HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 60 donations so far out of 49,000 members - C'mon guys!) ×
Hi Mort,
very good question; I took a long time to find the the same answer as Ian just gave.
I don’t know the size of the actual rope on the HMS Victory in Portsmouth, but it looks quite thick.
I used 0.25mm rope, and put an extremely thin ( medical) guide wire  “inside” the rope. It helps the rope to “hang” naturally.
Regards, Paul
While finishing the mizzen mast, I've made a start rigging the mast. Starting with the fore mast I had to solve how to attach the rope and block at the correct distance. My solution is the "noose" method:
First glue the rope to one side of the block:
cDSC_5181
Then around the block and glue the other side as well:
cDSC_5182
Next: I clamped the block in the Seizing and Serving tool, with the rope looping around the screw on the left, and tighten the screw:
cDSC_5183
Winding the right loose end around the fixed rope AND the other loose end.
cDSC_5184
It is now possible to exactly determine the distance between the block and the mast:
cDSC_5185
Now I can pull the loose end (on the right) coming from the loop, and tighten it:
cDSC_5186
and fix it around the topgallant mast:
cDSC_5187
Put some CA glue and trim the ends:
cDSC_5188
Edited by paulb
Regards, Paul
Got a question: where can one get wooden thimbles? They're not in the kit, and hard to find on the internet. Is it a matter of using a dead-eye block and drill a hole in the middle or are they available ready-made?
Regards, Paul
 Paul, you might try Cornwall Model Boats in the UK.
Hi Paul,
Amati and Mantua on the CMB  site have heart and violin blocks.  A few years ago I bought bullseyes from Model Shipways.
Hope this helps.
Current Build - Caldercraft Diana
Completed - Artesiana Latina Swift, Harvey, MGS Prince de Neufchatel, Imai USS Susquehanna, Mamoli Constitution, Rattlesnake per Hunt Practium, Caldercraft Snake, Diana, Caldercraft Victory, Kammerlander Duke William
Waiting to be Launched -  Bluejacket Constitution
Proud member of The New Jersey Ship Model Society, Model Shipwrights of Niagara, Model Shipwrights of Western New York and Offshore member of the Society of Model Shipwrights
Paul, the challenge with finding thimbles is guessing what a supplier might call them, for the purposes of using their search engine.
I used to buy them from The Model Dockyard, called "single hole deadeyes". but Nick retired and closed up.
Take a look at "Cording Roller Wood" (???) at Model Dockyard (oops, corrected) Cornwall Model Boats; they have several sizes down to 2.5mm and 3.5mm. However their holes look perhaps smaller than on the ones I used to buy.
Good luck!
Ian
Edited by Ian_Grant
Thanks Keith, Mort and Ian. Cornwall Model Boats has them, and after paying quite a bit of import tax (Brexit...) they were delivered.
Been busy with the yards. Lots of research in sometimes conflicting texts.
First yard to be ready is the Sprit Sail Yard.
cSprit sail yard
Some comments: It seems that the buntline block was actually a thimble until 1773. From then in larger ships the thimble was no more strapped to the yard but instead to one side of the bowsprit, just above the slings, so I think I will remove the blocks on the yard.
The clueline block is a modified 3mm single block:
cDSC_5197
All clueline blocks are like this. With the 5 mm blocks the picture will probably be more clear.
Regards, Paul
Yards finished.
Spritsail yard and spritsail topsail yard:
cDSC_5210
Fore yard, fore topsail yard and fore topgallant yard:
cDSC_5212
Main yard, main topsail yard and main topgallant yard:
cDSC_5214
The crossjack yard, mizzen topsail yard and mizzen topgalant yard:
cDSC_5216
The driver boom and driver gaff:
cDSC_5218
Regards, Paul
Paul,
I just now noticed your log and after seeing the latest posts went back to the beginning.  Congratulations on all the research you have done and replacing so much of the unrealistic kit parts.   Very well done!
When you were doing the bottom, did you consider replacing their copper sheathing material with something more realistic like what you show in the McKay close up drawing?
Thanks for sharing your build!.
Allan
Edited by allanyed
lovely to catch up on your log again, you have made such a fantastic job on her so far
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Thanks Allan and Kevin.
@Allan: yes, I have considered doing something else with the coppering of the part below the waterline, and you are absolutely right about the less than correct solution of Caldercraft, but at the time I didn't see another way forward. In the end I feel the copper plates from Caldercraft are a reasonable compromise, but I'm not sure what I would do if I would build the Victory again.
Right now, I have shipped the masts and covered the sleeves with a fine cloth, to make it look like canvass.
cDSC_5219
cDSC_5224
cDSC_5225
cDSC_5227
cDSC_5228
cDSC_5221
and the sleeve of the mizzen mast on the quarter deck:
cDSC_5230
Next is the standing rigging, starting with the tackle pendants. Let me show a picture from Zu Mondfeld.
cDSC_5226
Here the English way of putting tackle pendants (here called hangers voor de takels) is different from the continental way, so that looks easy. However, Longridge describes the continental way, but draws the English way, as does Caldercraft is its manual. McKay draws the English way, but again James Lees has only one description: the continental way.
I tend to do it the continental way, that is if there are 2 tackle pendants on both sides (fore and main lower masts). Of course if there is only one tackle pendant on either side, I will use the English method and use a cut splice.
But of course I am open to good advice.
Edited by paulb
Regards, Paul
After reading James Lee carefully, I decided to take his interpretation of the tackle pendants, meaning that those of the fore and main masts will be put around the mast head, just as the shrouds.
That meant making a cable of the correct length with a thimble turned in each side, served along its entire length.
I started by fastening the thimble to the rope (1,2mm) with a small drop of superglue.
cDSC_5231
Next seizing of the rope, starting close to the thimble:
cDSC_5232
cDSC_5233
Seizing towards the thimble, and securing the thin rope with of knot and some superglue:
cDSC_5234
cDSC_5235
Then the seizing away from the thimble can start, for a short distance around the three strands of the rope:
cDSC_5236
In order to taper the seizing I took out one strand of the rope, and continued with the other two:
cDSC_5237
A short distance with two strands, dropping another strand and end up with only one and then just the rope:
cDSC_5238
Serving the rope:
cDSC_5239
and securing the serving thread where the seizing of the other side terminates
cDSC_5240
Securing the second thimble in the right spot:
cDSC_5241
Again starting the seizing close to the thimble, and towards the thimble; securing the thread with a knot and superglue:
cDSC_5243
cDSC_5244
This time all three strands came apart, which is not a problem. Tapering same as on the other side, seize until you meet the serving thread, and secure the two threads with a knot and a small drop of superglue:
cDSC_5245
cDSC_5246
Trim the loose ends of the strands taking care not to cut the seizing thread.
Tackle pendant for one side of the main mast:
cDSC_5247
Regards, Paul
Hi Paul,
When I noticed your binnacle with the aft side closed off and the forward side open I thought that the clear openings might be on the wrong side as the helmsmen could not see the compasses but then looked at photos of the binnacle on the modern day Victory and there are clear openings on the forward side there as well.   Is this because the candle light would interfere with the night vision of the helmsmen or is there some other reason for this configuration?
Thanks
Allan
 Allan, even if the binnacle was open to the helmsmen he would have been hard pressed to be able read the compass. Reading from the forward side by the OD or watch would have been unobstructed and corrections if any could been easily relayed.
  • 2 months later...
Standing rigging continued.
First the pendants of the tackles: fore and main mast two on either side, mizzen mast, fore top mast and main top mast one on each side:
Fore mast:
cDSC_5254
Main mast:
cDSC_5248
Mizzen mast:
cDSC_5292
Main top mast:
cDSC_5250
Painting the deadeyes black:
cDSC_5260
The fore shroud of the fore and main mast are completely served. The others from the sling around the mast head to about the height of the yard:
cDSC_5256
 cDSC_5259
Before starting with attaching the shroud to the deadeyes (and lanyards) I first made the thimble for the main topmast preventer stay on the fore mast:
cDSC_5267
cDSC_5268
Then my method for securing the deadeyes to the shrouds. I decided to use shroud laid rope for the shrouds , and that affects the way one should attach the dead eyes. The information about what kind of rope to use for the shrouds is conflicting; it was only after I made all the shrouds that I found out that the fore and main mast shrouds be cable laid and the ones of the mizzen mast shroud laid. Too late to change!!
