank, the stock was in two sections this was wrapped around the shank and glued, the stock had molded on lashing ropes - instead I sanded it all flat and lashed it myself using fine black thread. Next off painting/weathering. Just the two pics. OC.
Probably already explained this - a cure for fraying threads used for our ropes - spread watered down pva into the thread between yor fingers, it smooths the thread yet it still reamins flexible. OC.
Thank you Piet, its amazing what can be done with an already very well constructed kit - it makes detailing it so much easier. OC.
Right then plan for tomorrow - Im going to try some knitting - only joking, I am "wait for it - wait for it" going to build/paint/weather and fit the anchors as the cables are there so is the cathead. OC.
Thank you so much for saying that mate - getting compliments like this is just so inspiring, and puts a smile on this pirates face OC.
So I got my second wind - so I glued inplace the upper/topgallant mast - got it ligned up, then I constructed the front upper stay, first I built the bowsprit block attachment - this forms a triangler rig, then I lashed the top of the upper mast secured it with ca and ran the stay through the bowsprit block, it will be tentioned and lashed when I attach the four side stays down to the deadeyes. Three more pics. OC.
Thats what I thought mark - with the tention off all that standing rigging, I have even braced the inside of the main mast sections where they were two part sections. OC.
More progress today - next was the pre-molded topmast/topgallant, I decided to have a go at replacing the topmast section for a piece of wood dowel, first I cut off the mastcap assembly - then after cleaning it up a bit, I drilled a hole to take the thicker end of the topmast, then I shapped it so it was narrower towards the top, then again I drilled a hole into the top mastcap - after I glued both sections between the wood topmast with ca. I decided to use the plastic topgallant but smeared it with ca and cleaned the exsess off - this helps to strengthen the plastic, I then force dried it with the venerable hairdryer and finished it off by painting and weathering. I then worked on - and fitted both sets of lifting blocks in the same maner as before. Just the one pic today of the unpainted wood topmast fitted. OC.
First rate craftmanship - she is looking superb. OC.
- 961 replies
Yep it is taking A lot more time and concentration but I think its paying off, its also a geat way to learn more about seamanship and nautical terms (before building the pearl if somone had mentioned a Lift - I would have thought - people getting in it to go up or down) OC.
