US Brig Syren by Hipexec - FINISHED - Model Shipways - 1:64 - building as USS Argus
Hi Dave,
I'll take a stab at answering - oar ports!
Doug
Current BuildsBluenose II - AKrabbenkutter / Prince de Neufchatel / Essex Cross-section / Syren / Barque Stefano / Winchelsea / Half Hull / Maria HF31 - Dusek / Bandirma - Turkmodel
On the Shelf: Santisima Trinidad and Cross Section / HMS Cutter Alert / Tender AVOS / Confederacy
Suspended Build: Bluenose II - Billing Boats Nr 600
Link to comment
Share on other sites
2 hours ago, lambsbk said:
Nice build Rich. The veneer will have a solid base.
Just curious - what are the small openings between the gun ports?
Dave
They are sweep ports (long oars)
Link to comment
The last side plank is installed. It was no bigger than a long toothpick. Now I'll tackle the stern
Link to comment
Beautiful planking!
Respectfully
Link to comment
Working on the stern. The plans and instructions are vague on this part with one fuzzy picture showing planks before painting.
Link to comment
More work on the stern. This piece will greatly strengthen the whole thing. While I was fitting the several pieces that comprise of the upper part of the stern, the ship slipped off my holding rack and the tip of the bowsprit broke off! Thank goodness it glued back with a perfect fit even though the break was jagged.
Link to comment
Here's my supply of veneer. I'll be using some to build the transom even though I'm a long way from putting veneer on the hull.
Link to comment
Continuing to build the stern. This is rough veneer planks plus the decorative trim that will eventually be installed. You can see where I screwed up rough planking by the stern post. I'll correct all that with sanding, filler then veneer planks. First I have to finish the bottom half of the stern.
Link to comment
More stern planks. I think I'm pretty close to hiding all my mistakes when I veneer plank the hull. If I were coppering it the same would apply.
Link to comment
Rich, what did you paint the metal decorative trim with to give it the wood color?
Jesse
 Current build: Syren : Kit- Model Shipways
Side project: HMS Bounty - Revel -(plastic)
On hold: Pre-owned, unfinished Mayflower (wood)
Past builds: Scottish Maid - AL- 1:50, USS North Carolina Battleship -1/350  (plastic),   Andromede - Dikar (wood),   Yatch Atlantic - 14" (wood),   Pirate Ship - 1:72 (plastic),   Custom built wood Brig from scratch - ?(3/4" =1'),   4 small scratch builds (wood),   Vietnamese fishing boat (wood)   & a Ship in a bottle
Link to comment
Rich,  I use those green fabric Velcro plant ties you get in garden shops to hold my model to the build rack. See the tail end of my Willie Bennett build log for photos of them in use.  You could run them under the rack and thru 1 or 2 gun ports - since they're Velcro they go on and off really easy and don't impart a lot of downward pressure on the model.
Link to comment
Jesse
Jesse,
It's gold paint to give it a gilded look
Link to comment
I put in the hole for the rudder. I'm holding off for now installing the stern post until I finish planking
Link to comment
Preparing inside the gunwales. Thinning them and making them even to receive planks
Link to comment
I'm pre-bending the stern trim to be installed later. I'm still preparing the inner gunwales to be planked.
Link to comment
Inside stern planks progressing. The white slash is the rudder port hole and will be stained
Link to comment
Another inside stern plank. This one partially covers gunports which I will trim when glue dries. Rudder hole has been stained
Link to comment
Finished rough planking the inside of the stern. Now I have to clean it up with trimming, etc
Link to comment
Inner transom cleaned up a bit. Now I'm cleaning up the inside gunwals so I can plank them. They are composed of dozens of small pieces and parts, so getting them smooth is a chore.
Link to comment
After a tremendous amount of making filler strips and blocks.... and sanding and sanding and sanding to get the gunwals narrowed and smooth....I finally glued on the first piece of inside planking. Now I have a very long road ahead of inside planking, outside veneer planking and deck planking. But this is the stuff of making the model look great when finished.
Link to comment
First inside course, both sides. Wow...all that patchwork sub-structure ( as per the plans), sure is ugly. I can't wait to cover it all up. Cutting out the tiny sweep ports was tricky since they and the gunports get partially covered during planking.
Link to comment
Both inner gunwals rough finished all the way up. Now I have to carefully trim the whole thing to prepare for the cap rail and outside planks.
Link to comment
Quick work on that Rich.  Well done!
Doug
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
