Fantastic video Kevin 👍  I just mentioned to my wife that from now on I'm going to be sitting in front of the TV making tree nails.........she mentioned something about "over my dead body" but I think she really meant - no problem Mark you just carry on fella 😜
You will check in with us occasionally, just to let us know everything is alright? 🤐
STAY SAFE
current builds:
Kevin, that is looking good. It is a beautiful model.
STAY SAFE
current builds:
I'm still breathing -  I never realised that building model ships came with a care package - but I'm grateful 🤣
The hull looks beautiful Kevin. On my current model I inserted the treenails dry into the holes with the stock in one hand and the flush nipper in the other. This makes quick work of inserting the treenails. After this I used a 50:50 white glue/water solution to paint over the holes. Once dry the hull was lightly sanded and that was it. I did not have a single treenail fall out using this method (which I also used on the deck). As you also use termite control and another finish that would additionally lock in the treenails.
Greg
website
Admiralty Models
Finished build
Pegasus, 1776, cross-section
Current build
Speedwell, 1752
Kevin
Just finished watching your treenail video, excellent video and thanks for all your video.  Your hull looks great and i look forward to watching you more.
Gary
Life is to short to be serious all the time. So, if you can't laugh at yourself, your not doing it right.
Current Builds
18th Century Armed Longboat
Finished Builds
Muscongus Bay Lobster Smack
Lowell Grand Banks Dory
Norwegian Sailing Pram
An actual horseshoe clamp taken from the wreck of the HMS Janus. She sank in 1800 off Trinidad. This was given to me earlier this year by a commercial diver Robert Stauble who knew of my interest in out marine history. Notice how rough the casting is. Makes one wonder if it ws recessed or just bolted flat against the keel and the hull. Its 33 1/4“ wide, 22” high, the width of the cast is 3 1/2” and its 3/4” thick. The holes are 1 1/2” wide and there are 7 holes to take the bronze pins.
another OH CRAP moment we've all suffered from.
Edited by AON
Alan O'Neill
Add the red marks/bruises on the forehead from the facepalm.
Looking good, Kevin.
BTW, I watched your video on clamps earlier and learned a couple of things. Thanks!
STAY SAFE
current builds:
A slitting saw blade on a table saw. Heat-softening the brass first and some wax while cutting will help. Mounting the brass on a sacrificial wood backing will also ease the job.
Double sided tape works well for this. If you are using a slitting saw blade it's probably best to raise it higher than normal practice and use a slow feed rate.
To release the brass from the sacrificial wood without distortion can be a problem, I soaked the whole assembly for a day or so in white spirits to loosen the bond. Plywood may fall apart after this which is the best result.
Edited by bruce d
STAY SAFE
current builds:
