Thanks for the link Nic.
Just out of curiosity, is BlueJacket looking at using 3-D printing for any parts? I know the upfront costs can be eye-watering.
Tim
Current build:  Syren
Past builds:    Continental Navy Frigate ALFRED (build log & Gallery)
                        Steam Tug SEGUIN (build log in the kits 1850-1900 section)
                         Liberty Ship SS Stephen Hopkins (Gallery & Build Log)
                         Lobster boat RED BARON (Build log)
                         USS Basilone (DD-824) (Gallery & Build Log)
                         USS Olympia (Gallery)
                         USS Kirk (FF-1087) (Gallery & Build Log)
Yes, we have kept a close eye on 3-D printing. From a kit production standpoint, it is prohibitively expensive for not much gain.
However, for the modeler, it is practical. For example, if you want to get nice marine figures in 1/192 scale, shapeways has you covered. Look here:
https://www.shapeways.com/product/55GX8HF2S/1-192-us-navy-dungaree-set-1?optionId=61093772&li=marketplace
And here's one in place on the USS Kidd.
Final Cargo Rigging
The booms on Hatch nr5 are configured in what was known as a “Wing and Wing’ rig, another variation on the Yard and Stay rig used on hatches 3 & 4. The Wing & Wing had the ends of both booms over the side of the ship, allowing cargo to be worked on both sides simultaneously. One feature of it is that the are no inboard guys - the ends of the booms are just lashed together for support.
I still have to trim some tag end and add some rope coils. Next up will be the lifelines and PE railings.
Edited by schooner
Tim
Lifelines and PE Railings
The kit supplied PE railings were too thick for me so I used some 1/192 railings from Tom’s Modelworks which I find very easy to work with. The lifeline around the fantail gun platform is brass and thread.
Next up will be the radio antennas and flags.
Tim
Radio Antennas and Flags
I found a 48-star flag and the house flag for the Luckenbach Steamship Co online and copied them to my graphics program, adjusted their size, copied them and flipped one copy, backed each half together and printed them out.
In order to get the paper to hold furls I used a trick I found on some modeling site. I cut a piece of aluminum foil slightly smaller than one half of the flag. I glued it in place using rubber cement because white glue has too much water in it and it will make the printer ink run. I then placed a length of halyard rope along the fold point, folded the flags and glued them together, once again using rubber cement. The furls were made by folding the paper around a pin, alternating directions.
The antennas are made from some metallic thread provided in the kit, it simulates bare wire nicely.  Both antennas run between the main and mizzen masts and are connected to the coupler tower on the flying bridge. The insulators near the ends of the antennas are just small blobs of white glue built up over several repetitions.
The last thing left to add is the guns and then the big job comes - cleaning and dusting the model prior to casing it.
Tim
Thanks Steve,but this can't hold a light to your Vance build.
It amazes me that while they share the same hull the addition of all that superstructure makes the Vance look at least twice as big as a standard Liberty
Tim
Well, she's done. Thank you to all who have followed along, made suggestions and contributed ideas.
Hopefully I'll be back soon with a lobster boat build that I don't think has appeared here before.
Edited by schooner
Tim
Very nice!  That looks like a fantastic kit.  Great to see subjects other than 18th century British warships with dozens of cannons :)
Mike
Current Wooden builds:  Amati/Victory Pegasus  MS Charles W. Morgan  Euromodel La Renommèe
Plastic builds:    Hs129B-2 1/48  SB2U-1 Vindicator 1/48  Five Star Yaeyama 1/700  Pit Road Asashio and Akashi 1/700 diorama  Walrus 1/48 and Albatross 1/700  Special Hobby Buffalo 1/32   IJN Notoro 1/700  Akitsu Maru 1/700
Completed builds :  Caldercraft Brig Badger   CLC Annapolis Wherry  Amati Hannah - Ship in Bottle  Pit Road Hatsuzakura 1/700   Hasegawa Shimakaze 1:350
F4B-4 and P-6E 1/72  Accurate Miniatures F3F-1/F3F-2 1/48  Tamiya F4F-4 Wildcat built as FM-1 1/48  Special Hobby Buffalo 1/48  Eduard Sikorsky JRS-1 1/72
Citroen 2CV 1/24 - Airfix and Tamiya  Entex Morgan 3-wheeler 1/16
Terminated build:  HMS Lyme (based on Corel Unicorn)
On the shelf:  Euromodel Friedrich Wilhelm zu Pferde; Caldercraft Victory; too many plastic ship, plane and car kits
Future potential scratch builds:  HMS Lyme (from NMM plans); Le Gros Ventre (from Ancre monographs), Dutch ship from Ab Hoving book, HMS Sussex from McCardle book, Philadelphia gunboat (Smithsonian plans)
Thanks Mike,
It IS a fantastic kit, so good that I was able to spend my time doing what I like, which is detailing, instead of having to "fix the kit"!
Tim
She turned out real spiffy, I like the way the rigging turned out on the masts and cranes, a lot of additional details too. A very informative build, thanks for sharing
Carl
great topic, something slightly different :)   weldone ...
HMAV Bounty 'Billings' completed
HMS Cheerful - Syren-Chuck' completed :)
Steam Pinnace 199 'Billings bashed' - completed
HMS Ledbury F30 --White Ensign -completed 😎
HMS Vanguard 'Victory models'-- completed :)
Bismarck Amati 1/200 --underway  👍
Thanks for the kind words Ian and Cog, I had a lot of fun with this one, hated to see it come to an end.
Tim
Great job on a unique subject Mike.
You have truly made a model to be proud of. Hopefully it is located in a place where it can be admired by all.
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
  • 1 year later...
I don't hesitate to recommend this kit if you are interested. It's big enough to detail but its relatively short height means you don't need a piece of furniture to case it. You can put on as much or as little rigging as you want but all of it is easier than sailing ship rigging. Overall a very enjoyable build.
Tim
Thanks!
Tim
