Yeah ,my bad I was thinking you were using a closed mold for a whole boat. But, I looked back and saw your method. I was trying to make 192/1 landing craft and having a terrible time with fast setting resin. The project is really coming along nice I spite of all the help you're getting from us. =)
Bill, in Idaho
Completed Mamoli Halifax and Billings Viking ship in 2015
Next  Model Shipways Syren
My thanks go to Rob and Bill,
and all fellow members who gave their kind input, suggestions and comments for boats making... recently
Also thanks to all the "likes"...
Rob,
good idea with the vibrating palm sander, I must try that, and save in mind..., I was already thinking of what I possibly could use exactly for that purpose...
Bill,
the additional plug still requires some corrections, but I think in general it should work as intended. After glueing the halves together I will remove the center area of the halfmoon like top cover until only the rail on the sheer remains standing. Here in the white sample there is no inner bulwark support, whilst the translucent sample was made from the modified plug with 8 slots to resemble the ribs...
Nils
halves ready for fairing sanding the to be matching glue surfaces
here 5 completed boats
The upper sample with reinforcement ribs
the additional plug for hanging / fixing into the silicon mold
now that it works, the other side of the plug will also get outcuts
Current builds
-Lightship Elbe 1
Completed
Such great progress since I last looked in ;)    your boats are coming out very good......future boat needs will be a lot easier now.    super trip you and the admiral went on.....thanks for sharing :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks very much Denis,
for your kind comment, much appreciated...
Nils
Current builds
-Lightship Elbe 1
Completed
Outstanding model and beautiful impression with the crew on decks. You did a great job.
My admiration, dear Nils.
Kind regards,
Doris
Doris
Current build:
HMS Royal Katherine 1664 from card
Kind regards,
Doris
Doris,
thank you very much for your nice compliment, for looking in and your interest for this build, much appreciated...
Nils
Current builds
-Lightship Elbe 1
Completed
Update :
here, the first one of the raw open boats. I think I`ll place one or two open boats later on each side of the ship...., most of the others will be closed and canvas covered boats
Nils
This is the same silicon mold as for the closed boats, but here additionaly a plug is inserted and fixed in position, before the resin is carefully poured in....
The result out of the silicone mold...
and after pulling the plug out
the two halves are glued together and the decking cover is milled out with a Dremel
seatings a bit broader and thicker, capacity, when full occupied 26 persons
Current builds
-Lightship Elbe 1
Completed
Hi Nils
Well done! With a little amount of paint they will be perfect! I like the boats.
Regards
Gerhard
Problems just mean: solutions not yet found
Models in progress
SMS DANZIG
http://modelshipworld.com/index.php/topic/12842-sms-danzig-1851-by-gerhardvienna-radio-150-scale/
USS CAIRO
http://modelshipworld.com/index.php/topic/13282-uss-cairo-by-gerhardvienna-live-steam-radio/
Baby Bootlegger 1/10
http://modelshipworld.com/index.php/topic/13625-baby-bootlegger-110-radio-by-gerhardvienna/
Swiss paddlesteamer RIGI 1848 1:50, after plans from the Verkehrshaus Zürich, rescaled to original length
Anchor tugboat BISON, 1:50, plans from VTH, scratch
Finished models
See-Ewer ELBE, Constructo kit 1:48
German fastboat after plans from german Reichskriegsmarine measure unknown (too ugly to show up!)
German traffic boat for battleships WW2, 1:50, after plans from Jürgen Eichardt, scratch
German Schnellboot TIGER P6141 VTH plans, scratch
That is very slick, Nils. Can't wait to see them finished
Carl
thank you very much Gerhard and Carl,
a little bit of experience could be gained with the use of silicon and resin for the fist time, so if boats should be required again, there could be some optimizing of the process.
There are still tripple stacked foldable boats (last in the row on both ship sides), but I have to do a master boat set first....
Nils
Current builds
-Lightship Elbe 1
Completed
"There are still tripple stacked foldable boats"
now that will be interesting!!! Will you make them tripple stacked in the mould, or stack them after you made them ...
