Hello everyone
I decided to begin construction of Cherful
Current build
Enterprize
Schifetto
Completed builds:
LA BELLE
La Jacinthe French Schooner
Cherful
Tartana Gemma
Carmenia
Salvatore Padre
Tartana Gemma
Bisquine La Granvillaise
Fishing-boat
English pinnace
18th Century Longboat
I bought the designs from the site Syren Chuck.
Unfortunately there are no available pieces in laser cut, I proceeded to cut them after pasting paper forms on plywood
Current build
Enterprize
Schifetto
Completed builds:
LA BELLE
Cherful
Tartana Gemma
Carmenia
Salvatore Padre
Tartana Gemma
Fishing-boat
English pinnace
I preferred to use a construction technique different from that indicated in the instructions.
Typically use this technique for years for the hulls filled.
The technique is to glue the frames and then fill balsa spaces then fill with synthetic filler to have a uniform surface.
in this way laying the boards is very easy, it does not require nailing.
For gluing use then a cyanoacrylate glue
Current build
Enterprize
Schifetto
Completed builds:
LA BELLE
Cherful
Tartana Gemma
Carmenia
Salvatore Padre
Tartana Gemma
Fishing-boat
English pinnace
The hull is then filled with balsa finished with coarse sandpaper, and then finer
after the surface is grouted, and then again sanded, and then stuccoed Finishing
Current build
Enterprize
Schifetto
Completed builds:
LA BELLE
Cherful
Tartana Gemma
Carmenia
Salvatore Padre
Tartana Gemma
Fishing-boat
English pinnace
  • 3 months later...
After the bandage hull I proceeded to lay the underbridge in thin plywood
Current build
Enterprize
Schifetto
Completed builds:
LA BELLE
Cherful
Tartana Gemma
Carmenia
Salvatore Padre
Tartana Gemma
Fishing-boat
English pinnace
Realization of the lower deck and topsides
Current build
Enterprize
Schifetto
Completed builds:
LA BELLE
Cherful
Tartana Gemma
Carmenia
Salvatore Padre
Tartana Gemma
Fishing-boat
English pinnace
Realization of the gunwale
Current build
Enterprize
Schifetto
Completed builds:
LA BELLE
Cherful
Tartana Gemma
Carmenia
Salvatore Padre
Tartana Gemma
Fishing-boat
English pinnace
Realization of floorboards
Current build
Enterprize
Schifetto
Completed builds:
LA BELLE
Cherful
Tartana Gemma
Carmenia
Salvatore Padre
Tartana Gemma
Fishing-boat
English pinnace
Side and special bow
Current build
Enterprize
Schifetto
Completed builds:
LA BELLE
Cherful
Tartana Gemma
Carmenia
Salvatore Padre
Tartana Gemma
Fishing-boat
English pinnace
Construction of a bridge
Current build
Enterprize
Schifetto
Completed builds:
LA BELLE
Cherful
Tartana Gemma
Carmenia
Salvatore Padre
Tartana Gemma
Fishing-boat
English pinnace
superstructure of the bridge
Edited by Iosto Doneddu
Current build
Enterprize
Schifetto
Completed builds:
LA BELLE
Cherful
Tartana Gemma
Carmenia
Salvatore Padre
Tartana Gemma
Fishing-boat
English pinnace
At this point I'm starting to think the window and definitive basis.
I am undecided whether to create a leg with strips square as models of arsenal, or set it on twooo turned columns with screw pin concealed in a more classical.
Could someone give me suggerimentio designs or realizations of stairs?
or on how to make the columns on the wheel?
so big I never made more than anything I want to find some nice drawings.
Current build
Enterprize
Schifetto
Completed builds:
LA BELLE
Cherful
Tartana Gemma
Carmenia
Salvatore Padre
Tartana Gemma
Fishing-boat
English pinnace
  • 2 months later...
Riveting bridge
I tried different techniques to see which one was better.
I made several holes with tips 0.5 / 0.6 / 0.8 mm
I inserted the tip of a graphite pencil in the hole and then I put a bit of glue.
then sanded after this is the effect obtained.
The system toothpicks is great but very long and I did not want to use it.
Current build
Enterprize
Schifetto
Completed builds:
LA BELLE
Cherful
Tartana Gemma
Carmenia
Salvatore Padre
Tartana Gemma
Fishing-boat
English pinnace
Construction of 'winch
Current build
Enterprize
Schifetto
Completed builds:
LA BELLE
Cherful
Tartana Gemma
Carmenia
Salvatore Padre
Tartana Gemma
Fishing-boat
English pinnace
Construction of ladders
I used this system seen in a forum.
It works very well
Current build
Enterprize
Schifetto
Completed builds:
LA BELLE
Cherful
Tartana Gemma
Carmenia
Salvatore Padre
Tartana Gemma
Fishing-boat
English pinnace
Test of of burnishing
I had never used this type of burnishing.
From the evidence I've seen that's not good to leave the piece immersed until the burnishing, but it is best to immerse and then take it off after 20-30 seconds, then go left to air and then rub with a woolen cloth.
after the operation must be repeated 8/9 times to get a good coating.
I had a kind of burnishing that works in one dive, it was given many years ago now is ending and I lost the recipe ....
Current build
Enterprize
Schifetto
Completed builds:
LA BELLE
Cherful
Tartana Gemma
Carmenia
Salvatore Padre
Tartana Gemma
Fishing-boat
English pinnace
Construction of the anchors
I realized the anchors with the bars and plates of brass.
I have realized a form of wood for the curvature.
I soldered the pieces with tin.
After I finished with the drill Proxxon
Current build
Enterprize
Schifetto
Completed builds:
LA BELLE
Cherful
Tartana Gemma
Carmenia
Salvatore Padre
Tartana Gemma
Fishing-boat
English pinnace
Finishing the hull
Current build
Enterprize
Schifetto
Completed builds:
LA BELLE
Cherful
Tartana Gemma
Carmenia
Salvatore Padre
Tartana Gemma
Fishing-boat
English pinnace
Construction of the base
I wanted to make the base to be set out in the window, in order to have the ship on a slipway site.
I wanted to get an antique effect as some models in museums.
I used a wooden base that I covered, cherry wood, with the grain in the central part oriented to the long side, and on the edges perpendicular.
I added a decoration between the two frames
I put the tape to leave free areas for bonding.
The finishing was done with shellac
Current build
Enterprize
Schifetto
Completed builds:
LA BELLE
Cherful
Tartana Gemma
Carmenia
Salvatore Padre
Tartana Gemma
Fishing-boat
English pinnace
Construction winch
Current build
Enterprize
Schifetto
Completed builds:
LA BELLE
Cherful
Tartana Gemma
Carmenia
Salvatore Padre
Tartana Gemma
Fishing-boat
English pinnace
Hull after the finish
Current build
Enterprize
Schifetto
Completed builds:
LA BELLE
Cherful
Tartana Gemma
Carmenia
Salvatore Padre
Tartana Gemma
Fishing-boat
English pinnace
Thanks Chuck
I could not get a clean job like yours, but I'm very happy.
I thank you for having made available to your experience in this beautiful site that allowed me to learn a lot.
Thanks again
Current build
Enterprize
Schifetto
Completed builds:
LA BELLE
Cherful
Tartana Gemma
Carmenia
Salvatore Padre
Tartana Gemma
Fishing-boat
English pinnace
Nicely done, Iosto.    Will you be adding masts and rigging?
