Hello all and welcome to my log of the Fast Patrol Launch I picked this kit up second hand it is a very old kit I believe to be from the seventies possible even the sixties
it was produced by aerokits and distributed by keilkraft
DSC01101.jpg.3a9d322a5c348f0406bb42538334b7cf.jpgDSC01102.jpg.63531e1f17601af542a31dd385d7cd9d.jpg
and some pictures of the contents really not much to this little kit and all seems to be present
DSC01100.jpg.6dc03e1578d5784bc00074122f42aeb5.jpgDSC01099.jpg.4ffb8a947918d3c65464dc24ef9ef7ad.jpg
the previous owner had glued on four pieces before giving up two of these where cut to the wrong size and the other two glued on in the wrong place
so I removed those to have a fresh start
DSC01103.jpg.364b9f79fe236a6d87312e7e4b60e4b7.jpgDSC01104.jpg.4d351e3652f0e761cfe9bda9595ece42.jpg
here is a few pics to kick things off with the keel built and some of the framing dry fittedDSC01105.jpg.cec2dc7f7de2dead2f3692e7e2696cb5.jpgDSC01106.jpg.84e63fa9979b6b576473487622037d84.jpg
the kit certainly smells like it has lied in an attic/roofspace for a long time after working at it for a few hrs I can almost taste the horrible damp roofspace smell but once I get the frame on a bit a few coats of sand and seal will freshen it up,the plywood is in surpisenly good condition and seems bendable without cracking and hasent dried out at all
My intensions with this boat is to produce a display piece adding lots of hardwood and some pretty inlay work finished off with a super shiny polished surfice so call in and check on her once in a while to see that carried out
thanks for viewing
steve
Done a bit of research on this kit turns out it's actually from the fifties wow 60 + years old I am honoured to bring it back to life it could easily have remained unbuilt until it was simply not usable ,apart from the roof space odour it seems fine ,I found a company that remakes these vintage kits with same plans but with laser cut parts that's where I obtained the date of original
www.vintagemodelboats.com
turns out out I could have bought a modern version for not much more than the price I payed for the original but hey it's pretty cool to bring such an old kit back to life .
i now have the majority of the boat build it's a pretty straight forward system to build three bulkheads a transom and a breasthook some planks and plywood skins I will post some photos tomorrow after filling and sanding
I have taken copies of all the pieces before building as there is so little pieces and so little time to get a blank canvass of a hull I'm looking forward to the multiple different ways this build could go I definitely would like to try out epoxy and that's why I'm convinced at the minute to convert it to a yaught
thanks for viewing and any suggestions are more than welcome
steve
Hello all
With all the pieces that came along with this kit assembled the kit could be made watertight the rc componets fitted splash of paint and go have some fun however I plan on using it as a blank canvass for a display piece and the cool thing is if I mess it up I could quite easily knock up another blank canvass in a weekend
I see mahogany decks inlayed with pine strip decks real glass perhaps another level on top with wheel and controls a dive board on the stern glazed doors ladders/staircases seating areas brass handrails the list is limitless thanks for viewing and again any and all imput welcome
thanks steve
DSC01111.jpg.c891c9657c9084a54438af6de2e03c55.jpgDSC01112.jpg.1553be368f76fb12aa269f14cf0ece98.jpgDSC01113.jpg.0cf942cc314126455fbf48413783e0f0.jpgDSC01114.jpg.9871772a12b1a1ec55a55248d8554e79.jpgDSC01115.jpg.dffd9a3e5e98b2c26d54e6031641fe0e.jpgDSC01116.jpg.b4d125f0ffef4b3fe8f699b3ba1fc835.jpgDSC01117.jpg.7e27425662c2e2024a31e5461b8f0613.jpgDSC01118.jpg.17cef4ec1e9973ceef053697da606b67.jpgDSC01119.jpg.a61d14bde5e28a29dbe7aa8731373a6a.jpgDSC01120.jpg.8583eeffdd7b92565c958d9db7a75713.jpgDSC01121.jpg.25b515c3f81de74aa6aa53d25bf57435.jpgDSC01122.jpg.c94e83f41917d7fb847dec4128fc4777.jpgDSC01123.jpg.6b9b0ee84c0207932b1e0f456b9b5c66.jpgDSC01124.jpg.38658c5192fd0052211f931398c41fb8.jpgDSC01125.jpg.23d29231e7a758860534c837a2d6279c.jpgDSC01126.jpg.0bf773288d2e5e881d8ba10341eeea43.jpgDSC01127.jpg.1074bfdf5338d8516441ea91690da369.jpgDSC01128.jpg.c17d16df44dfc16b45f4b0fa21c712c2.jpgDSC01129.jpg.be5e221fe0cc0689300988f6fd8ff903.jpgDSC01130.jpg.37886f6860d875dadbd4edd895d79980.jpgDSC01131.jpg.2ec9f459cb7bdcdd5711a2f52ddad4b8.jpgDSC01132.jpg.9e548a1bc16b59741b269bb4f8f63395.jpgDSC01133.jpg.0852b65c065e6e2ce1c1ef9335b59b92.jpgDSC01134.jpg.0a4ceb026f4009b6a27cfeea54cec32b.jpgDSC01135.jpg.704b33e587bc1a2250dcfbe46673d77c.jpgDSC01136.jpg.5c341f6931f32082a0a6e2e1f5aeb3c0.jpgDSC01138.jpg.3522a5b00035a69127c49b7d2c9bc149.jpgDSC01137.jpg.b5b34fd73341c5edd2a4c2ffb65a57f3.jpgp124481758-3.jpg.35dcdda6bc5ea175f31cb67619eb9b8e.jpg
Great find Steve!! That looks like a fun little kit that you could get creative with. I got a seat and am ready to watch the show.
