alross2
Posts posted by alross2
  1. Test fitting the photoetched railings to the hurricane deck. There are four pieces per side and they are designed to fit in specific locations. This will require some careful bending and fitting to get them right. The end stanchions are a bit longer than the rest, so locating holes have to be drilled in the deck. An inclined ladder fits in the opening.
  2. Once the holes for the main deck stanchions are drilled, the holes in the side of the hull for the awning stanchions are drilled. The blue tape ensures that they are all at the same level below the deck. Their locations are marked on the template. Both types of stanchion have a mechanical stop on their bottoms to ensure they are at the same height.
  3. 4 hours ago, lmagna said:
    . He also wrote the Richard Bolitho and Adam Bolitho series under the name of Alexander Kent writing 68 novels!
    Strangely, I absolutely loved his Richard Bolitho novels but couldn't even get through one of his MTB ones!  Since I focus on this type of vessel, you'd think it would be the opposite.  Maybe I should try to read one of the MTB novels again.
  4. On 6/6/2022 at 9:56 PM, rudybob said:
    I'm not interested in doing it as 109. I want to label it 34, 35, 36 or 37 which were if I recall accurately the PT's that got MacArthur out of the Philippines
    The RON3 boat were 77' ELCOs; this is an 80' ELCO.  In the movie, they used two 80s and four Huckins boats, none of which looked like a 77'.  Here are two renderings of what they would have looked like.  The gray image is as they left the factory in Bayonne.  Once the war began, they removed the domed covers on the turrets and painted the boats green.  My Dad was the quartermaster on PT34 at the time.  She was lost on 9APR42 and he was captured a few days later, spending the rest of the war as a Japanese POW.
  5. OK, WYOMING is going to Nic for rigging, so I'm back full-time on OREGON. Today was mostly printing out plans and parts lists and getting my head back into OREGON. Painted up a bunch of castings and started applying the photo-etched 6" casemate doors. There are five doors on each casemate, which is curved, so it takes a while to get them lined up.
  6. Aligning the masts. It's a simple approach but works well. The forecastle mast was set at the correct angles first, then the rest of the masts were aligned with the distances between them at the boom jaw rests. The clamps keep everything aligned while a drop of glue sets the angles.
  7. The spring stay bails require a little patience and care to build. They are laser-cut .020" laser board but are surprisingly strong and flexible. They are best built off the mast. Two eyes are glued together, a light coat of thin CA is applied to them, then they are bent over a dowl (front bail) and 1/4" square stick (aft bail). The mast is drilled with a .022" bit, the bail is slid down over the mast, and a pin goes through the holes. Once everything is aligned, CA is applied to the end of the pin and the end is snipped off.
