HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 69 donations so far out of 49,000 members - Can we at least get 100? C'mon guys!) ×
Thanks for the kind words.
I am using basswood instead of plywood. Those stanchions are exposed along the inside of the deck so they have to be solid wood instead of plywood. Plus the basswood sands a lot easier than plywood.
Russ
Your build is really looking good.  Working with the grain is always a good idea.
Cheers
Ken
Washington 1776 Galley
Completed Builds:
Pilot Boat Mary  (from Completed Gallery) (from MSW Build)
Well, I wish I had more to report, but there has been a lot going on lately. Yard work takes precedence so not much has gotten done in the shop. I injured my left thumb in a yard work accident and that also took some time away from modeling. Much better now and I am getting a few things done.
The margin plank is moving along. The most difficult area is in the bow so that is where I started. I am ready to glue the forward pieces in place.
Russ
Glad you didn't take off your thumb Russ, although, accidents are never practical ... Any bit of progress is progress, the margin plank seems to fit like a glove
Carl
Carl:
Thanks. I appreciate it.
There is just a bit of sanding yet to do on the margins before I glue them down.
Russ
  • 5 weeks later...
Russ - It was good to see you at the wooden boat show last weekend. I really like your use of building jigs you had on display. Too bad the rain put a damper on the sailing.
Everyone - This is a great little lugger. The lines are clean and hull shape shows the fine lines of an original Biloxi shrimp boat.
Thanks - Kenneth
Kenneth:
Many thanks for your kind words. It was great to see you and the family at the boat show as well.
Russ
Finally a little progress. I am working on the margin planking. I have settled on a process to make them that seems to work pretty well. While I have created templates for each of these plank in CAD, once you begin building the model, it pays to fit the components to the model instead of the templates created for them. Just makes life easier. :)
Here is a photo of the portside margin plank with a scarph joint and the blank for the next one aft that I am working with right now.
Russ
The margin planking is completed except for some minor trimming at the transom. Feels good to get something accomplished. :)
Russ
Kenneth:
Thanks. I appreciate it. :)
I really like the technique and I will use it again with these open bulwark workboats.
Russ
I am lining off the hull for planking. Still some work to do making sure the curves are what I want. It is very close though.
Russ
Moving right along, Russ. Always a pleasure to see your work.
A few of the older boats with similar lines were out at the annual Blessing of the Fleet yesterday in Biloxi. I was on the 1931 Doris Mae.
Keep up the good work -
Kenneth
Kenneth:
Thanks. I was thinking about the Doris Mae yesterday. Glad the rain did not spoil anything. :)
Russ
I know there are those who will not appreciate every little details or accomplishment, but I hope some of you will. The first plank has been cut and fitted. I always begin with the sheer strake. That establishes the curve off of which everything else will run. This plank has been spiled, tapered, and soaked. No glue yet. I will let it dry in place and when I glue it, it will have its shape and will need only finger pressure for a few minutes for the glue to take hold. Note the hi tech clamps. :)
Russ
glad to see you got over your injury in fine shape ;)    planking is coming along nicely!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Steven:
Thanks. These Biloxi luggers had nice lines, for sure.
As for planking, I was wish I was as good at it as many others here. :)
Russ
