so are your waterways 3/32 or 6/32?   this must mean that your going to plank the deck with normal planking {1.5 mm}   I've always thought that the waterways should taper down to the scuppers.
    with the Bluenose I have,  dealing with the damage it received in shipping,  the bulwark posts had to be removed.  I will need to make scratch ones before I go any further.   I think it's also neat that your not using a deck platform,  as supplied in most kits......your going to plank over the frame.   your progress looks really nice :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Popeye,
The instructions and plans are referring to use two strakes 3/32" x 3/32", so when I looked at the real Bluenose (II) they only had one plank but wide, so that is what I went with.
Further pictures will show the difference.
The single plank has the measurement 6/32" x 3/32".
I understand this can be confusing of what I am trying to show and explain.
Respectfully
Planking is on the way.
The provided material is not long enough, which is stated in practicum and instruction manual.
There-fore we have to use another strip to create the remaining length of the strake.
Instead of using a straight cut of the plank where the bulkhead is located I chamfered the connecting planks for more contact surface.
After sanding it's hard to tell where the joint is located.
Respectfully
naaawww.....I just need to keep my width and thickness straight ;)    interesting alternative to staggered butt joints
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Had time this morning for another plank to be attached.
Current score, which puts Port in lead is 5 to 4 (referring the number of planks attached.)20170619_081623.thumb.jpg.633659afffdff9a339523224eceea63d.jpg
Respectfully
I truly enjoy planking this lady, using the combination of titebond II and CA works great.
Both glues has a short setting time, specially the CA welding the plank to the bulkhead while the Titebond seals up.
So far I don't think I haven't made any building error.
Planking  will continue.
I will provide an overall all in focus picture in the next day or two.
Respectfully
Now I have reached a critical point when it comes to planking of the stern.
It's more important to get the planks even. So doing two planks at the same time and making sure they are tapered properly.
This is just the beginning,  some trimming is necessary for a clean connection and glueing.
Respectfully
Respectfully
Figuring out how to get the planks meet up centerline I took  step backward and thought
"wait a minute, this what I am to do has been posted before"
Using a fine needle and sewing thread to get my centerline.
I should had done this before as I saw how "bad off line" I was with the planking.
Well, building is a learning experience and one will improve and get better by it.
Hopefully I can recover and get the remaining planks more center butted.
Respectfully
Should had thought of this before, I like the "plumbing line" feature.
Now if only I could take pictures that are perfect, so the inserted red line would line up right.:default_wallbash:
Respectfully
Looking good! Using string looks like it should work. Are you sure that the joints formed a straight line instead of the zig-zag pattern planks make when they meet? It would seem that a straight line might be prone to rot? Just my two cents, though I'm not sure if it's accurate.
-Elijah
Current build(s):
Completed build(s):
Model Shipways Phantom
Member of:
The Nautical Research Guild
Elijah,
Thank you for your thought, I appreciate all inputs.
I didn't know whether to go a zig-zag or straight line.
The instructions nor the practicum of Bobs didn't say which way to go.
However going straight was easier.
Besides it all will be painted, so it won't matter.
I have had plenty of time today with my lady so this is the progress so far.
Respectfully
My Admiral confiscated the TV so I weren't able to watch the America's Cup, but instead I got time planking.
Should be able to finish the hull this week. 20170626_081114.thumb.jpg.a77efabb3bcbddceeafd37b763e120b9.jpg
Respectfully
Nothing exciting but the hull is now planked and "putted" sanding with various grit and she will be ready for painting.
Respectfully
Bill, well when it comes to Syren I am to start all over again.
Continuation will follow regarding Syren.
So, very soon I have three models I will be working on.
Respectfully
the hull looks great :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Popeye,
Thank you for the compliment.
To me there are still a lot of imperfection of the hull before any primer or paint can be added.
Hopefully by the weekend I can do the waterline.
Respectfully
they all look like bent children when we first start out......as long as you have the contour of the hull,  you've half the battle won ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
I have turned my attention to the other side, and working on the fills between the bulkhead.
The instructions is showing three planks for the waterway, I have chosen two, one wider for the inside of the bulkhead and a fillers between.
Lots of cutting and trimming, but I think this will be very nice once done.
Sadly all this will be painted.
I am now alternating between the Bluenose and Syren, it's a nice change.
Respectfully
Sometimes I take painting to be a blessing in disguise.  You don't have to be perfect, you can add fill, then once sanded you paint over all the imperfections hiding them forever.  In my case, I'm glad the waterways will be painted.  I haven't done as nice a job as you have.  I look forward to following along with this build.
Derek
If you want to build a ship, don't drum up the men to gather wood, divide the work and give orders. Instead, teach them to yearn for the vast and endless sea
Antoine de Saint Exupery
Current Builds
Bluenose - Model Shipways - 1:64 Scale
Fair American - Model Shipways - 1:48 Scale
HMS Winchelsea 1764 - Group Build
On Deck
Guns of History Naval Smoothbore Deck Gun - 1:24 Scale
Finished Builds
Mare Nostrum - Artesania Latina - 1:35 Scale
Guns of History Carronade - Model Shipways - 1:24 Scale
Worldway,  thank you for the kind words. Teehee, glad that hull is being painted, had to do some covering of flaws.
Respectfully
Starboard waterways almost done.20170722_171316.thumb.jpg.a5c29d0362bfdb0055ad1fc321cce772.jpg20170722_171354.thumb.jpg.4375ac289df9683645bcd218041bc198.jpg
Respectfully
All the waterways are done, hull has been "putted" and sanded.
There was a lot of sanding, but the outcome was pleasing to my eye.
The hull has gotten one layer of Wipe-On-Poly.
Now drying in the sun.
Perfect day for outdoor work such as sanding and wipe on.20170729_132120.thumb.jpg.2fe8542d54d9ec7098871056844ec705.jpg20170729_131953.thumb.jpg.5b69932791eb5e97e3143643b7084084.jpg
Respectfully
Some 600 grit sanding and some touch up putty. Then time for primer of the hull.
Almost to that point, shaping of the bow is first to be done.
Respectfully
First thin primer layer applied to the hull.20170729_180656.thumb.jpg.8fdf40b8b488eb16fe0476b690572401.jpg
And I like it...... this as there was no wind outside.
Respectfully
The primer is not blue!:cheers:
Respectfully
A second layer later........ thanks to temperatures in mid 80's it's drying fast.
Once this layer is dry, more putty and sanding for final finish before painting.
Respectfully
For the record, the paper isn't blue either,  just the temperature in the shady area creating this illusion.
It's wierd.......
Respectfully
The Chinese Britannia casting parts for Bluenose, some of the parts I might to make myself as a replacement, specially the windlass. But it's sad seeing ModelExpo having parts manufactured abroad, to be shipped half the world while they do their own casting in Florida.
Respectfully
