alross2
Posts posted by alross2
  1. The bobstay irons are going to be a bit fiddly to install. The arms are trimmed to length and a .020" hole drilled at the end of each, then through the stem. A pin is inserted through the three holes, glued to the arms and snipped off. By allowing them to pivot, it makes setting the angle easier when the bobstays are attached. Once they are in place, the irons can be glued in place.
  2. There are 120 holes in the cap rail for belaying pins. I decided not to laser them in because of the potential for breakage. So, you have to drill them but there is a template in the kit that will make this less challenging. You align the first two holes with the space between the stanchions, drill the first hole, stick a belaying pin or piece of rod in the hole to maintain alignment, hold the template in place, and drill away. It actually only takes a few minutes and everything is consistent.
  3. Stack brackets are installed. These are made from 1/64" x 1/16" britannia strips bent over a jig (included with the kit) and trimmed. As an aside, forceps are great for holding items for painting. These are cheap ones that I toss in lacquer thinner after I'm done painting. They clean up easily and can last for years.
  4. Rather than spend hours looking, I thought I'd start here first.  The plans I'm using to develop the kit of WYOMING were drawn by an actual schooner captain who is also a well-known researcher, so I have a warm fuzzy about their accuracy.  There is no belaying plan, but that is not much of a problem.  I can figure that out based on rigging plans for other schooners.  The main problem is that there is no indication of where the halyards on the forecastle mast (that's what P & S called it, as well as #1) tie off.  The plans do not show a fife rail nor a spider band on this forward-most mast.  Like many schooners, this mast passes through the fore house and the boom jaw rest is quite close to the roof.  WYOMING was flush-decked and did not have bulwarks, only a rail with stanchions which doesn't sound strong enough to support pin rails.  There are no indications of pin rails anywhere forward.  There are two large wooden bitts just forward of the house, each having two belaying pins, but this doesn't seem like enough to be the belaying points for this mast.  So, does anyone have an illustraton of this particular configuration that would clear things up for me?
  5. Made two new templates for setting the chain plate angles. One is for the forecastle mast, the other for the other five masts. The top of the template corresponds with the slots in the channel while the bottom corresponds with the bottom of the chain plate, You just align the top section with the channel slots and use a pin or ,020" drill through the bottom holes to mark the position of the lower part of the chain plate.
