Using the drill press I drilled out the small holes to mount the deadeyes to the chainplates.
I'll mount them hopefully tomorrow.
Rob
Current build:
Finished build:
Current build(On hold):
Well finished the port side and I finished the fore mast on the starboard. B)
Current build:
Finished build:
I hope to finish the port side chainplates today and begin on the rudder after work.  Once the exterior details are finished I'm not sure if I will mount the anchor gear or begin laying the rail stanchons...(there will be a million).
Rob
Current build:
Finished build:
Finished up the port side...the deadeyes are not painted at this time..that will happen after the lanyards are seized for the shrouds.
Current build:
Finished build:
Patrick...the strangest thing is the illusion that is created from the sheer of the curve of the hull and the elevated chamfer of the deck.  The Great Republic had a spar deck..so seeing the chamfered deck at the height of the bulwarks is a bit distracting if you aren't aware that it is suppose to be that way.  Typically the main deck is recessed within the bulwarks and all one sees is the edge of the monkey rail.
Again..thanks for the fine comments...and thanks everyone for all the likes. ^_^
Rob
Current build:
Finished build:
Thanks..Kees. for your fine comments.
I want the Yellow metal/muntz to look used and weathered..like the rest of the ship...so it must take on a metallic/brownish tinge...as it would appear after seeing salt water.  Kinda like this older image of Cutty Sarks muntz metal plates.  But not quite as deteriorated.
Rob
Edited by rwiederrich
Current build:
Finished build:
Well I tinkered on the GR and finished up the rudder..here are some images.
Rob
Current build:
Finished build:
I also began the deck houses....
Rob
Current build:
Finished build:
The images of the deck houses don't looks so good...but I have more windows to add and some carving of the panel work....and the roofs.
Rob(5 to go)
Current build:
Finished build:
Well...now that the bath remodel is done I can spend some time on the GR.
So I finished up the fore deck house and the next one with the long boats mounted.   Here are some images..and one giving some reference with a penny for scale.
Rob
Current build:
Finished build:
good to see you've resumed :)   I was wondering where you went.   deck structures look nice........well done!  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks everyone.  At this scale the raised panels on the deck houses has been a real issue...along with the window panes.  I worked through the details and many experiments and came up with a system that works.  The houses are not glued down yet....not until the rail is fashioned.  I need plenty of room for that exercise.  3 More houses to go.
Current build:
Finished build:
Yes...expediting work on the bath still meant a month not working on the GR.  I felt like I was away from modeling for an entire season..... :o
I hope now that the weather is changing I can spend quality time on the ship.  (Knock on wood). Cleaned gutters and installed downspouts....trimmed trees and shrubs all day....swew...if I only had that kinda time for my modeling.... :D
Rob
Current build:
Finished build:
Thanks everyone...I have been on holiday in Washington DC and virginia and have recently returned...so I hope to return to the GR build soon.
Current build:
Finished build:
Spent some time working on the GR's anchors and catheads and whiskers.
Rob
Current build:
Finished build:
The cast anchors still need refining and the stocks still need to be added.  I haven't attached the tie downs as of yet either.  Making all the flute rests and the seats along the rail edge took the majority of time last night.  The whiskers are metal, riveted to the catheads.
I suspect I will suspend one of the anchors from one of the catheads and depict all the rigging required for such.  Probably sneak in the bowsprit in there as well.
Thanks for your fine comments. I'm laboring in the shadows of giants...so your comments are much appreciated.
Rob
Current build:
Finished build:
you must have kept her covered while you were gone  ;)     the hull is look'in sweet Rob.........nice look'in head gear too!  :)   it's good to see your back.
I put 'tarps' on all my projects when not in play  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Nights heads and the forward fife will be added soon.  Thanks for your comments and likes everyone.
Rob
Current build:
Finished build:
I'm sicker then a skunk today so I will be brief.  I tinkered on the GR and finished up the knightshead.
Going to bed...see everyone later.
Rob
Current build:
Finished build:
