very nice work Nils........been out of the loop for a spell,  so I had quite a bit to catch up on.  she's coming along really great though and I see you've already started with your fine metal work ;)   the stern is looking better and better with every bit of detail you add to her.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Fantastic job, Can't wait until the hull plating starts!
Regards, Scott
Completed builds:
Awaiting construction:
Thanks for looking in Denis and Scott,
and all the "likes"...
Denis,
I have the wooden hull smooth and treated with filler where necessary, all is covered with one coat of nitro- Wood-bounder, to fix the grain.
The forecastle deck is very much rounded down to the sides typical for this ship (like some fishing Trawlers have), that is what I`m working on right now. These rounded side Areas of the forecastle deck will be plated as well...
Scott,
thanks for dropping in,....
The plating of the hull still needs to wait until I have the decks on, and the upper two rails mounted to the sides
Nils
Ammendment :
here a non scaled hand-scetch for illustration,,,,
Edited by Mirabell61
Current builds
-Lightship Elbe 1
Completed
Hi David,
I use Aluminium metal foil for the plating,
please have a look at the examples in my "Pamir" build log beginning there on page 4 with post #65 of that log and onward....(link in my signiture)....
Nils
Current builds
-Lightship Elbe 1
Completed
Build log part 14
preparing for the decks, cutting out card templates, will be using 0,8 mm ply and plank this with 1 x 2mm scaled pine strips, pencil "caulking" at the plank edges
Nils
inbetween I do 2 more windows at a time...
the forecastle card template and  half the front waist template (one deck lower). The outer limiting timbers (forecastle sheer) will be shaped to fit the rounded transition from hull to deck
half poop deck template
Current builds
-Lightship Elbe 1
Completed
Hi Nils
It looks like you're off and running, now that the hull planking is done (in readiness for the plating) and you're onto the deck templates.
The brass windows look great, as well. Out of interest, how long would it take to knock each window up? I dare say you've got a few to do, so time minimisation would be a good thing.
In terms of the overall appearance of the hull so far, the last photo above really gets my heartrate going. Not only is the hull sleek, but she's shapely as well.
Lastly, have/would you at some stage consider converting her into an RC model?
Cheers
Patrick
Edited by Omega1234
Thanks Patrick,
in answer to your questions...
the average time for a window like this is 15 minutes, and there are (my Count)  84 of this type, so that makes 1260 minutes = 21 hours
Yes, I have thought of RC Controlling, because the  propshafts  are functional, but I would have had to add some complicated gear System to the ruddershaft, inside that tail-cone. So I rejected that thought at an early stage already, I also trust that the ship will be much to fragile for water contact. Also I do`nt know how the plating (adhesive gluefilm) would behave in water...
Nils
Current builds
-Lightship Elbe 1
Completed
What beautiful lines, I can see why you wanted to build her.
Bob
Current build:  SS_ Mariefred
Bob
exactly Bob,
I think the lines of a ship are one of the first impressions that the eye recognizes, I just fell in love with these lines...
Nils
Nils
Current builds
-Lightship Elbe 1
Completed
And that's the way it should be for all of us.
Bob
She's going to be a beauty, Nils.  Lovely lines and your usual excellent details are already showing up.
Mark,
Thanks very much for your appreciative words,...
Nils
Current builds
-Lightship Elbe 1
Completed
Pits propeller??
No,
general fixed pitch prop design on screw driven steamers around year 1897..
Nils
Current builds
-Lightship Elbe 1
Completed
Update for forecastle- and first waist deck,
It all looks a bit rough in the moment, The front waist-deck was made to the card template and can now be removed for planking. Need to check the hights with the little 1:144 figurine
The forecastle deck will need the anchor tubes with suit taylored outlets to the bow sides fitted in, before it is planked( only about 2/3 of it`s area (pics will follow later on )
Nils
my little room for the rough work
I fixed a preliminary,horizontal  (loosenable) steel-rail, to which the drawing can be clipped (magnets)
The funnel arrangement in two groups provides the first class dining resaurant and lounges to go over the full width of the ship, this has been well accepted by the passengers, This design had also been adopted for the follower liners of the Norddeutscher Lloyd, and gave an unmistakenable silhouette for identification from the distance
three deck high, and over the ship`s width, the 1 st class dining saloon
the little white figure is used for determining the correct deck-highjts
here the deck curvature can be nicely seen
when clicking on this pic (to enlarge) the hand drawn frame distances on the drawing can be seen. I chose 26 frames over the ship`s length
Current builds
-Lightship Elbe 1
Completed
Hi Nils
Thanks for the update. Nice progress! I like the idea of being able to hang the plans, so that it's easily studied.
Also, I never realised how big the ship must have been untiI I saw the scale sized figurine.
Cheers and all the best!
Patrick
Edited by Omega1234
Your model is really taking shape I can hardly wait to see the super structure. Good idea to use a scale figure to determine deck height.
David B
She's coming along nicely, and she's being build in a fine space.
Bob
Many thanks to Patrick, Ioannis, David and Bob,
and the "likes"...
as the outer deck railings will be only 8mm high, I decided to favour rather foto etched stripes from copper sheet. instead of built railing with stanchions. Have to work out a suitable way to fasten These to the related hull /deck Areas. The ordered samples unfortunately did`nt arrive this week. The upper most of the 6-chord railing is the handrail which is of Wood on the actual ship, but in scale 1:144 I`ll have to put on a very small U-shaped brass liner stradling over the upper edge, and paint it in wood color. (at least thats my Intension, if there comes no better solution to mind)
Nils
Current builds
-Lightship Elbe 1
Completed
Thank you for your Input Larry,
maybe I`ll go for your suggested solution,......
but I`ll try the use of a mini L-angle brass Profile to the deck , so that the railing stripe can be carefully spot soldered to it, if it wo`nt look too messy afterwards. if the L-rail perhaps is soldered on to the railing stripe first, the other flange of the re-drilled profile could be pinned to deck for fastening (going to be a tricky excercise anyway...)
Nils
Current builds
-Lightship Elbe 1
Completed
Build log part 15
Status update:
today I cut into the hull sides at the waist areas, the front area lowest point, right down to the deck and the aft Area, leaving an 8mm high bulwark standing. Next will be the deck-planking job in these waist areas. The raw decks  were dry-fitted and are ready for planking
Unfortunately I found no figurines in scale 1:144 in fashion of 1900 clothing, pleas, does anybody know where to find some ?
The only ones I found are out of the airlines scale figurines, and I`m not so fond of military figurines, but I´m happy to have some at all for dimension checks
Nils
a Dremel grinder is good for this work
the second raw deck is laying on the second stringer from top, the upper stringer has been cut away, so the remaining bulwark is flush with the inside of the side planking
the port side will have to be brought to the same status
the 8mm raw-bulwark is in hight slightly above figurines waist hight, handrail still to be fitted
the forecastle deck is still a card template
Current builds
-Lightship Elbe 1
Completed
Hi Nils
Now that you've cut the hull sides, as per necessary, to create the bulwarks, it's all starting to make sense now.  I must've been a bit thick, but I couldn't quite understand why your hull plating had to be put on hold until the decks were laid out.  Now, of course, it all makes sense!  Definitely one of those 'lightbulb' moments for me.
Having said that, wow, she looks good.  The bulwarks and the figurines add a tantalising glimpse of what the completed ship's going to look like.
Nice!
Cheers
Patrick
Edited by Omega1234
thanks Patrick,
the work now is quite a long haul job to get all the decks to fit. B)  I plank the decks before mounting them, so  they can be sanded smooth and sealed with a dull varnish. All walls, deck bulwarks and -housing go on top of the planked decks. When the decks are on for permanent, there will be several rails to the upper hull sides. The metal plating does not go over the rails but fits neatly in between these.
I had a upsetting experience last week, when I had tilted the window of my basement workroom to allow nitro fumes of the wood sealing primer and it`s nitro smell to escape over night ^_^ ......
In the meantime we had much rain and bad weather, so that the high ambient humidity fell through the tilted window into the basement room just looking to settle on and in my hull. Next morning some of the longitudinal white glue joints (planks glued together at the edges as well) suffered swelling from the moisture a bit, and the nice smooth hull felt as if it needed a sanding and fairing session again  :o
I decided to leave as is, watch it over the week, hoping the glue swell will go back by itself. and to use watertight white glue (propeller glue) next time. Its getting better now day by day
Cheers,
Nils
Current builds
-Lightship Elbe 1
Completed