"It was a stormy sea that made a Captain out of me."
- Derina Harvey, "Captain" Derina Harvey Band
-E.J.
Current Builds - Vasa - Scratch
                               Royal Louis - Mamoli
                    Royal Caroline - Panart
Thanks E J
Hello all this evening I begun the first of many ideas to upgrade this little boat from the fifties
step one the deck planking
first thing was to create a border for the planking I traced the shape and made this on the drum sander
DSC01139.jpg.803b09c0e7a6f4add0c43be3bb259843.jpgDSC01140.jpg.56cd0713ecc8502d97585f60aa321efd.jpg
I rip some mahogany and thickness plane to 5.5mm I can then run it threw my little proxon saw a 1mmDSC01141.jpg.088a5a98ab2f374ed48b5635a0eaba72.jpgDSC01142.jpg.ce55e74fc4e7834552a6a24b5a025298.jpgDSC01143.jpg.dbffea8ca2ae2d404dc9ab63b930cb3e.jpgDSC01144.jpg.5cc6ce7e6d6d73c6ba3723aa57108956.jpgDSC01145.jpg.50cb488aa97ee826de25b1ebaddfc7ff.jpgDSC01147.jpg.4b9f3bb1af12b00c75265d3dc661473c.jpg
it was important to me to keep a line parallel with the middle cabin which I did achieve my next concern is when I start the starboard side can I keep them symmetrical DSC01148.jpg.aa3d81025e6e3d7fdd3d6a574ba587dd.jpgDSC01149.jpg.7b724b9f0759d27a307e59b529e833a7.jpg
for any of you that follow my other build the bounty im still awaiting parts from cornwall and I hope they arrive soon before this little boat steals my attention completely as im finding myself really beginning to enjoy this build
thanks for viewing
steve
Hey howya goin Steve mate, shes looking good mate.     :bird-vi:
I'm probably not going to live long enough to build all these but I'm BLOODY going to try HAHAHA.
Future Builds: The Schooner Bluenose, scale 1:48, POF Scratch Build (Gene Bodnar practicum - Plans from modelshipbuilder.com)
                       HMS Victory, scale 1:64 or 1:48, POF Scratch Build (John McKay's plans)
Current Builds: 42ft Longboat Armed for War 1834, scale 1:36 POF Scratch Build (Plans from A.N.C.R.E.)
                        Galley Washington 1776, scale 1:48, POF Scratch Build (NRG's Plans)
                        Ragusian Carrack, scale 1:59, POB kit (MarisStella)
                        King of the Mississippi, scale 1:80, POB Kit (Artesania Latina)
                        HMS Snake 1797, 18 Gun Sloop of War, scale 1:64, POB Kit (Jotika/CalderCraft)
Current Build: Stage Coach 1848, scale 1:10, Kit (Artesania Latina) Shhh don't tell the Admins I'm building this I'll hide it here ^under this line^ so they don't see it HAHAHA.
Do you have a known dimension such as a window or door that you could use to find the scale? Example, if you know the height of the actual window should be 2 feet and the model is 1 inch than your scale would be 1:24. There is a handy app for your phone called model scaler that I use for those handy conversions or to find unknown scales.
-E.J.
thanks E J I never thought such an app would exist that's gonna be real handy
This evenings activity saw deck planking on the starboard side and any worries over the symmetry being off vanished
I really don't know where im going with this build so any suggestions or examples very welcome ,at this stage the wheel house is still removable so that might be rebuilt a different shape I might raise the deck around the bow slightly also covering or redoing the deck planking is not a problem so any ideas guys jump in there and don't be a stranger
DSC01152.jpg.204520809041190cba12270f3e7a3283.jpgDSC01153.jpg.6d8cc2c18d12b40ef84cb5b7ad62a30f.jpgDSC01154.jpg.3104cdad0c6d4d08c5d5f721eb484b33.jpgDSC01155.jpg.941154316c8b367befd8076361a0190f.jpgDSC01156.jpg.4ec53a019fb89b9b5bd261179c7f901e.jpgDSC01157.jpg.f3a06f2cb61ab0d7c59e68da4f646cdd.jpg
Hi Steve,
Another awesome little project on the go I see. I think it's great that you're resurrecting an old kit that was unappreciated at some point, only to be brought to back to life and given the care and attention it deserves. It's a great little kit and you're going above and beyond in making it a stunner. It will look good and anyone's mantle!
Happy building!
Peter
Build Log: Billing - Cutty Sark
In The Gallery: HMS Unicorn, HMAV Bounty, L'Etoile, Marie Jeanne, Lilla Dan, Zeeschouw "Irene"
A Toast: To a wind that blows, A ship that goes, And the lass that loved a sailor!
Guest Riccardo1966
Hello Steve,
This is s very interesting build. I like how you have given an old model life and the very neat work in general, the deck looks beautiful.
Cheers Richard
Steve,
I like the idea that you kept following through with the idea of finish this kit even though you could had gotten a laser cut model for 70 quids.
My hat off for your dedication.
Looking forward to the see this yacht on display.
Respectfully
I would add a couple lawn chars, beer cooler and fishing gear off the stern... :P:cheers:
-E.J.
Superb work on the decking. Ever thought of lighting? Could be a good choice to add all the little detail in the wheelhouse.
Regards, Scott
Completed builds:
Awaiting construction:
Hello Steve, she is looking good. You were looking for ideas and sounds like you are ready to "bash the kit" and you also said you want a luxury yacht....... Well my thoughts would be to (lots of work) remove wheel house scrap the deck house. Move wheel house back further in order to increase cabin area and to provide a nice deck on bow for sun tanning(and sipping cool ones). When rebuilding wheel house slightly lower it, increase angle of windshield  and increase length of roof to cover more of the deck. Benches on either side inside of wheel house with a table in between them, captain's chair and access to cabin area. Build a false floor with access to bilge area (storage for more beer when cooler is full). At the stern build a nice padded bench that would house the motor and also provide another area to relax and sip cool ones. With the extended roof needing support install dancing pole to provide this. a bubble machine would also be cool;). Finally a ladder to allow access to the roof for those who have had enough cool ones and feel the urge to dive off risking it all. Lots and lots of work but you asked:D:P:cheers:.
Wow don now that's input ,you have just described my dream build all your ideas are great and I'm writing them all down for future reference
i particular like how you describe altering and moving the cabins thank you very much for your comment I'm gonna get to work sketching this out
cool looking boat Steve.......looks to be the same construction  as Midwest.   very nice job on an old model ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks guys for the interests and the likes
running a google image search I came across this boat I reckon I could clone it would mean re doing that pretty deck again where it raises at the bow  but hey that is no problem
ignore the size and shape of windows on mine this will all be planked over and new apertures created and as don mentioned I would need to make the windscreen steeper angled
if anyone has any pics you think this boat could be made in to throw them up there id be happy to see alternatives
thanks
steve
Go for Steve!  It'll be fun to see where you take this project.  Bonne chance mon ami!
Doug
Current BuildsBluenose II - AKrabbenkutter / Prince de Neufchatel / Essex Cross-section / Syren / Barque Stefano / Winchelsea / Half Hull / Maria HF31 - Dusek / Bandirma - Turkmodel
On the Shelf: Santisima Trinidad and Cross Section / HMS Cutter Alert / Tender AVOS / Confederacy
Suspended Build: Bluenose II - Billing Boats Nr 600
whats your advise guys on fibre glassing the hull I have zero experience with this and I am keen to learn what is required and approx cost and suppliers and after fibre glassing how do I finish it does it need laquer or something?
Very nice work so far--might have a go at something like the pic below... (Just use it as "inspiration", since so many of these mid-20th century cruisers were customized or one-off for individual tastes.) This way you wouldn't have to change the very nice deck you have, as well as having your craft become a smaller boat at a larger scale (somewhere between 1/32 and 1/24 maybe?) allowing for some nice detail work.  All the cabin sides and glass are straight, the only curved bit is the roof, which can be easily executed with tissue over planking over ribs.  Have fun!
