Greetings,
While I was waiting fro the paint to dry on the main engine room hatch, I decided to clean up the cowl vents and add a coat of primer....
Cheers,
Tim
Edited by Timothy Wood
Tim
Future Build:
  • BlueJacket - USS Kidd (Fletcher Class Destroyer) Solid Hull
  • BlueJacket - U.S.S. SAMUEL B. ROBERTS, DE413 | Butler-Class Destroyer Escort
  • BlueJacket - 310' Destroyer "The famous "four-piper" of both World Wars"
  • Model Shipways - Pride of Baltimore II (Topsail Schooner)
  • Model Shipways - Willie L. Bennett (Chesapeake Bay Skipjack)
  • Constructo - Pilar (Ernest Hemingway's Fishing Yacht)
  • Sergal - Race Horse (Bomb Ketch)
  • Classic Warships - USS Salem CA-139 (Heavy Cruiser) Resin Kit
  • Pen Duick Schooner - Half Hull (Scratch Build)
  • CSA Submarine Hunley (Resin Kit)
  • Classic Warships - USS Washington BB-56 (Battleship) Resin Kit
  • Blue Ridge Models - USS Alaska CB-1 (Resin Kit)
Completed Builds:
Member:
Hampton Roads Ship Model Society
Greetings,
Four cowl vent bases ready to be glued into position.
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
Greetings,
The main engine room is complete with the "dog house" and 20mm ready service lockers glued in place.  I still need to attach the dead light covers at their correct locations on the "dog house".
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
lovely work, will look fantastic when she is all together
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Thanks guys!  Stay tuned, more to come!!!   :)
Tim
Tim
Future Build:
Completed Builds:
Member:
looking really good Tim  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Greetings Tim,
1. Nice job. I built this model several years ago. I really like the Blue Jacket products - well produced and made in USA.
2. If you ever get the chance, visit the Fall River, MA Marine Museum. That museum has an outstanding PT Boat section, including an honest to goodness restored PT boat from WWII. They also have many PT boat components including engines, props, transmissions, hull sections, etc.
3. If you are interested, there are several PT web sites. One web site has a complete list of EVERY PT boat ever built indicating when the keel was laid, where it was stationed, when it was destroyed/decommissioned, and how it met its end. I gave my PT #164. There were many more PT boats in the Pacific theater, not just the 109.
4. I know the Blue Jacket kit doesn't show it, but many later PT boats had radar fitted to their masts. Some of the websites show PTs with this radar fitted, and it is not difficult to model on your boat. I put it on my PT using some scrap wood and a bit of dowel.
wq3296
Greetings, the engineroom hatch is complete, only needs a final coat of paint.
My next step is to start work on the Day Cabin.  The Day Cabin has a slightly cambered roof, this will be sanded the same way as the chart house.  Also the Day Cabin needs to be sanded to mach the camber of the deck, to start with you gouge out the underside of the day cabin the same way I did with the chart house.
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
  • 3 months later...
Greetings, Happy New Year to all...   :)
I finally made it back to the bench today, thought I would jump ahead to the torpedo tubes for a little fun.
The first step was to cut the supplied 7/16" brass tubing into four tubes 5" long using a small miter box and a fine-tooth razor saw.  This step didn't sound like very much fun, too many things to go wrong with a miter box cutting a round object.  Instead I used small tubing cutter, this was much faster and provided a much cleaner cut.
The next step was to draw a center line the length of each tube, the line was used as a reference point for attaching the various pieces to the tubes.  This was accomplished by laying each tube on the plans and marking the location of each photo etched part with a mechanical pencil.
The reinforcing rings were glued to the tube first the the reinforcement plates were added.
The next step was to drill a hole through the through the training gear lug along with a hole into the end of the training gear housing.  At a later point a length of .020 brass rod will be inserted through these holes.
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
​Note: Comments on messy bench are not allowed!   :huh:
At this point the pieced are placed on deck, nothing has been glued at this time.
Three overall progress views:
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
It was some scrap that I had after our contractor did some work in the kitchen, figured I may as well use it for the PT Boat.  Better than tossing it in the trash bin, after all I paid for it!   :)
Tim
Future Build:
Completed Builds:
Member:
awesome brass work....tubes are looking very nice Tim!  ;)   but.......those full shots of your build..........now....THAT'S.....what I'm talking about!   very nice work...very nice.......one lean,  mean, floating machine!  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thank you for the nice comment!  :)
Tim
Future Build:
Completed Builds:
Member:
Greetings, a snowy morning in Virginia Beach makes for a good day at the building bench!  I managed to get the Breech Covers, Impulse Chambers, and all the Access Covers on the  torpedo tubes and some work on the Day Cabin.
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
My next task was to place the front and rear saddle on a flat surface, set the tube into them, align each saddle with the center of it's reinforcement plate, then glue them to the tube.  This step was quite easy!
The next step requires a more steady hand and a set of magnifying visors, (at this point I wish I had bought the type with LED lights).  Then I snip two front and two rear gussets from the photo-etched sheet and glue them in place on top of the reinforcement plates.
(See photos below).  There will be four for each tube for a total of sixteen gussets to mount.
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
One down, fifteen to go!
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
Elia,
Tim
Tim
Future Build:
Completed Builds:
Member:
Looking great Tim, Can't wait to see the next time you bring it to the meeting. I had a great time with you and the guys Saturday, I needed that.
Thanks a bunch man.
Happy modeling,
Marty G.
tubes look great Tim.........holy cow!!!  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Those tubes are great.  Did you ever make flutes and piccolos?
Bob
Current build:  SS_ Mariefred
Greetings Tim,
Good job - your work brings back memories from when I built her a few years ago. I numbered mine 164 - couldn't bring myself to call it 109 like every other Elco you see. One of the great things about Bluejacket is the diversity of models they make.
wq3296
Sorry Bob, can't say that I have.  Do you think I should start?   ;)
Tim
Future Build:
Completed Builds:
Member:
I have looked @ this kit many times and I must admit, you are for sure bringing all you can out of it.  Looking forward to more.
Rick
Wherever I am at...........there I am
KARTONIST in the making.......... B)
