The real work came with the addition of the main topstays  both sides.....still need to finale secure the port side.
Current build:
Finished build:
Current build(On hold):
After lunch, I'll finish up the port buntlines and blocks ...run them through the faileads and to their pins and finish up the port leach lines and blocks.
I''l return to the stays once this is all done.
Current build:
Finished build:
Rob, were the fore and main stays on the GR hemp or steel cable at this time?
Able bodied seaman, subject to the requirements of the service.
"I may very well sink, but I'm damned if I'll Strike!" JPJ
My Pacific Northwest Discovery Series:
On the slipways in the lumberyard
Union, 1792 - 1:48 scale - POF Scratch build
18th Century Longboat - circa 1790 as used in the PNW fur trade - FINISHED
Future Builds (Wish List)
Columbia Redidiva, 1787
HM Armed Tender Chatham, 1788
HMS Discovery, 1789 Captain Vancouver
Santiago, 1775 - Spanish Frigate of Explorer Bruno de Hezeta
Lady Washington, 1787 - Original Sloop Rig
In 1853 they were still hemp from what I gather...when she caught fire she burned up nearly completely above the waterline.
Current build:
Finished build:
Finishing up the day in the yard......I finished the top and topgallant stays..worked a bit on the topgallant haulyard and its purchase.
I had to make lots of blocks and iron hooks and seizing stuff....
The detail at this scale is excruciating....I spend most of my time keeping from bumping or ripping somthing out I previously put on....Oh well...the burden of fun.
Here is a bunch of pics from the day.
Rob
Edited by rwiederrich
Current build:
Finished build:
14 hours ago, BANYAN said:
Really on a roll now Rob; looking good!
cheers
Pat
Yes...one could say I'm *Clipping* along.   I'll probably add the royal stay before I proceed onto the mizzen mast.
Thanks a lot Pat..and thanks a lot to all the likes everyone...
Rob
Current build:
Finished build:
I began the work session by first cutting to length the 5 yards for the mizzen mast.
Current build:
Finished build:
While I was planning out the yard details and making more eye bolts...I also finished up the rigging for the top sail yard halyard and its blocks and purchase.  Here they are installed and just belayed.
Rob
Current build:
Finished build:
Moving back to the mizzen yards...I finished forming them and prepping them for addition of eye bolts and trusses.
Rob
Current build:
Finished build:
With the mast set in the work vice...I added many new eye bolts for lifts, halyard blocks and other blocks connection points.
Next, I'll begin adding the yard parrels and straps as I finish up the first yard to be added to the mast, the royal yard.
Rob
Current build:
Finished build:
With the addition of the blocks this yard will be complete.
I have 8 inches of snow outside and I have to go get my wife from work....hope to be at it later.
Current build:
Finished build:
Great progress Rob; looks good.
I like that vice you use too - ideas, ideas :)
cheers
Pat
Thanks everyone.  Yes...I got that table vice over 35 years ago...and it's been a great aid.
28 degrees outside and 18 inches of snow.....
Everyone be safe.
Rob
Current build:
Finished build:
I've had my full-sized Workmate for about as long. I use it all the time. It's one of the most versatile benches of its kind. I've never seen the miniature "Hobbycrafter" model. I googled it. Apparently, they don't make them anymore. There were a couple on eBay for big bucks and the shipping was sixty bucks or so, too. I was dumbfounded by the prices they are asking for old big Workmates, too. If the Hobbycrafter is half the tool the big one is, I'd definitely be looking for one, but not at eBay prices!
I love it...it is very articulate.  They haven't made them for years from what I gather.
I use mine in all my model building.
Rob
Current build:
Finished build:
Bob
 Is this what you're looking for?
https://www.buya.com/Item/Details/BLACK-DECKER-Clamp-Vise-79-025/lite/30b4a689501f48b88bca3dcfc40b294b?gclid=EAIaIQobChMI286A2vKx4AIVkbbACh0xcgD0EAQYAiABEgKlVfD_BwE
Rob, I have a dremel version (also no longer made) but I find it just a bit too big - have never got around to modding it - but eventually :).  Yours looked a little smaller but seeing Keith's link I think it is about the same size?  I think the base of yours would also make it a little more articulated?
Image result for Dremel bench vice
cheers
Pat
Unlike the Dremel version the B/D is fully articulated...meaning it can rotate and be adjusted in a vast array of different angles and latitudes.  It rolls around on a ball at the base and you can adjust the level and angle.  One real reason I prefer it over the Dremel vice.
Rob
Current build:
Finished build:
There's one showing on ebay us currently for ten dollars plus 30 dollars to send to the the UK😀
The clerk of the cheque's yacht of sheerness
Current build HMS Sirius (1797) 1:48 scratch POF from NMM plans
HMS Winchelsea by chuck 1:48
Cutter cheerful by chuck 1:48
Previous builds-
Elidir - Thames steam barge
Cutty Sark-Billings boats
Wasa - billings boats
Among others 😁
Paul, sounds like that one has your name written all over it!
Ha thanks, not at those postage rates but I thought you might be interested or Bob @Bob Cleek
Edited by paulsutcliffe
Previous builds-
Among others 😁
I’v Been without power since Monday, so I haven’t been able to work on the G/R    Lots of snow
Current build:
Finished build:
6 hours ago, capnharv2 said:
How much did you get Rob? We got about 16-18".
We're lucky that we never lost power. A lot of people (including you) have been less lucky.
So, you've been watching TV by candle light??🤣
I have a 6000watt generator so I powered up the freezers and the fridge and also the TV.  I was able to get power to the coffee maker and microwave...but nothing else.  I also have lots of oil lamps which lit the house and gas stoves.
No internet...no hot water...and worse...no exiting the hill drive to/from the house.
I'm back to work today after shoveling my way out of the drive.  I have a Jeep, but my sweetheart is still stuck and can't get her car out.
I do hope to get back to the GR on Saturday....I'll have a few hours then...I hope.
We had 18~20 inches....my wife has lived hear her entire life and has never seen this much snow...and it lingering so long.
Good day everyone.
Rob
Current build:
Finished build:
The world's weather is going nuts; floods and fires here, freezes and snow on the upper half - stay safe one and all.  Sounds like you were well prepared at least Rob.
cheers
Pat
Edited by BANYAN
Thanks everyone for the concern and encouragements.
I spent some time this morning working on the top stay sail.
I made it as close to realistic as possible in this scale.
Here are some pics of the addition.
Rob
Current build:
Finished build:
