Posts posted by Old Collingwood
I'm back, I put a handful of figures mainly the 2nd KGL and Lunebourg and some injured on some bottles to hold them, then i mixed up a small amount of my Mig Lucky acrylic flat coat, and did a very thin brush coat, then dried then off slightly with the hairdryer, they will need a second coat tomorrow.
OC.
- GrandpaPhil, mtaylor, FriedClams and 5 others
8
30 minutes ago, CDW said:
You are one of the best model brush painters I have seen, so I believe you will get by just fine without an airbrush.
I have watched some videos of a modeler who works exclusively with brush painting and his work is phenomenal. Yours is and will be, too.
That is suck a kind thing to say Craig - very very encouraging words thank you buddy.
OC.
Hi all, I decided I am going to give myself a good kick and have a go at this build, I have quite a few figures that are painted and weathered and need flat top coating, I have done away with my airbrush system for many reasons, but I can still brush paint the flat top coat as I still have some of it left in the bottle, they will then be put away to fully harden before I remove the bases.
I have been missing working on this but I will be honest I kind of lost my mojo a bit and after packing everything away I could not be bothered to get it all out again, but I will just get out what I need to do these figures.
OC.
More excellent work - loving it.
OC.
- Jeff T, Lee J H and Twokidsnosleep
3
Those are quite a striking difference I have only used a few of the 1/48 scale figures before - I thnk by the ICM range but they where WW2 aircrew.
I tend to work with 28mm figures from the Victrix and Perry ranges and a few resin types that can be a bit over scale compared to the plastic ones, not much help I an affraid - but hopefully there will be more replies.
OC.
- mtaylor, Canute and thibaultron
3
3 hours ago, gsdpic said:
Thanks for the comment CDW and thanks to all the others for the likes and the wows. Not sure my work lives up to a "wow" but I'll take it.
So I said the exhaust was next but I skipped ahead a little bit and worked on painting the wheels. The wheels presented a couple of conundrums.
But first, back when I built the Ferrari shown above, I wondered about the goldish tone of wheels on race cars from around 1970 and google told me all about "DOW 7". For those unfamiliar, the wheels were made of magnesium to reduce weight, but it is fairly reactive to the environment, so the magnesium was coated with some chemical mix to prevent corrosion. "DOW 7" is the current name for one such mix; not sure if that is what it was called back in 1970. It is a sort of non-metallic goldish tan color, sometimes with a little tinge of green, though looking at net pictures of magnesium wheels shows a wide variety of color.
As for the conundrums (conundra?), the various pictures and youtube videos of this car (not to mention models of this car) show a variety of wheels and a variety of schemes for coloration of the wheels, usually with a silver rim along with some parts in a goldish color, and some times black as well. So the first issue was just how to paint the wheels. For the front, as shown, I've gone with a black inner section, gold wheel, with some silver trim around the edge. The rears are a different style and very deep so I did not do the black inner section on them.
The second conundrum is regarding the gold color. Was the gold wheel on the 72D a magnesium wheel coated with DOW 7? Or was the wheel painted gold to match the livery of the car, with the gold stripes? As much as I might have wanted the latter, I assumed the former.
So I started out painting the wheels with the dreaded alclad gloss black, thinking I might be painting some polished aluminum over it, though that did not occur. I then did a light mist coat of flat "German Grey" Tamiya paint just to knock down the gloss and blackness of the inner part a bit. Then I masked the inner wheel section and painted the wheel with Alclad's "pale gold". That was the first time I used it, and I have to say it went on beautifully. At that point I was tempted to pretend the wheels were painted gold to match the livery and let it go. But no, I continued with my original plan to attempt to make the wheels more "DOW 7"ish, and put on a mist coat of Tamiya Flat Earth with a couple of drops of green in it. Finally, I went around the rim of the wheel using the molotow chrome paint marker. Below is what it looks like now. I'll likely go over the rim with another pass or two of the molotow paint marker and then maybe shoot the whole thing with a semi-gloss clear coat. But, even as is, I am quite pleased with how this came out.
If you made it this far, thanks for reading this overly long explanation for painting a wheel
Typical Lotus wheel colours.
OC.
Excellent work Kevin - really nice and tidy.
OC.
- mtaylor and Knocklouder
2
Absolutely Gorgeous, spot on work.
OC.
- CDW, Canute, king derelict and 2 others
5
Battle of Waterloo Attack on La Haye Sainte Farm by Old Collingwood - 1/56 (28mm)
in Non-ship/categorised builds
Posted · Edited by Old Collingwood
Thank you so much Mark mate, indeed it was a bit like loosing the interest a bit - I am sure I heard the figures stamping their feet and sighing.
OC.
