Javlin
Everything posted by Javlin
  1. I like the looks of things Gary and leaving the pins the brass gives it a nice touch.I have a brother down your way in Merrit Island has a sail shop been there since the early 80's. Kevin
  2. Regardless would be a NICE mantle piece with the lighting!To many lifeboats (so I jest) the life boats need help oars,covers I sure the aftermarket world will chime in.Me I have a HK 1/32 B-25 along with some other big scale A/C I need to finish before I throw out more bucks.
  3. Whats those build were it's just the hull,deck and part a mast??? This is one
  4. I p/u this little gem some time back and I like this scale 1) If you just want to build and that's it wal la 2)you can detail and make a dio which I think is were I want to take my skills? So this is a test run got Big Mo in there on one pic which will be my second water dio with a destroyer escort.I have about 10hr in the Maya ATTM.Thks for looking I do have some generic 1/700 railing the Maya will get and she will get some rigging ..
  5. I have had this come up when laying a gloss black sometimes that is really akin to a real lacquer paint meaning it it has a fast drying agent smell almost like acetone.The paint in that case can glob on the my Badger Airbrush little tips on the edge and I had a car painter on another forum it was humidity and temperature so now it's cold in my room.But ,back to the pebbles don't go the sandpaper route quite yet go to a paint shop or parts house and get an 800 grit scotch brite it contours to the plastic and levels the paint it's a must when I do Alclad silver on my aircraft before the silver goes down and the more you use the softer it gets. Kevin I tried some AK paint on a little F-6AQ Recce Mustang just for the wing bands straight from the bottle no thinning sprayed smooth and level kinda liked it.I spray enamels mainly Model Masters or Humbrol and what I like about enamels is you have all night before you have to clean your gun unlike your acrylics you have to be quick.I lost one badger airbrush because I was not through enough and the needle seized in the gun(I broke the brass w/nut twisting) and all I had to do was soak it in ammonia.
  6. Give it a little while Rich read maybe or look at some unbuilt kits.get well.
  7. That was going to my suggestion use it alot in wing roots when they pop up trim/sand.
  8. Been there done that on some plastic it happens.
  9. That is a very Nice Build you got going Dick!You do very precise/clean and a well thought out piece of art/work Kevin
  10. Semore came out fantastic Build Sir and Finish!! What are you doing for a case? Kevin
  11. She's a beauty alright.I love the colors of this ship when any of you guys build her,she will be a stunner when finished Sir Kevin
  12. If you are concerned about it Smore the very bottom of the pontoons would be the same color as the bottom of the plane and it shows in the pic look at the forward part of the back pontoon and the piece jutting out the bottom of the front pontoon at the rear.Camo.
  13. work continues today with airbrushing sky grey for the last time... im a little sad. hey proud you should for finishing the job with dedication both to the build itself and working to make it as authentic as possible for that I give you an A
  14. Scott I thought the it looked kinda good with paint missing like another touch of weathering?Probably esp. after you highlighted it some more? kevin