With shroud laid shrouds, the short end lies forwards of the standing part on the port side of the ship and aft on the starboard side.
Additionally the short end runs on the inside (deck side) of the standing part, just above the dead eye:
I made sure that the deadeye is at the right height: just above the netting in case of the fore mast. To make sure their height are all the same I made a simple jig out of a brass wire. I used two small clips behind the upper deadeye, as the jig tended to slip out of the holes. Then I put tension on the rope, and clamped it:
cDSC_5293
Two drops of CA glue to fix the rope on the deadeye:
cDSC_5294
The end of the shroud is secured to the deadeye with three seizing: A throat seizing (horizontal) immediately above the deadeye....
cDSC_5295
....and two round seizing (vertical) to the standing part, making sure the seizing are at the same height in all shrouds:
cDSC_5296
First round seizing:
cDSC_5298
Second round seizing:
cDSC_5299
The loose end: some CA glue just above the seizing:
cDSC_5300
And clipping it of with a nail trimmer for the end result:
cDSC_5301
The rest will take some time...
Regards, Paul
The deadeyes came with the kit, Allan.
All the blocks have been replaced. Mainly by the ones from Syren Model Ship Company.
Regards, Paul
  • 7 months later...
Just a small update of a lot of work and a long period of inactivity (in terms of model ship building😉).
I finished the starboard side of the lower foremast.
The lanyards are fitted in a formal way: as I used shroud laid cable for the shrouds (which, according to a colleague ship builder is also a good choice) I started threading the lanyard through the top-front hole of the top dead eye, then up and down, and then wind it around the lower end of the shroud.
The lanyards on the MS Victory are tied together in a certain way, which I have copied.
After that I fitted 5 mm shroud cleats which I bought separately, as I found the cleats in the kit too big.
The result:
cDSC_5533
cDSC_5534
Detail of the lanyards
ccDSC_5533
Compared to the original
cDSC_2832 (2) cDSC_5535 cDSC_5536
Next: the port side.
Regards, Paul
  • 4 months later...
Actually since I have already built 2 Hms Victory on commission (no from kits), the Caldecraft kit is not correct!! The bow section of the ship is wrong! Fortunately there are tons of pictures of the real ship to look at! So who ever wants to built this great ship there is a lot of info on the subject….oh another thing, if you want to paint the model have a look at the colours that the curators of the museum have discovered……
  • 4 months later...
Following a fairly long summer break, the work has started again.
First I had to finalize the shrouds of the main mast and the mizzen mast. So mainly fixing the dead eyes and the lanyards.
Never mind the gunport lids. That is collateral damage, and easy to fix.
cDSC_5537
cDSC_5538
Then the futtock staves: I used a 0.8mm brass rod, and served it with 0.1mm black thread. Next the futtock shrouds, meant to keep the futtock plate and lower dead eyes of he top mast shrouds in place when those shrouds are being tightened.
The futtock shrouds have an eye slice to accomodate a hook, which is put in a hole in the futtock plate. The whole length is served.
cDSC_5540
The lower end will be tied to the futtock stave in the following way:
cDSC_5542
More to come!
Regards, Paul
Futtock shrouds attached.
I followed McKay instead of zu Mondfeld when it came to attaching the futtock shrouds to the futtock stave.
In this way I guess it is still correct, but less lumpy, especially because the attachment of the catherpins also need space.
cDSC_5545
cDSC_5543
cDSC_5544
Regards, Paul
Catharpins are short lengths of rope, with an eye spliced on both ends. Rope and eyes are served using 0.1mm rope. The main challenge is to make them of the right length. Although they slightly increase in length from fore to aft, this is hardly noticeable.
cDSC_5546
Catharpins in position, attached to the 4th, 5th, 7th and 9th shroud.
cDSC_5548
cDSC_5547
cDSC_5549
cDSC_5550
Regards, Paul
  • 1 year later...
On 11/8/2020 at 6:01 PM, tracey odd said:
hi paul where did you get those decal for the buckets thank's
Woody's Model Workshop, based in UK, does a set of resin 3D printed replica buckets complete with brass 'GR', plus other detail parts.
