Glad you are back, Igor, and up to your increadible standard too. Great details. It seems you improve yourself with every build you make ...
Carl
Hi Carl!
Many thanks for you feedback!
I just always have fun to try to make some new parts to test new ideas, etc. Unfortunately, it usually takes much more time than I plan earlier. :)
Best Regards!
Igor.
Fantastic work as usual Igor!
Mike
Current Wooden builds:  Amati/Victory Pegasus  MS Charles W. Morgan  Euromodel La Renommèe
Plastic builds:    Hs129B-2 1/48  SB2U-1 Vindicator 1/48  Five Star Yaeyama 1/700  Pit Road Asashio and Akashi 1/700 diorama  Walrus 1/48 and Albatross 1/700  Special Hobby Buffalo 1/32   IJN Notoro 1/700  Akitsu Maru 1/700
Completed builds :  Caldercraft Brig Badger   CLC Annapolis Wherry  Amati Hannah - Ship in Bottle  Pit Road Hatsuzakura 1/700   Hasegawa Shimakaze 1:350
F4B-4 and P-6E 1/72  Accurate Miniatures F3F-1/F3F-2 1/48  Tamiya F4F-4 Wildcat built as FM-1 1/48  Special Hobby Buffalo 1/48  Eduard Sikorsky JRS-1 1/72
Citroen 2CV 1/24 - Airfix and Tamiya  Entex Morgan 3-wheeler 1/16
Terminated build:  HMS Lyme (based on Corel Unicorn)
On the shelf:  Euromodel Friedrich Wilhelm zu Pferde; Caldercraft Victory; too many plastic ship, plane and car kits
Future potential scratch builds:  HMS Lyme (from NMM plans); Le Gros Ventre (from Ancre monographs), Dutch ship from Ab Hoving book, HMS Sussex from McCardle book, Philadelphia gunboat (Smithsonian plans)
This always boggles my mind.  Working with parts that can get lost behind a strand of hair?  Yikes!
I certainly admire the skill it takes but I cannot even fathom what it would actually be like doing the work.  Kudos to you, Igor!  I humbly bow.
Julie
First and only build: Endeavour - 1934 American's Cup, UK Challenger, J-Class - Amati 1:35
Thank you Mike!
Many thanks Julie Mo!
All of these components and part is not as difficult to make as it seems :)
Best Regards!
Igor.
I'm pondering on entering an Igor instruction class. You've got so much to teach ... brilliant
Many thanks Carl!
But I also continue to learn. This model has become my testing ground for the testing new ideas and technologies :)
During the last weekend I was continuing to work with sails.
At first I have glued grommets using CA. But it was not the good idea.
Then I tried to use Titebond II.
Then I have drilled holes.
Once with eyelets were finished, I once again painted the sails with a mixture of water diluted white glue and white acrylic.
Edited by IgorSky
That foremost sail is interesting. I'm not sure I've seen a sail like that before. She's looking great Igor.
Hi Daniel!
I used the plans of the yacht ENDEAVOUR for making the sails
Best Regards!
Igor.
I wonder if they did that to make it easier to tack.  With the end cut off it looks like it would pass over the other jib more easily.
It was done to improve the shape of the upper part of the sail to make the boat go faster.
Bob
Current build:  SS_ Mariefred
Very nice Igor!  Are those blocks wood?
Just our of curiosity, how will you step the masts into the hull?  It doesn't look like you are using a hinge - are you using a string from the bottom of the mast through the bottom of the hull?  I'm wondering because I'm doing a similar ship in an upright bottle, but still trying to figure out how to step the masts as I would prefer to avoid using a hinge.
Mike
