just read through your log.......such a nice job your doing :)   kit like these are perfect,  if you want to go off the beaten path.  then again,  most kits are 'open ended'.......you can go just about anywhere you want with them.   a little modification and bash {or necromancy}  and your in business.   I've done a few and I think they can be more satisfying than the actual kit  ;)
it's a bit late to share comments  and tips for the hull.......you've done a great job of overcoming the planking and painting.   but I'm going to watch further.  I have a Flattie,  and these two boat have a lot in common  ;)    super looking boat BTW  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Prepped and painted the bottom - rust red.  Came out pretty good.
She is on a makeshift stand.
I have already sanded the mast, boom and gaff according to size.  They will all be painted white.  Made some of the cleats and so on. The stern is covered with a piece of cherry veneer (donated by Kurt van Dahm).
Marcus
Lovely work Marcus.
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Nice job! The paint looks nice and red :P!
-Elijah
Current build(s):
Completed build(s):
Model Shipways Phantom
Member of:
The Nautical Research Guild
After the conference and a road trip (1200 mls) up the Pacific Highway and lets not forget a day in Tijuana, Mexico I am have been working on her again.
This picture shows items I used and what I did with them. I have made small nails out of them. I didn't have any.
Piercing holes with a dental drill.
Forming the trim after soaking.
Trim attached and waiting to be dried.
Have been doing lots of small things to finish up the boat.
First of all, being a bit careless, I broke the bottom area of the rudder. Removed it and replaced it with another piece of wood.  Painted it, but did not look right, so I pulled off all the hardware and will start from scratch.
Next, finished up the trim work all around the boat.
Added an open cabin door, (so you can see inside with a flash light).
Re-did the hoops. First went to Hobby Lobby and looked for chair canning. They had none. Came home and looked in the parrot cage and one of her toys is made of chair canning. Removed it, took out all the treats and she was happy. I don't think she is going to miss this.
Pulled the toy apart and put in bowl of water overnight.
Removed the pliable canning and wrapped it around the metal cylinder (HP printer item).
Tapped both ends and let the canning dry for a couple of days.
Removed the tape and took the canning off the cylinder.
On the left the canning wrapped and tapped to the cylinder.
In the middle, cutting hoops.
On the right, after gluing the ends with a drop of CA, sand it to thickness.
Lots of hoops, very few good ones. Also I had a lot of colored ones as the canning for the parrot toy is dyed with different colors. I picked all the none dyed pieces, glued, sanded and stained them brown.
These are the hoops. Only glued.
I need single and double blocks, As I don't have single, but do have double and triple hole blocks, I cut the triple hole block in half and after a bit of sanding, one has two single hole blocks.
Mast. Boom and gaff have all there blocks and attachments ready.
Marcus
The close up of the bow. There are three blocks attached to the deck (as it is on the real boat). On the kit there are eyelets made on the mast itself. That is one of the big differences in each of the design.
I need to sharpen my sewing machine skills, so I can make the sail. Finish up the rigging, make the stand, get a display case, pack it and FedEx it to my sister.
Marcus
Nice Marcus. I really like the gaff to mast attachment, whatever that's called. If I re-rig mine that's what I'll do. Unless I missed it I will be interested to see what you do for the gooseneck. You have done a beautiful job on this little boat. Thanks for sharing. I'd say your sister will be thrilled.
Ian
I made a colossal mistake @#$Getverderrie%^&* I yelled all the Dutch swear words I knew...........................Didn't trash the boat.
I was touching up some paint and a piece of paper towel ended up sticking to the paint.  Took it off and left the threads on the deck.  Tried to take that off and it left scratch marks.  Tried to sand that off and sanded some of the trim and it got worse and worse  (Always does)  AAARRRRGGGGHHHHHHHHHHHHHHHHH
So I stripped the boat of all its trim, and hardware, sanded it down, covered the left over trim with tape and masked the bottom and keel (rust red).
Now it is ready for a RE-DO paint job.  I did take pictures.  Didn't want to as I want to forget this, but it needs to be learned.
Runs of in a corner and cries.
At least you can re-do-dely-dum-do-it. You know it is "getver, derrie" (yack, muck) ;) I hope it will go smoothly from here on, Marcus. Not what we call a good beginning ...
Carl
SCREW-UP
I put a light coat of polyurethane on the paint and it dried blemished. Then tried the touch ups and that went wrong. So as I mentioned before, stripped the boat of all the trim and hardware and about an hour ago spray painted the first coat.
On this picture you can see it good.
Ready for painting.
What did I learn?
Once paint is completed NO polyurethane except the wood work.
Redoing the hardware and the trim will be easy as I have done this already. The display stand is ready. The items that still need to be made is a name plate with the word 'perseverance' and a burgee with the Prince Edward Island crest.
Marcus
Nice work Marcus. Perseverance pays off !!!
Thanks. Did 2 light coats of paint and she looks good again.
Due to the bitter cold I have both paint can and boat in the warm basement. Then I go outside holding the boat in one hand and spray painting light coats on the boat with the other hand. Run inside before my face freezes off. Let her dry in the garage which is still cold and after about an hour bring paint can and boat back in the basement. Here I will let her dry for 2 to 3 days.
I also learned that painting is something that needs to be learned. Eventually I will get the knack of it. Another part of the hobby.
Marcus
is that what you named her........she sure is living up to her name  ;)   we've all done it........I've done it with both enamels and lacquers.   you can have a good day.........or.......well,  it was a good day .shrug<.    I'm in the same boat......but I think your in colder country than I am.   I have to paint in the cellar {i'll gladly open a window for vent}.  fingers crossed she looks better than before  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hoi Markus, happy New Year to you and the family.
Just caught up with your build.  She's really looking very good my friend and these little goof-ups come with the territory.  It's the end result that counts.  our sister will be well pleased, I'm sure.
Cheers,
                       VOC Ship Surabaya
As of the last post I am ahead. Cleaned up my mistake and learned from it.
The boat is pretty much finished and all that is needed is the mast, boom and gaff with the sail.
I need to make a burgee (little flag)
and the name 'PERSEVERANCE' on a name board.
I have no letters so I am thinking (MS Word, required font and printer).
Except if anyone has a better idea, I would like to hear about this.
Thanks
Marc
you could use photo shop to create the name plates........set them up for size.   but instead of paper,  use white decal paper.  you will also need to purchase a can of decal bonder to seal the decals. the stars though could be done in a cool idea.   on one of my scavenges through Hobby Lobby,  I found these stars,  used for leather studding and / or decorating.   I found them in copper, gold,  and silver.........but I also bought a pack of red,  white,  and blue.   it might give it a cool touch  ;)
for the flag,  it involves making a mirrored opposite to the left of the image.   here's the kicker........set up a piece of sail cloth and run it through your printer.
    I've done it for embossing sails,  and for flags too.   if the cloth your using is rigid enough,  it should go through with no problem.......guide and assist if needed.   seal with decal bonder.........do not use a water based product.
PM me if you have questions,  or this appeals to you.......gotta take m' dog out  :rolleyes:  :rolleyes:
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
This is something I will do.
The flag I will do by a method from Gus Augustin, member of our tri-club and a well known modeler.Post 51 on this page
http://modelshipworld.com/index.php/topic/4294-the-first-royal-dutch-yacht-mary-by-marcus-botanicus-finished-mamoli-1646/page-3?hl=yacht mary
Marc
sounds good Marc......glad I could contribute in some way or another.  sure thing  'decal it' is a basic program for the computer to create decals.  I bought it a while ago,  but found that images couldn't be imported into the program.   that's when I bought the standard edition of the decal it program.   stencils have been a gold mine......I just scan the images into a folder,  and I can import them whenever I need them.  I've also been able to scan other decal sheets and use those images as well.  the decal bonder is the most important thing to get,  besides the paper.  it's like a lacquer.......dries quickly,  but smells terrible.
    after the decals are printed,  wait for about 20 mins or so.......then spray then lightly with the bonder.   takes about two coats to do the job.
glad I could help  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