Carl
Thank you much Kees, Carl and John,
for your nice words...
Kees,
in the beginning it was a little strange to work with silicone and resin, but now have addopted this procedure in my repertoir....
Carl,
I presume that the foldable boats will be single production and then stacked, might be easyier to produce
John,
thanks for catching up, you`re always wellcome...
As I already learnt a lot of english terms from you already, please may I ask, if the halfmoon like handle ropes (for people in the water) around the boats are called "grab ropes", or if they have a special term ?
Nils
Current builds
-Lightship Elbe 1
Completed
Nils,
These ropes are called lifelines.  Lifeboats on "modern" ships also have grab lines (which are never seen on models for some reason) which are ropes which run around under the boat from gunwale to gunwale and are for the purpose of righting a capsized boat.  There are usually two grab lines per boat.
John
14 hours ago, Jim Lad said:
Nils,
John
Thanks very much John,
learnt something new again, much appreciated, "lifelines" such an easy word......, also the function of the grab lines makes sense, when trying to righten my sailing dinghi once, standing on the keel I nearly broke the wooden swing centerplate by sidewise hanging my weight to it`s full length standing up, wish I had grab lines there...
For these small resin boats I give it a go for a trial on a scrap part with the lifelines and the seine floats attached, quite a weary process, but I trust the optic will be worth the effort afterwards. For the closed boats the canvas cover may be partialy hiding some of the lifelines
Nils
Current builds
-Lightship Elbe 1
Completed
Nils, another way to fit the lifelines is to just drill a small hole but not put an eye in.  A bight of the lifeline can then be pushed into the hole using a piece of wire and glued in place.
John
John
Hi John,
I took up your suggestion for fastening the lifelines (drilled a small hole 0,6 mm and pulled the lifline rope in with a very thin brass loop and clipped it off at the inside bulwark rail) it will look more elegant now, thanks for your nice tip, much appreciated
Nils
Current builds
-Lightship Elbe 1
Completed
super job on the life boats.......they look awesome! :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Many thanks Denis and Greg,
for your nice comments, much appreciated..
Denis,
they`re missing floor planking, hoisting points and seatings, as well as the lifelines, paint coating and shipsname at the bow
Greg,
maybe (for the open boats) I`ll ty to make some oars and a rudder for putting them loose on the seatings
Nils
Current builds
-Lightship Elbe 1
Completed
Doll-em up Nils........Since you only will have a few.
Rob
Current build:
Finished build:
Current build(On hold):
Nice work on the small boats, Nils.  It is always interesting to see innovative solutions for modeling small scale pieces, and especially when many copies are needed.  You have both these issues to conquer on your model and the results are great.
Ed
Rob
Hi Rob,
you find me a bit iritated with the term "doll-em up"... (pls. give me a hint...)
do you perhaps  mean to put rowlocks on ? In German the term for rowlocks on a rowboat is " Ruder-dollen"
Nils
Current builds
-Lightship Elbe 1
Completed
Ed
Hi Ed,
thanks so much for that nice compliment, yes, the boats are quite a tough sequence to do, and also to get them rigged afterwards
Nils
Current builds
-Lightship Elbe 1
Completed
3 hours ago, Mirabell61 said:
Hi Rob,
Nils
The term is probably American and it simply means to spoof up or make nice.
Rob
Current build:
Finished build:
Thank you Rob,
it is understood, nice comment !
I`ll do my best
Nils
Current builds
-Lightship Elbe 1
Completed
Back with you Nils after my absence. Nice work on all the life boats, something for us to remember trying.
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Cheers,
Thanks very much Piet,
am pleased you like the little boats
also thanks for your catching up on the build....
Nils
Current builds
-Lightship Elbe 1
Completed
Little update...
look of the open lifeboats, with floorplanking, seatings, hoist points, name and port of registration but still without lifelines
Nils
Current builds
-Lightship Elbe 1
Completed
