Javlin
Everything posted by Javlin
  1. I am not the best photographer maybe some outdoor pics later.........now others it seems have a steadier hand than I but were the wires feed in the back I cut off the stubbs ,drilled .020",inserted hollow rod and then the wire.I like the Quinta kit for the big slides but had a nob break while fiddling with the IP the thin pieces break fairly easy or maybe just fat fingers
  2. If you never mentioned it Dmitri I wouldn't of known any better doing some Nice upgrades.I built this one a couple years ago but not as many upgrades still came out quite nice though.
  3. Mike be very careful when rigging on the stress you impart on those little arms coming off the SS I think 3/4 lines on each side one of mine came loose.
  4. I started this build last night not much Russkie in the collection either this will be my 2nd SH kit to which I have a few limited run kits in the collection waiting to be built.I will be using for the first time the Quinta Studios copit it adds some nice details.I may play with the wheel wells have seen some Nice enhancements done by on builder.The Qunita people say to paint first then overlay the decal that started last night with the grey to which the instructions say to use a light gull grey I opted for neutral grey a tad darker.
  5. Thks Lou and for those that looked in just some works to keep those idle hands busy.
  6. I started these awhile back when the Mossie's engines started bogging me down.The Hurri with the pods is 1970's Revell,Hurri with 20's HobbyCraft 1990's (got both for $10) and the Blue Hurri is Malta Italeri Nice Kit! I hardly had any Hurri's built in the collection so it was like WTH.I can't tell you how many times I wanted to ditch that Revell was doing the build because I did it as a youth.The decals were old and very thin and the glue was coming off white as slide them in place hence I do not think any on the fuse are really straight!!They will look the part in the cabinet no contest winners that's for sure.
  7. Going to use the EZ line for the rigging makes it easy used it on my last two ships.
  8. You know Guys just a little tidbit I have noticed from the newsreels of the times when you watch the factory workers clocking in they are not heavy set!The diet back then was so much better than today's methinks a small observation.
  9. Well to be honest brother when you are mastering the 1/700 scale Dios are next they can look so real it's unfathomable that's the next leap.
  10. Craig this is looking really Good I have done some 1/700 but not to the extent you are going just some rails and ladders I would be blind by now! Top Shelf Stuff!!
  11. That would be if one was still looking for brownie points not the case anymore so name her after an ole Girlfriend the wife knew Kevin murder on 34th street
  12. Something about building these old kits it's called .............nostalgia! I have two Hurries on the desk getting decaled one is the the ole Monogram about 66-72 abouts.I have one done and two to go all Africa and Sicily will be looking in if you don't mind. Kevin
  13. In the states acrylic is on the rise Testors the company I have used for 50+ years is fazing out it's line of paints I think they were bought out by Rustoleum?I agree lost one airbrush my first was 30years old to acrylics forgot to clean it IF I do that with lacquer and come back the next day no problem and it happens.I order Rie Field kits tonight Kevin
  14. Dan was the Grand Daddy of card modeling and a Gent to boot.
  15. Like the results Jorgen esp.like the subtle weathering! Kevin
  16. It must be the train thingy I like these old cars if that's the right term nostalgic methinks. Kevin
  17. Looking the part thus far.I have been using lacquer paints all my life shame they are on the way out by most companies.Will poke a head in occasionally Kevin
  18. Sounds like Guberment all sounds interesting will be popping in Craig/Lou Kevin
  19. Thks Dan.I have it on good advice from the fella in Canada working on the restoration of a Mossie up there straps area grey-green so they were completed last night and the wing finished and fitted to the fuse just not glued up yet.The engines ......how far do I go? Kevin
