I finished up the railing today...now I am going to carve the eagle head figurhead(that'll be fun)
Rob
Current build:
Finished build:
Current build(On hold):
Thanks Omega...that aft rail was a booger.  I had to laminate several pieces together while I was forming the curve(Off ship), then secure it to the stanchions while making adjustments before it dried...... :huh:
Figurehead we come......
Rob
Current build:
Finished build:
but it was sure worth it...masterful job on the railing Rob!    very well done!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks everyone for all the likes and comments.  I finished up the figurehead.  Carved from dowel.
Example of real figurehead and my attempt.
Rob
Current build:
Finished build:
The beak will be tongue oiled to lend it to age.
Rob
Current build:
Finished build:
Mounted
Current build:
Finished build:
Wider view
Current build:
Finished build:
superb job on the eagle!   really nice!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Jeff..that is awesome.  Fun thing about the GR is you can build her in her original state or her rebuilt state...and still be correct.
I'll surely follow that log.
Thanks for the like and fine comment.
Rob
Current build:
Finished build:
I made few more slight corrections to it and I still have some mods to make to the final look and finish....but it is pretty close to finished.
Without photographs or builders drawing to know exactly how the figurehead was mounted...one must use an educated guess.  I'm confident from what information I do have...it is as accurate as can be modeled.
Rob
Current build:
Finished build:
Finally got around to making the six crab winches.  These little 1/4" buggers were difficult...especially having to make 6 identical.
You can see the image in the background that was the model.
Rob
Current build:
Finished build:
These winches are not an exact replicas of the image pictured....the winches of the period were numerous..so I had a choice...I chose one similar.
Now when they dry I will mount them and then get to some masts.
Rob
Edited by rwiederrich
Current build:
Finished build:
Here are the winches mounted.
Rob
Current build:
Finished build:
Time to get out that Dremel and turn some masts!
I checked and my Dremel lathe doesn't have enough length in the bed to hold the masts....sooooo...I'll need to turn them on the larger wood lathe in the wood shop.
Rob
Current build:
Finished build:
1/4" - Yikes! Nice job on those winches Rob.
Gary
Yeah....I wrestled with many ideas and processes of fabrication till I settled on the design used.
Lots of grinding and metal fab was necessary.
Rob
Current build:
Finished build:
I fabricated my winches from Clam clips.......These little guys.  I cut the large lip edge off and cut it down and removed the center..then added the roller drum and guide/actuation rod for the handle.
Just to let you all see the re-engineering I sometimes go through.
Rob
Current build:
Finished build:
all along the way good ideas and good progress Rob,
love that figurehead and the winches.... :)
Nils
Current builds
-Lightship Elbe 1
Completed
great job on the winches......they look cool in place on the deck  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Rob.
How did you make the winches? They look very clean with high level of detail.
Interested to know how you did it.
Sorry...just saw your post above, but how about the wheels?
Thanks,
Tim
Edited by Tim Curtis
Rob.
Thanks,
Tim
Hi Rob
I'm with Tim.  Curiouser and curiouser!
Pls do tell :) .
Cheers
Patrick
Well..here is a drawing of the original part and drawn on it are the portions cut away(In yellow) and the resulting shape of the part needed.
I had to cut using a hard cutting disc because the metal is hardened spring steel.
Clamp the part cut off the excess and then grind out the center....then clean up the edges with a fine grinding stone bur in my hand piece.
I didn't take any images of the actual process.
I then fashioned the drums from wood stock and some left over stanchions froma Revell 1/96 Cutty Sark....trimmed to fit and fashioned to mimic the control rod .
The gear reduction gear is fashioned from HO train accessory break kits for boxcars(the break wheels)
Then painted black to hide a multitude of sins.
Rob
Current build:
Finished build:
Thanks guys.  After establishing the width(1/4")...cutting out the middle to produce the 4 external legs/arms...it looked like the familiar triangle legged...or *A* frame legged crab winch.  See...that was the construction issue.  Making the legs all uniform.  This method provided me with a repeatable process and one that also left convincing results.
I also attempted to cast the leg frames , using light cured acrylic.  It worked, but the assembly was far more tedious and at this scale proved to complex and down right exhausting.
I thought my way out of a mess....I think.
I've concluded I will attempt to replicate the masts by casting them as well...if not for an experiment to see if it is possible.  If failure is my reward...then I will do it the hard way.  We'll see.
Rob
Current build:
Finished build:
