HMS Dreadnought 1907 by RGL - FINISHED - Zvezda - 1/350- PLASTIC
I know how you fell about the armour strips (remember by problems making them from paper strips) :o Its such a difficult situation either thay are too over done or nothing at all, it certainly pushes are skills and imagination.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
Share on other sites
Good idea Greg.  Do you have any concerns this tape may lift over time?
cheers
Pat
Link to comment
Hi Greg,
I have seen a similar technique to build up the 'plates' with primer but the tape is removed to create the 'lower' section so when painted overall there are different subtle thicknesses to represent the plates.
Cheers
Slog
_______________________________________________________________________________________________________________
HM Bark Endeavour (First Wood, On Hold)
Borodino (1:200 Card, Current Build)
Admiral Nakhimov (card 1/200)
Mazur D-350 Artillery Tractor (1:25 Card)
F-8 Crusader (1:48 Aircraft, Plastic)
Link to comment
I remember several years ago Don Pruel from Annapoli gave a demo on simulting plating using tape and a airbrush.  At the scale it was marvelous.
David B
Link to comment
Moving along with the hull, 120 porthole eyebrows added, and strips along the strengthening bars with microscopic rivets in them (you can see these on the original photos) as well as the flanges for the torpedo booms. Looks messy but it is yet to have its first proper primer coat.
Greg
Link to comment
You're going along rapidly Greg; that PE looks good where you have used it so far.
Those baseboards look a treat, especially with the grain showing the way it does.
cheers
Pat
Edited by BANYAN
Link to comment
Moving along! Primer coat done and the armor belts came up OK.post-253-0-48356500-1466569425_thumb.jpg  then the bottom of the hull. I want to leave it about 12 hours before I do the black band and upper hull. Over all I'm pretty happy so far. Before I do the grey top I want to add around 100 or eyelets to the side of the hull for the torpedo net boom rigging. They are so small I wont prime them as they will just fill up with paint. post-253-0-03271500-1466569486_thumb.jpg
Greg
Link to comment
gosh, thats really good work.  I wish they made this model in 1-200 scale.
How about 1/96 scale?  :)
http://www.deansmarine.co.uk/mpage/Products/dreadnought.html
Link to comment
There is a heap of plastic models and aftermarket coming out in 1/200 at the moment, OK if you have poor eyesight and lots of space I suppose. I often wonder what the kids will do with mine when I'm gone! The Endeavor would look good anywhere, the plastic ones are a matter of choice I suppose, so will end up in a bin.
Greg
Link to comment
Loving your progress greg - the armour plates look a treat, she has a great shape about here and no boubt quite daunting in her prime.
OC.
Current builds
Completed works.
Link to comment
Looking nice greg very clean and as you say - good to get the main hull painting out the way,    always feels like an achievment when thats done,      is that AP 507C on the hull?  standard RN paint colour to help keep the temp down a bit on ship in hots climates.
OC.
Current builds
Completed works.
Link to comment
Very nice Greg, those armour bands came up very well indeed.
cheers
Pat
Link to comment
The screw and shafts complete. I used some lovely G Factor brass ones specific to this kit.post-253-0-73252600-1466723482_thumb.jpgpost-253-0-33364800-1466723491_thumb.jpg
I then placed on the depth markers. These are dry transfers which I have never used before but after a quick look on the internet on how to use them (no instructions were provided) they went on very easily. If you loom closely at the tird phot you can see the .3mm rings for the torpedo boom rigging.
This is now my Monday morning so back to the grind.    post-253-0-42377500-1466723607_thumb.jpgpost-253-0-39170300-1466723611_thumb.jpg
Greg
Link to comment
Umm, Greg - looking at your last photo, it appears that you have right hand propellers on the port side and left hand propellers on the starboard side.  Have you photos to show this ion the original ship, as multiple propellers are almost invariably fitted the other way around so that they're outward turning when the ship is going ahead; which provides for much better manoeuvrability - especially when going astern.
John
Link to comment
John
Greg
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
